Old 07-30-2011, 02:18 AM   #126
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: My 66 Service Truck Build Thread
Something I thought of the other day, and just did a search for here in the forums;
neoprene washers for the fender top bolts:
67-72chevytrucks.com/vboard/showpost.php?p=3733189&postcount=661
66 C20 Service Truck:
Old 07-30-2011, 02:52 AM   #127
LostMy65
LostMy65's Avatar
Well Okay,
I got to drive it some before I tore the old box off.
It was fun.
I now have most of the patch panels to do the bad areas of the outer edge of the floor, cab corners and rocker panels.
I still have the box off so I started cleaning up the rear part of the frame.
So I figured I might as well dive in and pull the cab and get it cleaned up real nice.
Also got the cab windows out and will be building some kind of Rotisserie
http://67-72chevytrucks.com/vboard/s...d.php?t=406238
Old 08-18-2011, 02:20 AM   #128
LostMy65
LostMy65's Avatar
Wiring Thread Links for future reference:
http://67-72chevytrucks.com/vboard//...d.php?t=374553
http://67-72chevytrucks.com/vboard/s...d.php?t=425114
Old 08-20-2011, 02:27 AM   #129
LostMy65
LostMy65's Avatar
Originally Posted by LostMy65 View Post
Well Okay,
I don't have the money to do a complete frame up restore at this time, so I'm doing more of a frame up preservation.
I just want this thing reliable mechanically, and preserved & protected.
Like I posted above; I have the old box off and cleaned the rear part of the frame. I now have the cab off and gave it a good pressure wash and cleaning with dawn, underside and all - along with the rest of the frame.
I decided to pull the engine and do the front end swap to the complete front end with 8-lug discs that I bought last winter.
Yes, I know... Since I have everything tore off, now would be a good time to sandblast everything. But I'm just going to rustoleum the frame for now.
Once I have the frame painted, I'll put the motor back in.
Then I'll start patching my cab.
I'll epoxy the cab as I get areas stripped and repaired.
I guess instead of calling this my 'Build' thread, I should of called it my 'Work on in spurts' thread.
Old 08-20-2011, 03:46 AM   #130
pdxhall
pdxhall's Avatar
You know what you've started don't you? You can never go back.
pdxhall is offline   Reply With Quote
Old 08-21-2011, 01:52 AM   #131
LostMy65
LostMy65's Avatar
Here's a good thread on hooking things up:
http://67-72chevytrucks.com/vboard/s...ght=disc+brake
Old 08-27-2011, 01:44 AM   #132
LostMy65
LostMy65's Avatar
Using this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=461537
I got the 8-Lug Discs front end all bolted up today:
Old 08-28-2011, 02:39 AM   #133
Captainfab
60-66 Nut
Did you change the crossmember and all?
Old 08-28-2011, 02:52 AM   #134
LostMy65
LostMy65's Avatar
Yep.
I just rolled mine out, and rolled the other in.
Needed to drill a new upper front hole and wallow out the lower.
Like Highlander shows in these pics:
Old 08-29-2011, 02:36 AM   #135
Captainfab
60-66 Nut
Yep, that's all you need to do. Drill one new hole on each side and elongate one hole on each side. C10, C20 are the same. I've never done this with the engine installed.
Old 09-03-2011, 01:28 AM   #136
LostMy65
LostMy65's Avatar
My truck must have been hit from the side at one time.
The passnger door was pretty beat up. - (I have since found two nice doors)
I stripped the rear passenger door jam / cab corner / rear pillar and it is pretty beat up also.
Found a junk cab local in the booming metropolis of Boring that has no damage to the portion I need:
Old 09-03-2011, 01:35 AM   #137
LostMy65
LostMy65's Avatar
No, It wasn't something I could hammer and dolly out.
Because of how beat up that portion is, it has also caused the area that creates the complimentary gap to the door to be all out of wack. The previous owner used bondo to make that gap between the door and cab look straight.
It just makes more sense to replace that whole portion.
Old 09-03-2011, 01:49 AM   #138
LostMy65
LostMy65's Avatar
Pulling diagonal dimensions from the visor hole both directions shows the passenger door jam is knocked in 1/4 inch where the rocker panel meets the rear door pillar.
