Old 01-31-2011, 01:06 PM   #126
Fat Mike
Fat Mike's Avatar
Re: Project 59 Apache "1st Build"
Thank you kawbe. Your door panel placement came out really nice.
Fat Mike is offline   Reply With Quote
Old 01-31-2011, 01:34 PM   #127
56ClassicTruck
Hey mike, what measurement did you go with from cub mount to shock hole? Did you ever get a answer? I did my sub at 28"3/8....... Looks like you are ready to weld........
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
56ClassicTruck is offline   Reply With Quote
Old 01-31-2011, 02:56 PM   #128
Fat Mike
Fat Mike's Avatar
I used the same measurement of 28 3/8" from the rear of the shock hole. 29 3/8" from the front of the shock hole.
Old 01-31-2011, 10:09 PM   #129
Fat Mike
Fat Mike's Avatar
Decided to come home alittle early today to do some welding, and wouldn't you know it, it starts to snow. I just moved everything inside and was able to weld up the c-notch. Just need to do a couple more measurements and will weld the c-notch to the frame.
Old 01-31-2011, 11:58 PM   #130
ratty 46
Looking good FM. Look at the snow on the brighter side .... you won't have to shovel the snow off your ouside concrete shop "floor" (LOL).
Let's get those installed .....
Ratty 46
ratty 46 is offline   Reply With Quote
Old 02-01-2011, 01:21 AM   #131
Kim57
Kim57's Avatar
Looking good Mike.
Kim
Kim57 is offline   Reply With Quote
Old 02-01-2011, 07:14 AM   #132
R.A.D
it snows in albuquerque? wow you do learn something new everyday
R.A.D is offline   Reply With Quote
Old 02-01-2011, 12:44 PM   #133
OrrieG
OrrieG's Avatar
One of my kids lived there for a couple of years and was amazed at how a light dusting as we call it would stop everything. She was used to waking up with a couple of inches, brushing it off he car and driving 25 miles to school. They don't close the schools up here unless we get 6" or so in one drop or a severe thaw freeze that ices up the roads real bad. 60% of the vehicles in the state are some form of 4wd or awd to deal with it. We are considering retiring to North NM or AZ.
OrrieG is offline   Reply With Quote
Old 02-01-2011, 01:28 PM   #134
Fat Mike
Fat Mike's Avatar
I am at home today because we got 2" of snow and the whole city shut down. Oh well, work on the truck today.
Old 02-01-2011, 05:16 PM   #135
R.A.D
i went to work today cause we only got twenty four inches of snow
Old 02-01-2011, 10:23 PM   #136
Fat Mike
Fat Mike's Avatar
Finally got all the c-notch all welded up. I will be attaching it to the inside of each side of the frame probably tommorrow.
Old 02-02-2011, 01:11 AM   #137
Kim57
Kim57's Avatar
Thay look good Mike.
Kim
Old 02-02-2011, 01:15 AM   #138
nikwho
nikwho's Avatar
Hey Mike! Its looking good. I cant wait to see your c notch all done. Hey, didn't you make your own air bag brackets/buckets? I seem to remember that. Do you have pics or specs? I dont want to spend $110 bucks on those if I can just go grab some pipe and some plate and fab them up. Mostly just need to know the diameter of the round plate on top and the diameter and depth of the round stock that you welded to it. Also what you're doing on the bottom(lower a-arm). Thanks, Nik
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 02-02-2011, 01:34 AM   #139
Fat Mike
Fat Mike's Avatar
Nikwho look under my Project 47 GMC post #20 and you will see the brackets I made. I got precut lower brackets with the mounting holes and vavle holes already precut for $6 a piece. I got some 5" by 3/16" round tube to make the sides, then drilled a hole threw the center and welded a nut to the backside of it. Used some all thread and there you go. Built all 4 for about $40.
Old 02-02-2011, 09:44 PM   #140
Fat Mike
Fat Mike's Avatar
I worked on the 59 today and got some of the boring stuff done. Moved and drilled the rear body mounts. Have not figured out if I should weld a nut to the backside or if I should do something similiar to how Kawbe fastened his seats to the floorboards. Also, found the center line of the rear c-notch and I got everything close to where it is going to go. Posted a picture of how I am going to attach the gussets to the frame. There will be one on the top and bottom. I was thinking of welding a piece of 2X6 piece of tubing on the inside of the rear frame where I will be welding the new narrowed frame will go. After looking at Grimms build I will use some 1/4", 2"X4" tubing sideways and weld it to the inside of the frame. Then I will still box it in with 3/16" plate. Finally weld the new frame to the boxing plate. NEED SOME FEEDBACK!
Old 02-02-2011, 09:49 PM   #141
Fat Mike
Fat Mike's Avatar
Here is a few more pictures!
Old 02-03-2011, 11:42 PM   #142
ratty 46
Oh .... I like the web gussetts ....
Ratty 46
Old 02-04-2011, 09:55 AM   #143
Fat Mike
Fat Mike's Avatar
Ratty 46
Thank you! I thought they were pretty cool also.
Old 02-04-2011, 11:45 AM   #144
jjjmm56
jjjmm56's Avatar
Mike you've really come a long way, not only with your project but also with your skills. Keep up the good work.
jjjmm56 is offline   Reply With Quote
Old 02-04-2011, 12:05 PM   #145
Fat Mike
Fat Mike's Avatar
Thank you and everyone else. I have learned everything from you guys! I love this website.
Old 02-04-2011, 10:44 PM   #146
troy54gmc
troy54gmc's Avatar
lookin good Mike. great job on the frame bro....
troy54gmc is offline   Reply With Quote
Old 02-05-2011, 02:38 PM   #147
Fat Mike
Fat Mike's Avatar
Thank you Troy. I was trying to get it to look just like yours.
Old 02-05-2011, 07:28 PM   #148
R.A.D
fat mike your doing great keep the pictures coming
Old 02-06-2011, 03:20 AM   #149
BC Toy chest
BC Toy chest's Avatar
Looks really gr8 Fat Mike & the web gussetts are realy different I like that.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 02-06-2011, 10:51 AM   #150
Fat Mike
Fat Mike's Avatar
Thank you RAD! Do you have a build thread? If not you should start one. Would really like to see it.
Thank you BC Toy Chest! How is your build going? Haven't seen you post anything in awhile. Look forward to some new posts.
