Old 02-26-2011, 11:07 AM   #126
lakeroadster
Re: #3 The Sickness Continues
Originally Posted by protrash64 View Post
Installed the third brake lite today. Fairly easy to do. The hardest part was fishing over the wire, and it wasn't too bad. Of course the dome lite was rigged in there so now I have to fix that......
Sweet truck Protrash. Just walked thru the thread, nice mod's. The tailgate color matching is impressive.
Quite the collection you got going there.
I am envious of the posts where you are working in the driveway in the middle of "winter". Although I suppose that summer is quite "toasty".
lakeroadster is offline   Reply With Quote
Old 02-26-2011, 11:17 AM   #127
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Truck is looking good you are dong a great job turning that truck around real quick. I'm thinking like Dino, I should have bought that truck too...
I need to take a run to the East side and hang out. Probably need to get a hotel room for the night and make it a stay-cation
Keep the pics coming!
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 02-26-2011, 01:16 PM   #128
protrash64
Resistance is Futile
protrash64's Avatar
Thanx much!!! The tailgate color match was more like dumb luck...but that works too!! I definitely use winter as much as possible to try and get things done and it is my favorite time of year. I've worked outside for 20 years so my adjectives are a little stronger than toasty.
Tony
Thanx Tony; I've been trying hard to get all the stuff done and I've fixed quite a bit more than I intended, but I think we know how that goes. If your up for an eastside run your more than welcome. I've gone out to the cruise that PMD frequents and figured I'd meet him at some point. I'm roughly in east-central Mesa.
Nice work on your ride, by the way, it looks super nice.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-27-2011, 08:07 PM   #129
protrash64
protrash64's Avatar
Some work, bad weather, and relaxing got in the way of more progress this weekend but I did fix my dome light by replacing it. Didnt know I had one extra. Also installed new valve cover gaskets as the old ones were leaking. Used Fel-Pro rubber and got rid of the big hold downs. Cleaned the valve covers and used some 1/4''-20 bolts....also pulled out my horn buttons. I'm going with the fancy one as it fits the steering wheel better. The wheel I installed is 1/2'' in diameter larger than the previous wheel. Here are some pics.....
Old 03-04-2011, 08:13 PM   #130
protrash64
protrash64's Avatar
Just for fun I painted my fender emblems; hoefully they match the tastefully dilapidated look of the truck. Cleaning up some wiring and doing my dizzy swap, too.
Old 03-04-2011, 11:48 PM   #131
protrash64
protrash64's Avatar
OK, finished my dizzy swap. I still need to re-do some wiring and fire it up. It fit no problem; dont know why others have issues. I also have an Accel coil on top which is huge and it clears the firewall by 1/4''.
Pulled out my plug wires that came on the 454 in the 'burb.....the pics speak for themselves.
Old 03-06-2011, 09:51 AM   #132
protrash64
protrash64's Avatar
Didn't get it fired. Had no spark and solved that problem. Now it's just a timing issue and I ran out of steam. I need to pull the cap and get everything lined up and I believe it will fire up with no problem.
Old 03-06-2011, 10:47 AM   #133
daverod
SSN 706
daverod's Avatar
Must be the one gear off thing. That kicked my butt for hours. It's a new day.
daverod is offline   Reply With Quote
Old 03-06-2011, 02:44 PM   #134
Dinos63
chevy only
Dinos63's Avatar
Are you going out to goodguys kat??
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 03-06-2011, 02:59 PM   #135
protrash64
protrash64's Avatar
Not sure, Dino. Are you??
Old 03-06-2011, 05:56 PM   #136
protrash64
protrash64's Avatar
Fire in the hole
Old 03-06-2011, 06:54 PM   #137
Dinos63
chevy only
Dinos63's Avatar
TRYING SUBS STILL IN THE INTERIOR SHOP, LET ME KNOW I LIKE TO CATCH UP WITH YA
Old 03-06-2011, 10:01 PM   #138
protrash64
protrash64's Avatar
Timing was off some so I moved the dizzy after setting TDC on #1. Fired up but it needed advance and I was against the firewall so I pulled it back out and moved it one tooth to center my dizzy throw.
