07-31-2011, 06:27 PM | #126 |
Re: Mike's 66 swb dropmember build
I haven't worked on the truck in a while. Got some of the rust cut out of the floor. I have all the patch panels for it. I made a panel for above the floor pan and welded it in. This is my first attemt at welding. I didn't realize how much rust was in the cab till I tore it apart.
07-31-2011, 06:56 PM | #127 |
It will be worth it when your done.
08-01-2011, 12:51 AM | #128 |
chevy only
man anytime i think i can't take the heat in arizona i see you guys with the rust and think maybe i can , nice work this is going to be one very nice truck
CHEVY ONLY... Nothin Else ! |
08-01-2011, 07:07 AM | #129 |
Redneck Hillbilly
Coming along great, that's one clean build you've got going on.
08-01-2011, 10:43 AM | #130 |
Amazing what was hiding under that paint, but it will be rock solid when you are all done. Keep it up.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
08-01-2011, 11:17 AM | #131 |
Couple more questions.
What paint did you use to get the engine the same color as the body? Did you have to scuff up the grade 8 hardware to get the paint to stick? |
08-01-2011, 02:42 PM | #132 | |
08-01-2011, 07:38 PM | #133 |
Thanks for the encouragement guys. I've been putting this part of the build off for a while because welding is not my thing, but I am trying to teach myself. Biohazard, the paint on the engine is the same paint I used on the frame. I've painted other engines with regular paint and it seems to hold up ok. Yes, I just scuffed up the hardware.
08-07-2011, 06:49 PM | #134 |
Got a little more done. This is a lot harder than I thought it would be. I have most of the drivers side just tacked together. Time for a break, I'm going to the Goodguys show in Joliet this coming weekend and taking my Belair.
08-08-2011, 08:49 AM | #135 |
made in america
man you have some really nice toys! i have yet to learn about any body work but i have a question. right there where the to sections of floor meet why is does the front look like its hangin down further? i see the seam matches across the two of them. but not the bottom. two different companies make patch panels?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree 2004 corvette- lowered, borla, tuned. slow my old girl 1966 c10- 305v8, t-5 sold |
08-08-2011, 08:14 PM | #136 |
The patch panels are from LMC. You have to do a lot of trimming on these panels . Once I get the new rocker panel on I will trim the floor panels to fit the rocker.
08-08-2011, 10:40 PM | #137 |
made in america
ahhh i seeee. i suppose its better to have to much and need to cut then to not have enough.
08-31-2011, 10:33 PM | #138 | |
But Found Her 25yrs Later!
Good work!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-18-2011, 05:59 PM | #139 |
Well I finally got the floors done. What a pain. Now I need to weld up the holes in the firewall and clean up the bottom of the cab.
09-18-2011, 07:18 PM | #140 |
Needs a Big Block
Nice work!!!! you really got after it!!! lots attention to detail in your work , it looks really good especially for a guy whos just learning to weld!!!
this truck is gonna be awsome!!!
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
09-18-2011, 11:12 PM | #141 |
Nice job on the floor and rockers. Im almost ready to weld my rockers on also. I just ordered some por15 to try out on the bottom of my floor after the rockers are welded on.
69 chevelle malibu, 64 C-10 shortbed |
09-19-2011, 12:02 PM | #142 |
Wow, this truck is looking better and better!
09-24-2011, 10:25 AM | #143 |
Tot Roddin'
Lookin' good!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-25-2011, 03:23 PM | #144 |
PROJECT 7DEUCE
Truck is looking great love the color scheme.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-25-2011, 08:40 PM | #145 |
nice progress. floor looks great.
Doug Looking for a 67-72 short bed driver..... |
10-16-2011, 04:06 PM | #146 |
A little progress. Got the bottom of the cab cleaned up and primed.
10-16-2011, 08:44 PM | #147 |
Looking good man sweet combo cant wait too see more
10-30-2011, 08:04 PM | #148 |
coming alone nice
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
10-30-2011, 09:17 PM | #149 |
Nice build I'm in on watching this one I don't know how i have missed it
10-30-2011, 09:51 PM | #150 |
chevy runs deep
ttt
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
