08-17-2010, 11:55 AM | #126 | |
Re: Project “Learning as I Go”
You wouldn't be able to put up with the other three sisters and crazy mother.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224 |
08-25-2010, 09:27 PM | #127 |
Not much progress but some, got the core support out and removed the rear crossmember to move it back for the gas tank. Still need to notch the lower frame rails out to get it up where it needs to be. Been really busy lately, hopefully I will get some more time soon and get some real work done. Here are a couple pics.
08-27-2010, 08:16 PM | #128 |
PROJECT 7DEUCE
wOW YOU ARE REALLY MOVEIN WITH THIS PROJECT VERY COOL OF YOUR BROTHER TO DROP THAT ENGINE OFF..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-27-2010, 11:08 PM | #129 |
One day...
Yeah its coming along nice!
Im going to try and find a wrecked crew for the drive train wiring and seats for my crew cab. |
09-04-2010, 04:01 PM | #130 | ||
I got the gas tank mocked up, still need to do a little more grinding, and make the mounting straps. Still haven't had time to even get my engine out of the box, and now with football starting I can pretty much count Saturdays out.
09-04-2010, 05:00 PM | #131 |
Burnouts are therapeutic
great work it's coming together nicely, good job making it a short bed!
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
09-06-2010, 08:44 AM | #132 |
Looking good man.
09-06-2010, 09:15 AM | #133 |
One day...
Cool man thanks ill check it out, Tank is looking good!
09-08-2010, 08:05 PM | #134 | |
Thanks! I would be interested to see what they go for out there. If you can pick them up pretty cheap it would be awesome. My brother has an old Dodge truck of dad's that we are thinking about putting on a newer car frame like a 300 or Charger. If that happens we will probably go out there and pick one up. Worked on the tank a little more last night, got the rear crossmember moved back and put in the rails for the tank to pull up to installed. Still need to get the straps figured out but coming along a little.
09-08-2010, 08:59 PM | #135 |
Looking good.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
09-23-2010, 02:02 PM | #136 |
So the snowball continues to roll. I figured why stop tearing it down now. So I took all the rest of the brake lines off, removed the trailing arms, and took off the front suspension. It is officially down to nothing but the frame. I looked back at the beginning of my build thread and started to laugh at how my original intentions were so modest, now I'm staring at a pile of parts in the garage. I cut out holes in the crossmember and welded in some four inch pipe for the exhaust to run through, and am finalizing all the welding I have left. As soon as that is done I am taking the frame in to the sandblaster, painting it and starting to reassemble. I bought some extra pipe to notch the frame in the back but I think I have decided against it. Here are some pics.
09-23-2010, 02:33 PM | #137 |
Under Construction
nice work.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
09-23-2010, 02:34 PM | #138 |
Keep it up man. There are quite a few of us Okies that have projects in the works. One day, we might all have them done enough to go cruising.
09-24-2010, 11:00 AM | #139 |
Look at it this way: They only direction to go from here is back together!
Keep at it man. You'll be glad you went this far when it's done. |
09-24-2010, 01:46 PM | #140 |
Unless I just start knocking rivits out for no reason, it's all the way down! I was thinking about that yesterday, it can only get better from here. At least that's what I keep telling my wife.
09-30-2010, 08:56 PM | #141 |
Been trying to finish the frame welds so I can get this thing blasted and painted. I used the sections that I cut out of the frame for reinforcement. Still have to weld on the drivers side cab mount and I should be done. Here are some pics of the reinforcements.
10-08-2010, 05:02 PM | #142 |
I finally got my old engine sold, so that opened up a little more space in the garage! I was able to get my new engine out of the crate and mock it up on the frame. I thought that I was going to be able to use the original engine mounts from the Tahoe, but fabricating up some brackets seems a little sketchy. I do want to save as much money as possible but I think this is an area that I should just shell out the cash. I think these are the ones I want, but can't figure out what company makes them.
Here are some other pics of mocking it up.
10-09-2010, 08:46 AM | #143 |
Yeah I'm with you man. That isn't somewhere you want to skimp. Talk to glock35ipsc. He is working on a kit for the LS swaps. He is a wealth of knowledge on this.
10-09-2010, 05:39 PM | #144 |
One day...
Very cool! Now im jealous
10-09-2010, 05:51 PM | #145 | |
Thanks man!
10-09-2010, 07:31 PM | #146 |
One day...
You have all the wiring and computer and all?
I need to get out and check that out sometime if you dont mind. Last edited by scotts62; 10-09-2010 at 07:31 PM. |
10-10-2010, 10:36 AM | #147 |
Yep, it came with all of that. I have to get my harness disconnected and sent in to have cut down. I am going to use Wait4meperformance.com, I have read good reveiws on here about them. It's only $340 to have the harness modified and computer reprogrammed. From what I've read you can get the harness modified to be a little cleaner through other people, but this won't be a show truck so I can't see spending that much more. Shoot me a PM, I would love to show you what I have done so far.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224 Last edited by gopokes; 10-10-2010 at 10:38 AM. Reason: Forgot part of the reply. |
10-11-2010, 02:25 PM | #148 |
I've been trying to figure out what to do for front bumpstops and finally came up with this. I extended the crossmember out about an inch and a half and reinforced it. I will drill a hole to mount the stop and be done with it. Sorry about the pics, couldn't find my camera, had to use the cell phone.
These are the stops I am using.
10-11-2010, 08:50 PM | #149 |
Dang man you're working so hard your jeans can't keep up.
Looks good man! |
10-11-2010, 08:55 PM | #150 |
One day...
My wife calls mine that look like that my "church jeans" |