Old 09-03-2011, 11:45 AM   #139
chad64chevy
chad64chevy's Avatar
(I guess instead of calling this my 'Build' thread, I should of called it my 'Work on in spurts' thread.) i know what you mean, i only get a lil time to work on mine lately, but i have been buying a parts instead! i've had my truck for 6 yrs. and i wish i would have started on my truck a few years ago when i has more money then i do now, lol! anyways thanks for posting in my thread, and keep at it!
chad64chevy is offline   Reply With Quote
Old 09-11-2011, 01:25 AM   #140
LostMy65
LostMy65's Avatar
I was having a difficult time getting the front cab supports out of the Floor Support Brace, so i just cut the whole square out, even through the Floor Support Brace.
I then had easier access to get the cab support out.
I bolted up the new cab support brace so I could see exactly where to bend the tabs at the upper part of the cab support brace.
I'll clean everything up real good before I start putting it back together.
Once I have the new cab support braces welded in good and the Floor Support Brace all welded back up, I'll roll the cab back forward and mount it up to the frame.
Then I'll move on to the floors, inner/outer rockers, etc.
Old 09-11-2011, 02:11 AM   #141
LostMy65
LostMy65's Avatar
...clip...I've never done this with the engine installed.
Neither did I.
My engine was out.
Those pics above were from Highlander's front swap thread.
Old 09-11-2011, 07:01 AM   #142
aerotruk63
aerotruk63's Avatar
Did you build a rotisserie?
Old 09-11-2011, 07:09 PM   #143
LostMy65
LostMy65's Avatar
I had everything I needed to bolt it up similar to this.
Except I was going to hoist it up from a girder in my pole barn.
It wasn't going to be anything fancy.
The part that would of bolted to the door frame I made out of 1-1/8" Plywood.
I would of then ran a 2-1/2" pipe through the center point of the plywood all the way through to rotate the cab on.
This pipe I would of hoisted from either end to suspend the cab.
I never went through with it.
I may pick up where I left off on it this winter and will take pics if so.
Old 09-13-2011, 02:37 AM   #144
LostMy65
LostMy65's Avatar
I posted this in another related thread;
Does someone have this measurement?
Old 09-13-2011, 09:13 AM   #145
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
That measurement isn't given because the bushing dictates that measurment from cab brace to frame. the top of the cab mount bracket to frame top is 1 1/16th" if memory serves. I just put those frame brackets on my 71/66 conversion.
Is that what you are asking?
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 09-13-2011, 04:49 PM   #146
chad64chevy
question is this your services truck cab or an extra one you have?? looks like your doing a good job anyways!
Old 09-13-2011, 06:40 PM   #147
LostMy65
LostMy65's Avatar
Funny you should ask.
I kinda went back and forth with which route to take.
There was some nice things about the donor cab I acquired, but the floors were totally shot - I mean really shot and hacked up.
I was tempted to completely redo the floors, but in the end, I decided to keep my original service truck cab and use what I need off the donor to fix mine.
So, the short answer to your question: The pics of the repairs I'm doing above are of my 66 service truck's original cab.
Old 09-13-2011, 10:25 PM   #148
Howell88
Howell88's Avatar
Thumbs up Re: My 66 Service Truck Build Thread
Enjoying your story man! Awseome what youve done so far with that truck man! keep it coming!
just tell her its a work of art and will never really be FINISHED! If that doesnt cause a pause in her rant then you have real problems!
Howell88 is offline   Reply With Quote
Old 09-14-2011, 12:36 AM   #149
LostMy65
LostMy65's Avatar
Thanks.
The project does seem overwhelming at times, but these forums inspire me to keep at it.
Old 09-14-2011, 04:41 PM   #150
chad64chevy
ok, cool! i have a parts truck i bought off my friend before he went back to cali for $50! he was going to scrape it and i needed parts, so i got it! its got the normal rust in the cab also but the suspension parts were only 6 years old, they got sold! all-in-all i made 300-350 i got my moneys worth! cab didnt have a title so im cutting my patches out of it and saving myself even more money
