#126 |
Re: project: What did I get myself into 50 chevy
Do you have some dimensions on those running board brackets that you made and possibly some locations to where you installed them on the frame? Your truck is bad a$$!
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
#127 | |
vintage car junkie
Thanks Fat Mike, the tube is 1x1.5" 11 gauge and gussets are 3/16 fronts are 14 1/4" center is 15.5" long not sure if im going to make a rear one yet since access is limited back there.
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 |
#128 |
vintage car junkie
Been busy on this, slacking on updates. Front clip is painted and installed, hood took 3 rounds of paint to get right. The clear kept showing stripes, once I grabbed the wrong reducer and wrinkled it all to hell. Repainted the cab also, went with more gloss than before. I like this round of paint better, I call it low gloss. Its glossy but no reflective qualities.
![]() ![]() Lots of custom work on the bed, here is one of them. ![]() Lots of parts rolling in ![]() Engine getting buttoned up. Waiting on a few more parts before its a runner. Brakes are done, new lines, booster, master, pads, rotors, etc. ![]()
#129 |
vintage car junkie
Final paint on hood, still not perfect but im over it.
![]() Sweet good fortune! ![]() One of the more fun parts, finding a rad hose to fit this nice angle. Ended up with a cool flex metal hose knock off. ![]() Finished off the frame in the rear. Old picture but the ends of that rear tube got boxed and everything finish welded. Still need to mount my air tank, battery and compressor in this area. USPS lost my new battery cable this week. ![]() ![]()
#130 |
![]() Join Date: Mar 2007
Looks good. I started final assembly last year. It was one of the most enjoyable parts of my LONG build.
Keep up the good work. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#131 |
Coming right along ... great progress & build.
R46 |
#132 |
i had to smile
![]() ![]() ![]() perfect paint is for those that pay for a paint job ![]() first trip out, you will get a rock chip any way... nice project, nice color, nice paint job.
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#133 |
blitz'd, looking good. I like the bed mods. Keep up the great work.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
#134 | |
vintage car junkie
Thanks Shannon!
#135 |
Truck is lookn good. If you want more practice painting just come on over.
#136 |
Good job your almost there like the color.
#137 |
vintage car junkie
Almost forgot to post this! I came up with a good cheap alternative to body mounts. Wish I had used these instead of the more expensive body mounts I bought a while back. These are for V8 belaire engine mounts part number 602-1044. 1045 is the same but a little larger. Best part is these are under $3 each. I used them for my rad support.
![]() ![]() Finished up the frame section today, decided to punch some "speed holes" for some visual appeal and to help route wiring and air line. Mounted up the air tank also. ![]() Made some mounts and hung the front bumper finally. Still need to adjust it, hood is not lining up properly on the drivers side though. Looks like I got that left front rad mount a little too high. Easy fix. ![]() Speed holes and frame graft. Wish I had thought this through a little more I could have made it look a little more seamless from the top if I had done it differently. Was more focused on strength even though this doesn't support anything really. Doubt I will be hauling anything in the bed of this one! Wait till you see the wood floor I built! ![]() ![]()
#138 |
vintage car junkie
And I just realized how bad my camera sucks! I need to rob the wifes Nikon tomorrow.
#139 |
That color is great!
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
#140 |
![]() Join Date: Mar 2011
Your build is coming along great.. Love the paint, im also going with the more semi gloss finish not just a flat paint job. That pearl really makes it.
I have been told it is super hard to paint, without it looking streaky. Cant wait to see photos in the sun with the front fenders on.
Blake. Sydney Aus 56 Chev 3100 build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363 LOW n LOUD ![]() |
#141 |
Just curious are you planning to use a splash apron behind your front bumper?
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
#142 | |
vintage car junkie
I want to make my own, just haven't decided on what to do yet. Need to get my hands on a dimple die and or bead roller.
#143 |
Those gates hoses work great for those crazy angles on the radiator. Truck is looking killer.
#144 | |
vintage car junkie
Good news is, USPS found my battery cable and its on the way. Some updates, fuel line is ran and gas tank installed, engine and front clip wired up. Air tank and compressor mounted. Re-engineered my brake pedal to work with the column moved over. The old column came out right into the header so It got moved about 2 inches to the left. Also had to make a new bracket for the stop lamp switch. Had to cut and weld the pedal arm with the booster pin on the other side to gain some clearance. ![]() ![]() ![]() Got a chrome column in trade for helping a buddy paint his truck, not my style so it getting painted vintage white like the dash on my next round of white paint. Waiting on a column drop and a u joint from CPP to connect it. ![]()
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 Last edited by blitz'd; 02-20-2012 at 02:43 AM. |
#145 |
vintage car junkie
Took some pictures with the wife's Nikon. I don't use it much since its expensive and confusing. Got a great shot here of the chip I put in the paint installing the bumper.
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 Last edited by blitz'd; 02-20-2012 at 02:44 AM. |
#146 |
That last shot is a great angle. It's gets pretty exciting the more shinny parts you intall. To me it was when it actuall felt like I could start to see the finsish line.
Keep it up. Marc
#147 |
Moving right along. I like the round pedals.
#148 |
progresso????
#149 |
sweet truck! subscribed and waiting for more!
2011 Silverado ECSB LT 2000 Silverado RCSB 2WD super bad habit of not owning a vehicle for a long time ![]() |
#150 |
i never get enough of looking at that paint color! fantastic!!!
