Old 03-22-2012, 11:55 PM   #126
protrash64
Resistance is Futile
protrash64's Avatar
Re: My Build: Home Depot Machine
The cleared panels look more 'aged' to me....like them either way.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-23-2012, 09:34 PM   #127
baggedbigblock
Thanks!
I am done w the wiring!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I am going to get a battery and start it on monday.Also monday, the front end goes back on, the doors go back on. The bed is already on but I forgot to take pics. Shocks are in but need to be installed, I have to finish the paint, exhaust, and wait for the driveshaft to be finished.
sweet ass connectors! Do it right once!
baggedbigblock is offline   Reply With Quote
Old 03-27-2012, 10:32 AM   #128
baggedbigblock
I put the front clip back on, there is no way to retain inner fenders with the wheel offset I am running. I etched and primed the entire cab and doors. All that is left is to paint the front clip and hood. The truck will need a bit more filler work and block sanding before final paint, but that will be at a cleaner booth 30 min away with high quality paint guns and DA's. Forgot the keys so I couldn't try and start it, later next week I will.
Old 04-03-2012, 10:00 AM   #129
baggedbigblock
Got the door cards in for now. It will be a month or so until we get the new fenders and cowl so it will be primer for now.
Cut down the stock tubs to cover the wheels, I will make them level and then lay the wood floor down
Radiator is in.
Tail lights wired
Old 04-04-2012, 12:01 AM   #130
baggedbigblock
A little more work done. I finished the wiring but I don't have a battery yet, waiting on an Optima to come in. I used a motorcycle battery to test lights and gauges. Everything works on the 1st try!!!!!!!! I have some poor grounds I didn't sand down the epoxied frame on the ground points. 1 headlight and 1 taillight are dim. Once I get the battery in I will crank it over. I need to get 2 new front fenders, a windshield, finish exhaust and install the driveshaft. Brakes are bled.
The only sticker I'm putting on the truck. I love Dia de los Muertos.
lights!!
New rear window trim to be installed so neglect the over spray
Old 04-07-2012, 09:12 AM   #131
baggedbigblock
So some of these are out of order. My good friend stopped by from Colorado 2 weeks ago to take so pics with his fancy pants camera and editing software. Here they are, some are of the shop cars too
Here is the first start up vid. I like the cam so far. no mufflers just open headers now.
Old 04-08-2012, 11:18 PM   #132
McMurphy
McMurphy's Avatar
Right on man, you have got to be stoked !!
You are almost there and just in time for summer crusin !!
Guessing that is you with the bigass grin and the thumbs up?
Always cool to put a face to the build after a while LOL.
Congrats on running wire! I am contemplating wiring soon too. I like your connectors and heat skrink, makes a real smooth and better looking than the crip on connectors IMO.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 04-09-2012, 10:21 AM   #133
baggedbigblock
Thanks McMurphy,
Yup, thats me w the thumbs up. It is perfect timing to be out and about cruising this thing. I agree the wiring takes time but knowing its done right makes me feel so much better, I dont want to worry about connections getting loose. I also enjoy hiding the wires, they are all tucked into the frame rail and out of site.
Old 04-09-2012, 08:29 PM   #134
c.brown
c.brown's Avatar
truck is looking good cant wait to here mine run
1966 suburban slammed fuel injected 6.2L
My build
c.brown is offline   Reply With Quote
Old 04-12-2012, 12:26 PM   #135
baggedbigblock
All for today, Port-O-Walls came in. Cut my self pretty good so my hand are useless. I will be back out monday to finish the passanger door and install the driveshaft. I have to tweak the steering rack because 1 universal joint is hitting the motor mount. I also have to chase down the turn signal issue and then do a shake down run. Once I leave the shop I will save $$ and get a new cowl and fenders, paint the truck and reinstall the glass.
Old 04-14-2012, 10:26 AM   #136
baggedbigblock
This blows, Since I have a lot of views they make you upgrade to photobucket Pro for $25 a year. I need to find a better way to share my pics. Any tips?
Old 04-14-2012, 04:19 PM   #137
McMurphy
McMurphy's Avatar
I just upload mine from my computer to the site.
Seems to work just fine.
I never trusted 3rd party photo storing sites since I read the fine print on Yahoo's old geocities, which said anything uploaded on geocities was then considered property of Yahoo and could be used in any way they saw fit.
Fine print like that makes me an edgy and untrusting fellow.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 04-16-2012, 10:52 AM   #138
baggedbigblock
got the photobucket account back up!
Old 04-16-2012, 03:06 PM   #139
McMurphy
McMurphy's Avatar
What are those for?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 04-16-2012, 04:38 PM   #140
baggedbigblock
Fake white walls
Old 04-16-2012, 11:00 PM   #141
baggedbigblock
Lots of little things. I welded and filled the holes in the bed. Fixed the binding universal joints that where binding on the steering rack. Finished all little odds and ends, added more grounds. Reprimed the truck. I forgot to take out the port-0-walls to install.
Brass knuckles mounted. Old radio template is being welded in tomorrow.
Fiances door panel is installed
Old 04-17-2012, 09:18 AM   #142
baggedbigblock
A better video
I love how the engine makes the camera go out of focus!
Old 04-17-2012, 06:02 PM   #143
chad64chevy
chad64chevy's Avatar
as many times as ive looked at your motor, i just realized you did the same engine setup as i was going to do on my truck; gilmer drive belt setup, intake, and valve covers, lol!! i thought you have a big block this whole time!!
chad64chevy is offline   Reply With Quote
Old 04-17-2012, 06:09 PM   #144
chad64chevy
did you get your billet smoothies yet??
Old 04-17-2012, 09:16 PM   #145
baggedbigblock
I picked the name before I got the truck. I was going to get a big block but I needed to spend $ in the right places. I will have this truck for life so I'll upgrade later. Big block and a weiland are definitely in the plans. I'd rather have a sbc, and bags, and rust repair if you know what I mean!
Old 04-17-2012, 10:00 PM   #146
McMurphy
McMurphy's Avatar
Ok the video was cool... nice FX with the camera unfocusing with the higher RPMs...
Wont be long now !!!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 04-18-2012, 07:46 AM   #147
coulter
coulter's Avatar
Nice!!!! glad to see you got ur pics fixed!!! i bet you were pumped to hear it run
keep up the good work ur getting really close!!!!!
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 04-18-2012, 09:38 PM   #148
baggedbigblock
Thanks man! Yours is making great progress I see. Nice interior!
Old 04-18-2012, 09:42 PM   #149
baggedbigblock
Thanks man, no special effects, the motor really shook the camera out of focus!
Old 04-18-2012, 10:36 PM   #150
baggedbigblock
my seat inspiration but in the factory bench with this leather and stitching with coarse white or red or black stitching, I cant pick!!
