Old 02-06-2012, 06:16 PM   #126
drivea55
drivea55's Avatar
Re: My Build - 1955 2nd Series Short Bed Stepside
Cool!
Its always nice to spend money on the truck.
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 02-13-2012, 02:04 AM   #127
Maximus
Maximus's Avatar
Well I had a couple hours during the weekend that I was able to dedicate to the truck, so I took the opportunity to install my new Hotchkis front lowering springs for my "Firebird".
I'd be lying if I didn't say I was extatic with the result. Not only with the drop but the handling, I also bought new bushings and installed the 1 1/4" sway bar. WHAT A DIFFERENCE!!
The original springs were horribly tired, the entire truck swayed in turns. Now, almost ZERO body roll between the new stiff springs and sway bar additions. I can honestly say it turns/handles like the '78 Formula Firebird that the subframe originated from.
simply awesome.
the overall drop after the springs was almost exactly 1.5", making the truck ALMOST dead level, making me very happy. Here are a few pics
BEFORE SPRINGS:
AFTER SPRINGS:
Install photos:
Before measurement:
After measurement:
Maximus is offline   Reply With Quote
Old 02-13-2012, 02:09 AM   #128
drivea55
drivea55's Avatar
Very nice dude!
that made a heck of a difference!!!!!!!!!!!
current project;
Old 02-13-2012, 02:11 AM   #129
drivea55
drivea55's Avatar
oh BTW,
You jinxed me!... joking of course.
After our chat about springs or drop spindles, I noticed rub marks on the inner front rims.
I had to indeed trim the lower control arm. GM made these way too big anyways...
thanks for the heads up!
current project;
Old 02-13-2012, 02:55 AM   #130
Maximus
Maximus's Avatar
Originally Posted by drivea55 View Post
oh BTW,
Ahh man that sucks! Sorry to hear about the interference! at lest you caught on to it before a serious problem came up!
Old 02-13-2012, 03:38 AM   #131
drivea55
drivea55's Avatar
I thank you for that!
you bringing it up helped me figure out what was going on.
funny 16" rims too... ah well all is good.
back to your build!
lookin good!!!!!!!!!!!!!!
current project;
Old 02-13-2012, 09:53 AM   #132
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-14-2012, 09:25 PM   #133
Maximus
Maximus's Avatar
Got my very own box with a heart on it today!!!!
and to sound a little less girly, it was labeled Hooker.
Headers that is.
I hate spending money, but not as much as I like getting new parts!!
My cracked exhaust manifold/MAJOR exhaust leak on the drivers side will no longer be an issue of mine after the weekend if all goes well. The headers are just the solution, as the long tubes will set me up an easy strait shot to install the rest of the exhaust. I might not get the mufflers on this weekend, but sure hope to get the manifolds off and these bad boys on!
Took a photo of how crammed the poor inner-exhaust ports are on these pontiac heads...
Old 02-15-2012, 12:16 AM   #134
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
Old 02-15-2012, 02:34 AM   #135
drivea55
drivea55's Avatar
Woo Hoo!
new parts!!!
current project;
Old 02-15-2012, 02:03 PM   #136
oldcouple
oldcouple's Avatar
Save the side of that box for your wall art.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 02-27-2012, 12:45 AM   #137
Maximus
Maximus's Avatar
well, today was a case of taking three steps forward, and one step backwards...
after removing the starter, clutch linkage and oil filter assembly off my pontiac engine, I forced the headers into position and started the tedious task of bolting the headers on. after slowly getting each bolt in, I put the starter back in, only to find my clutch linkage is going to interfear with the long tube header. I will spend a few days thinking about how I will build a new bracket to connect the clutch fork to the pedal fulcrum, it shouldnt be very difficult its just frustrating because it was all woring fine before the interfearance by the headers...
I am also waiting for my oil filter housing gasket, yay for my odd-ball pontiac having speacial order parts hah... $2 gasket... but its gonna take 3 days to show up...
anyways, here are some bad quality photos of the headers in position.
Old 02-27-2012, 01:15 AM   #138
Kim57
Kim57's Avatar
Looks like a tight fit.
Good luck on getting it all to work.
Kim
My build thread
Old 02-27-2012, 01:22 AM   #139
Maximus
Maximus's Avatar
man, it was a bear getting the headers up into position...
and thanks! ill take all the luck I can get haha...
Old 03-09-2012, 07:50 PM   #140
Maximus
Maximus's Avatar
Haven't had a ton of time in the last few weeks to work on the truck, but did manage to get my clutch issue resolved. After installing headers, my clutch fork pivot rod went forward, and strait into my header. Instead of hacking up my OEM parts, i ordered repop rods to modify.
