Old 06-24-2011, 10:49 PM   #126
fredscarryall
fredscarryall's Avatar
Re: slamburban
put some 6an fitting on the mustang 2 pump and a trip to the hydraulic shop. i here you need to put a pressure reducer on the chevy power steering pump because fords dont have as much pressure as the chevys. some say if you dont run the reducer it will over steer.but i'm not sure
fredscarryall is offline   Reply With Quote
Old 06-24-2011, 10:52 PM   #127
fredscarryall
Re: slamburban
inner fenders and radiator support
Old 06-24-2011, 10:56 PM   #128
fredscarryall
Re: slamburban
i found a radiator support to front cross member set up that will work good with the gmc to chevy front end conversion at jim carter for $25
Old 06-24-2011, 11:03 PM   #129
fredscarryall
Re: slamburban
here's my rendition from a trip to the the hardware store and $8. i got a few different size springs to try and i will cut off the end of the bolts if they are to long after i get the front fenders and grill on, monday.
Old 06-24-2011, 11:59 PM   #130
oldman3
oldman3's Avatar
Re: slamburban
Looking better and better with each post, keep up the good work....Jim
oldman3 is offline   Reply With Quote
Old 06-27-2011, 11:55 PM   #131
fredscarryall
Re: slamburban
got the front fenders on today. still need to patina the roof ,fenders and hood
Old 06-27-2011, 11:57 PM   #132
fredscarryall
Re: slamburban
installed some stainless fender to firewall cross braces
Old 06-27-2011, 11:58 PM   #133
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: slamburban
How excited are you at this point? I have shown this to multiple buddies and the first thing everyone has said is "look at how detailed this build is" very slick!!
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-27-2011, 11:59 PM   #134
fredscarryall
Re: slamburban
now its getting exciting. there is a light at the end of the tunnel.i think i am going to actually be driving this by the end of july.i painted the steering column today. then i went to mock up the radiator and i didnt have enough room for a manual clutch fan.the superior radiator pre welded brackets fit terrible.so i took it to the radiator shop to get the brackets cut and rewelded. then get an aluminium shroud made and a hole cut for an electic fan.
Old 06-28-2011, 01:09 AM   #135
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
great progress!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-28-2011, 02:35 PM   #136
cajundragger
Re: slamburban
I didnt regulate my pump at first and had superman power steering and blew up a rack. so I reduced the pressure and now I have a real good feel to my steering and the current rack is doing well.
cajundragger is offline   Reply With Quote
Old 06-28-2011, 11:38 PM   #137
fredscarryall
Re: slamburban
where do you get a pressure regulator for the power steering. do you install it in the pump or does it go in the fitting in the line
Old 06-29-2011, 09:58 AM   #138
cajundragger
Re: slamburban
I got the one that had the washers you install in the pump.
Old 06-30-2011, 11:06 PM   #139
fredscarryall
Re: slamburban
i orded the washer kit from borgenson to reduce the pressure in the power steering. now i have to take the half the serpentine bracket system off to remove the pump from the suburban. so putting the rest of the front end together will have to wait till next week. i got the radiator back for the shop. fits really good and they did a nice job on the fan shroud.
Old 07-11-2011, 10:34 PM   #140
fredscarryall
Re: slamburban
got the lower grille support in. had to modify it a little for the radiator petcock
Old 07-11-2011, 10:37 PM   #141
fredscarryall
Re: slamburban
installed the grille,led turn signals and latching plate. also got the cowl vent and wiper motor in.
Old 07-11-2011, 10:57 PM   #142
99 to Life
99 to Life's Avatar
Re: slamburban
looking great, it's gonna be a real eye catcher for sure.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-11-2011, 11:38 PM   #143
iehotrod
iehotrod's Avatar
Re: slamburban
Coming along good. Big fan of that grill, I really dig the way look with fresh clean chrome.
iehotrod is offline   Reply With Quote
Old 07-12-2011, 11:23 PM   #144
fredscarryall
Re: slamburban
got the front bumper,bumper filler and headlight buckets in. also got the wiper motor and linkage in. tomorrow the hood ,fog lights and steering column go in and i start figuring out where to install the switches in the dash. then hopefully by the end of the week the plywood floor will be in and the back inner fender will get tacked on. also figured out why the brakes wouldnt bleed.sometimes it the simpliest thing. the calipers where on the wrong sides.so the bleeder where on the bottom instead of on the top. i dont know which is worse. taking 6 hours to unsuccessfully try to bleed the brakes or having a motorcycle guy walk up and instantly tell you whats wrong.
Old 07-13-2011, 12:17 AM   #145
tantrumpipeline
Re: slamburban
looks great as always the quality of this build is great, don't feel bad about the brakes I just installed 4 or 8 pistons backwards the other day and spent hours diagnosing with stock marked pistons even Can't wait to see a video of her cruising
20 Duramax tow pig
52 short project
Old 07-19-2011, 11:34 PM   #146
fredscarryall
Re: slamburban
got the head lights, fog lights and wood floor in.also got all the vital fluid lines hooked up and filled.
Old 07-19-2011, 11:41 PM   #147
fredscarryall
Re: slamburban
had to raise the floor in the back 4 inches to fit the irs. desided to make a small trunk in the very back with access for the air managment and rear battery. with a lid that hinges.
Old 07-19-2011, 11:43 PM   #148
fredscarryall
Re: slamburban
welded up some holes in the dash, so i can get it ready to paint
Old 07-19-2011, 11:54 PM   #149
tantrumpipeline
Re: slamburban
big update, looks good, the rear copartment is a great idea, master metal and wood fabrication
20 Duramax tow pig
52 short project
Old 07-20-2011, 12:17 AM   #150
VA72C10
VA72C10
VA72C10's Avatar
Re: slamburban
Looking really good!!!
