Old 04-30-2011, 10:29 PM   #1
zackary027
zackary027's Avatar
Re: My 81 Step Side
well the spacer worked my truck no longer floods
zackary027 is offline   Reply With Quote
Old 05-02-2011, 07:20 PM   #2
zackary027
zackary027's Avatar
Re: My 81 Step Side
Old 05-02-2011, 09:12 PM   #3
87 chevy silverado
Re: My 81 Step Side
nice to see a grill and bumper on it ..... ur page kind looks like mine no one repleying trucks looking good
87 chevy silverado is offline   Reply With Quote
Old 05-02-2011, 09:26 PM   #4
spudz
spudz's Avatar
Re: My 81 Step Side
truck has came a long way! I like it! not so sure about the hood pins but all in all good work!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 05-02-2011, 10:19 PM   #5
chad64chevy
chad64chevy's Avatar
Re: My 81 Step Side
i know what you mean about no one replying over 150 views on my truck in the last week with one reply besides myself!! lol!! nice work getting it running!! you ever think of putting a newer burban grille in there?? i think those look bad a$$!!
chad64chevy is offline   Reply With Quote
Old 05-03-2011, 01:19 PM   #6
zackary027
zackary027's Avatar
Re: My 81 Step Side
hood pins are a must the hood got warped at some point and will not shut without them. cant afford a new hood right now. and yea i like the burb grills, just finding one and then putting out the dough
Old 05-03-2011, 05:31 PM   #7
87 chevy silverado
Re: My 81 Step Side
to bad ur so far away ur i would basically give you a hood
Old 05-03-2011, 06:43 PM   #8
zackary027
zackary027's Avatar
Re: My 81 Step Side
well dang that would be awesome
Old 05-03-2011, 06:45 PM   #9
87 chevy silverado
Re: My 81 Step Side
yea if only
Old 05-03-2011, 07:43 PM   #10
zackary027
zackary027's Avatar
Re: My 81 Step Side
got a set of leather buckets today they may be finding there way into my truk
Old 05-09-2011, 09:19 PM   #11
zackary027
zackary027's Avatar
Re: My 81 Step Side
so i started to block sand my truck today and found the drivers fender has had some work done before. they did a pretty good job but im going to have to go in and smooth it out a little bit.
Old 05-26-2011, 07:58 PM   #12
zackary027
zackary027's Avatar
Re: My 81 Step Side
so i started wire brushing my rockers and floor pan and have just about desided to bursh all the rust out use a rust remover then finish it off with some primer and undercoat. they arent really that bad i dont think it will be a problem. i may even lay a little fiberglass down just for extra security. any opinions ??
Old 05-29-2011, 09:10 PM   #13
zackary027
zackary027's Avatar
Re: My 81 Step Side
any suggestions on the rust? i dont think there is enough to warrant full rocker and floor pan replacement? will put some pics up tomorrow
Old 05-29-2011, 09:46 PM   #14
notyo_cheez
Cool Re: My 81 Step Side
Depends on the size of the holes, and if the rust hasn't spread to the cab's structural supports. Go for the fiberglass filler if it's all small holes. If you have never used fiberglass bondo before only mix small amounts that can be worked and applied within five minutes .
If you don't care about how it looks you can always get some tin and self-tappers and make a "hillbilly" patch. It won't earn you any bragging rights with your gearhead friends but it'll keep you dry. Rust is just a fact of life with an old truck, you will always have it.
notyo_cheez is offline   Reply With Quote
Old 05-29-2011, 09:55 PM   #15
zackary027
zackary027's Avatar
Re: My 81 Step Side
well there's only a few pin holes the rest is just pitted after i ground it with the wire brush yet still pretty solid. im not going to hillbilly it but i dont want to cut it up if i dont have too..
Old 05-29-2011, 10:02 PM   #16
notyo_cheez
The hillbilly fix was a joke, should have added an emoticon after it...
Go for the bondo. It will be a driver anyway, you shouldn't worry about losing points from a concours judge at the country club regatta...
This is the fix I made for my cab floor, used tin snips on a scrap piece of a roof section. Sanded and ground the edges smooth, two coats of primer and self-tappers. The hole was for a shifter and I got frustrated trying to get a welder to fix it for me.
Old 05-29-2011, 09:56 PM   #17
zackary027
zackary027's Avatar
Re: My 81 Step Side
?? i think you got the wrong thread lol
Old 06-14-2011, 07:50 PM   #18
zackary027
zackary027's Avatar
Re: My 81 Step Side
little work done
Old 06-15-2011, 09:12 PM   #19
zackary027
zackary027's Avatar
Re: My 81 Step Side
fail or no you tell me i plan on covering the metal frame with carpet. the frame is the existing seat with everything taken off. if it doesn't look right i will figure something else out. anyone ever tried this.
Old 06-16-2011, 03:46 PM   #20
notyo_cheez
If the seats will fit the frame it should work, but when moving it back and forward both seats will travel together. How will the seat belts work with that setup?
I would have reupholstered the bench seat and called it done, but that's just my opinion.
Old 06-16-2011, 03:20 PM   #21
83highsierra
83highsierra's Avatar
Re: My 81 Step Side
wow this truck looks awesome kuddos to you i just purchased a 83 high sierra stepside and the 4.1 L6 has a stuck valve im wanting to drop in a 350 i was wondering if you could give me some pointers on the swap ive never swapped a motor before so will it all line up or does it require alot of modification thanks in advance
83highsierra is offline   Reply With Quote
Old 06-16-2011, 03:41 PM   #22
notyo_cheez
You'll need the engine mounts for the 350, transmission bell housing should mate easily. You'll want a bigger radiator. Upgrade to a 80 or 100 amp alternator too. Recruit a friend or two to help you who have experience with installing engines, preferably one who has a hoist and stand they could lend you for the project unless you already have them.
Depending on your resources and level of commitment, here's a few things you want to think about:
1. Go with a crate engine. A rebuilt one will cost as much or more than a crate.
2. Save all your brackets, pulleys, etc. Clean them up and paint them.
3. Install new water pump, power steering pump, balancer, flex plate when you reassemble it. Use new hardware. If you opt for a rebuilt long block make sure the shop chases all the bolt holes, a crate will have nice, clean threads already ready to go.
4. Install a new fuel pump, and clear out your fuel lines. Drop the tank, get it flushed and reinstall it with a new sending unit. If the tank has rust in it, replace it with a new poly tank ($160 from J.C.Whitney).
5. If your budget allows for it drop the transmission and drive shaft, check your u-joints and have the transmission rebuilt. It won't be that much more work to do this once the engine is out.
There's a few things I'm probably forgetting that someone else will add as well, stay tuned.
Old 06-16-2011, 03:48 PM   #23
83highsierra
Re: My 81 Step Side
thanks i will definiteley stay tuned
Old 06-16-2011, 06:50 PM   #24
zackary027
zackary027's Avatar
Re: My 81 Step Side
the buckets will be fixed they will not move i told my wife she ticks me off every time she drives behind me she moves my seat. the only reason i didn't recover the seat is that i want a center console/arm prop
Old 06-16-2011, 07:42 PM   #25
notyo_cheez
I'm not too keen on using the old seat bottom to mount your buckets, and in the end I don't think you'll be happy with the result.
To do this right you'll need to be a little creative and handy with a welder. If you have a plasma cutter trace out the pattern of the bench seat bottom on a sheet of diamond plate steel, cut it and tack it to the bench sliding brackets. Grind the edges smooth and paint. Use your bench hardware to fasten it to the floor, drill out and use new hardware to bolt your buckets to that. Check for head clearance and remember to mount your seat belt buckles.