After chopping off the end of the rod, I had a friend weld it back together rotated 90 degrees and at a camber similar to the original, and then shortened the second rod so that it would compensate for the angle pivot rod now facing the rear of the truck instead of the front of the truck.
When all was said and done, it clears the headers! I dont have an installed photo because it was dark, but here are the modified brackets to make my clutch work again...
Old 03-09-2012, 09:13 PM   #141
Kim57
Kim57's Avatar
Necessity is the mother of invention. Nice job.
Kim
My build thread
Old 03-12-2012, 11:59 AM   #142
Maximus
Maximus's Avatar
To anyone who cares, here is a photo of the clutch linkage installed. Works great, simple and effective!
Only other thing i did this weekend is tweek the timing and carb adjustments, now I am waiting on exhaust parts to get this thing quiet enough to drive again hah...
A Side note!! Anyone using the original style clutch linkage, and buys a reproduction elbow that bolts to the fork, the tabs that hold the rod on the elbow are not tall enough to keep the rod on, I had to weld bumps on the tabs to make them taller, and it works perfect. My original elbow never had this problem, but I didnt want to hack up the original part just in case, so i bought the Repo part and found it needed a little work... You can see in the photos of the elbow that there are welds on each bump.
Old 03-23-2012, 08:17 AM   #143
dug224
dug224's Avatar
simply awesome.
BEFORE SPRINGS:
AFTER SPRINGS:
Install photos:
Before measurement:
After measurement:
I really like what I see. This will be a great help. Thanks...
dug224 is offline   Reply With Quote
Old 03-28-2012, 01:33 PM   #144
Maximus
Maximus's Avatar
So... I haven't made a ton of progress lately, been waiting on parts and been busy with life... along with bad weather.
A break in the weather allowed me to sandblast and put some rust converting primers on my heater housing/motor probably just going to paint the parts satin black and if my heater is done getting recored by friday I might be able to put the heater together this weekend. Someone welded the original holes for the heater up on my firewall so ill have to redrill.
Anyone know what size spacers are used on the inside studs for the heater mounting?
Also, I know a rubber band is used for the blower-to-heater box, is the same used for the cowl-to-blower?
Blower still works!
I blasted and primered the box too but for some reason don't have photos. Ill get some up when I paint everything...
Old 03-28-2012, 08:06 PM   #145
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 03-28-2012, 08:18 PM   #146
lowdownstar
big guy
lowdownstar's Avatar
You did a really nice paint job!
Ray
lowdownstar is offline   Reply With Quote
Old 03-28-2012, 11:32 PM   #147
Maximus
Maximus's Avatar
Thanks! The paint in the previous heater photos were primers, today I finally had a sunny afternoon and was able to put a few coats of rattle can paint/clear coat on the heater parts. At first I started with a low gloss, but the interior of my truck was much too glossy for it, and it stood out very bad so I re-shot the parts in gloss and then clear coated them.
Because it was only a dollar more per can, i went total overkill and used 500 degree engine paint...
The heater core leaked alot in a past life causing alot of rust on the box, which is primarily why I chose to put 5 layers of paint and a clear coat on the box. No more rust...
Photos of the painted pieces... will probably upload some more after I get my core and assemble the box
Old 04-09-2012, 12:43 PM   #148
Maximus
Maximus's Avatar
Not alot of progress, no photos to show, just bolted my mufflers on this weekend and drove the truck around, sounds 1000% better without the exhaust leak, and with the engine timing better set (was WAY too retarded last time i drove it) being able to rev over 3000rpm without the engine sounding like it was going to explode was great!
older flowmaster mufflers off a friends old mustang sound mean behind the 400 pontiac! (I think they are the standard 40-series)
As soon as I get my heater core from the radiator shop though I'll get some photos of the box assembled.
Old 04-26-2012, 11:50 AM   #149
Maximus
Maximus's Avatar
Work is continuing to overpower my time, however I was able to install my new stereo. I went with the Retrosound Apache radio and am happy with it. It won't be easy to navigate through all my folders of music on my usb drive but it fits the stock opening and plays either SD cards or USB Thumb drives so thats all i need. I don't have speakers installed yet but when I figure out what I am doing with those ill post some photos
Old 04-26-2012, 01:33 PM   #150
_Ogre
_Ogre's Avatar
my stereo has an usb plug up front
the thought of a 2'' thumb drive sticking out scared me
until i found these short ones... newegg.com
skipping cd/dvd are a thing of my past
no folders, just 16gb of random rock and roll
shop air compressor timer
