Old 12-09-2011, 12:06 PM   #126
cochino12
It followed me home?
cochino12's Avatar
Re: 88 Crew cab dually
I decided on doing the porterbuilt arms narrowed but $1300 is a little more than I can spend right now (if it still snowed in colorado it would be a different story ) so had a friend of mine cup my lca's for now. hopefully I can order the porterbuilt stuff next month. Still need to clean these up paint them and put some new ball joints in.
I also got a new 88-91 gmc grill, found some of the headlight stuff I needed so I can start the front end swap this weekend. I finally got the stuff I need to get my blazer rolling so I can finally list it for sale. Just need to put some color on it and decide what I'm going to ask for it.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-12-2011, 06:13 PM   #127
cochino12
cochino12's Avatar
Got the arms put on last weekend and now it lays on the control arms, still need to pull a leaf out of the back, maybe add a 1" block to get the rear to hit the notch.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-14-2011, 06:03 PM   #128
Leedogg
Nice Adam!
So basically- that's as low as you can go with a stock frame and crossmember? What are you running for the rear notch?
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 12-15-2011, 12:21 AM   #129
luifer76
luifer76's Avatar
The LCA's look good man...... and the truck looks sick....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 12-16-2011, 11:49 PM   #130
cochino12
cochino12's Avatar
Thanks guys
Originally Posted by Leedogg View Post
Nice Adam!
Apparently most one tons will lay frame but some will hit the arms first, lucky me, my arms hit first I'm using a bolt in western chassis notch which was plenty tall enough to get the diff to hit the bed. I didn't want to but I ended up cutting a hole to clear the pumpkin, sticks through about 2-3"
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-16-2011, 11:57 PM   #131
SCOTI
SCOTI's Avatar
Originally Posted by cochino12 View Post
Thanks guys
I'm just going to cut/raise the floor between the tubs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2011, 11:38 AM   #132
cochino12
cochino12's Avatar
That is what wanted to do also, I'm waiting on mr porterbuilt to finish his 1 ton 4 link first though. I have a feeling its not going to be done as soon s he thinks though.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-18-2011, 02:19 PM   #133
SCOTI
SCOTI's Avatar
RideTechs HD Airbar. Just relocate the upper bag mounts a little higher & do a generic step-notch if more drop is desired.
They don't offer a c-notch w/their kit & thus the un-cut frame is what limits the total amount of drop. I still don't understand where they get their 7-10" drop dimension for the 73-91 C30 set-up when there's no c-notch used because on mine the dimension is </= 8" between the top of the axle tube & the bottom of the frame.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-18-2011, 11:32 PM   #134
cochino12
cochino12's Avatar
I just went to the airride.com site and they dont list the c30 kit anymore?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-18-2011, 11:40 PM   #135
lolife99
67-72 parts collector,…
lolife99's Avatar
Didn't find it at www.ridetech.com,... but Jegs still shows it listed.
Hmmm,...
http://www.jegs.com/i/Ridetech/029/1...ductId=1631811
Keith
Convert to disc brakes.
Old 12-19-2011, 12:04 AM   #136
SCOTI
SCOTI's Avatar
That's weird. I wonder if they're phasing the HD stuff out??
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-26-2011, 08:05 PM   #137
cochino12
cochino12's Avatar
Got an email from Nate today, looks like he has had some other requests for a bolt on 1 ton kit and thinks it should bebetter by the end of January.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-26-2011, 09:00 PM   #138
Leedogg
I hope they do so.
Does KP do a 6 link setup for 1 tons? I am thinking porterbuilt front and a 6 link out back for mine. But that'll be at least another 15 months from now.
Old 12-26-2011, 09:05 PM   #139
SCOTI
SCOTI's Avatar
I hope they do so.
They only offered 1/2 ton stuff when I researched rear suspension options. Also, based on conversations I had w/them before CA Chassisworks bought them out, the 6-link is intended for a cruiser only & not for supporting ANY kind of load other than the cooler & lawn chairs for a show.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2012, 08:29 PM   #140
cochino12
cochino12's Avatar
This weekend I finally had a chance to finish up all the wiring, routing hoses, and clean up the rest of the air install. I also wired in the new headlight harness for the new core support. I still have a leak in the right front bag somewhere but I'm going to call it done for a couple weeks so I can work on my new swb.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-29-2012, 10:10 PM   #141
rs72z
rs72z's Avatar
Truck looks awsome Adam. I love the GMC front.
Paul
rs72z is offline   Reply With Quote
Old 01-29-2012, 10:12 PM   #142
rs72z
rs72z's Avatar
What size tires did you end up with on the front?
Old 01-30-2012, 10:34 AM   #143
cochino12
cochino12's Avatar
Thanks, I really never liked that phantom grille, GMC looks much better I think. Front and rear tires are 225 75 16
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-30-2012, 12:03 PM   #144
rs72z
rs72z's Avatar
Do you still have the front fender wells in?
Old 01-30-2012, 02:33 PM   #145
cochino12
cochino12's Avatar
as requested, a picture of the rear bag maxed out. It lifts the rear fender about 2.5" above the tire
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-30-2012, 02:34 PM   #146
cochino12
cochino12's Avatar
inner fenders have been pulled out and the inner fender structure was trimmed up too.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-06-2012, 02:57 PM   #147
ChevyFreak60
ChevyFreak60's Avatar
Bad a$$ truck bro. Were you selling it on craigslist a while back?
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 02-06-2012, 07:18 PM   #148
luifer76
luifer76's Avatar
Very nice man.... truck is looking good....
Old 02-10-2012, 07:39 PM   #149
cochino12
cochino12's Avatar
I was, still thinking about selling it.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-12-2012, 11:18 PM   #150
yellowGT
yellowGT's Avatar
you mind posting what size bags those are and if you have more pics of the notch and rest of setup. Im about to start on mine myself.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