How the hell do you put in the horn button???
Old 03-13-2011, 08:20 PM   #139
protrash64
protrash64's Avatar
Repeat of my last question: How do you install the horn button? I greased mine up but it keeps popping out!
Played around today and painted my ms/cyl and made a cover for my shifter base. Drove around the 'hood pumping the brake as it does not have enough pedal. It's the last thing to be done so I can drive this truck.
Old 03-19-2011, 07:14 PM   #140
protrash64
protrash64's Avatar
Well, this will be worth a 100 views and no replies......
Drove to a cruise last nite just to go somewhere and ran into 2 Board members, Rob and Erock. Nice seeing you guys.
Finally fixed my turn signals after tearing the stuff apart for the 3rd time. The wiring terminates in a block that fits into the turn signal switch assembly. Mine aparently loosened up over time. I figured this out by taking off the steering wheel and staring at the switch while clicking it back and forth. It caused my left turn signals not to operate unless I held down on the lever. (See the pic of a spare switch with the two parts.) I fixed it by slightly bending the small brass leaves that make contact with one another. Simple!!
I tore apart a spare column and used the pieces to eliminate my column shifter and put on some parts with original fawn and patina. Finally figured out how to get the horn button in too.
Old 03-19-2011, 08:54 PM   #141
joe231
joe231's Avatar
did you get the horn button figured out?
I had the same problem with the the turn signals on the '66
it's nice when you can tear something apart and fix it without having to buy anything
CHEVY ONLY
Old 03-19-2011, 10:30 PM   #142
protrash64
protrash64's Avatar
Yes. It finally occured to me to put the rubber ring in first, then slide the horn button on. I had the rubber on the button and was trying to cram it into the retaining ring/cup.
Old 03-19-2011, 11:16 PM   #143
bubba327
HOW long until spring??
bubba327's Avatar
It is hard to reply to all the threads but we are watching your progress!!
I fought a tilt column turn signal for the better half of a weekend once before it gave up fighting and let me win!!
Looking good!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 03-19-2011, 11:31 PM   #144
joe231
joe231's Avatar
CHEVY ONLY
Old 03-19-2011, 11:45 PM   #145
protrash64
protrash64's Avatar
Looking good!!
Thanx bubba! I hate the turn signal stuff, but I figured if it broke or was too messed up I could get a new one ordered. I did learn how they work, too.
Old 03-19-2011, 11:48 PM   #146
bubba327
bubba327's Avatar
I adapted my 64 to a 77 tilt column and spent days with a wiring diagram adapting the old to the new . But I have turn signals and hazard lights that work now!!
I will be passing through Yuma soon to help my In-laws.-Wish Mesa was closer and I had more time, I would love to check out the Dry Desert wrecking yards and meet some of the Arizona members
Old 03-19-2011, 11:53 PM   #147
daverod
SSN 706
daverod's Avatar
I just roll the window down and use my hand. It's old school.
Old 03-19-2011, 11:59 PM   #148
protrash64
protrash64's Avatar
I have a 73+ column in my 'burb. It's too short! I was going to change it out at some point. I can steer with it all the way up and arm on my leg...I'm 6'2''.
On Saturday a bunch of board members are getting together in Scottsdale, cant make it??
Been there.........
Old 03-20-2011, 12:19 AM   #149
bubba327
bubba327's Avatar
Sorry,
I wont be in Yuma till the following Tuesday
I went to "Moonlight in the Oasis" show in Yuma a few years ago and was bummed to find out that they moved it up to early March and I would miss it this time.
I may be a snowbird someday , save me a spot in a few years !
I used to laugh at my In-laws yearly migration but as I get older, being warm all winter is looking better than snow and freezing my butt off .
Thanks for the invite!!
Old 03-20-2011, 12:28 AM   #150
protrash64
protrash64's Avatar
Bummer. By the way, bubba....I've sent the youtube video of the tuner you posted on daves' thread to a bunch of people: unbelievable
