#126 |
Re: New member with barn find
I bought a repop at Carlisle. I used a brillo pad on my original one and it came out pretty nice. Hopefully I'll be done by spring but it's hard working in the cold, the garage has heat but I have to go outside to paint, weld or grind.
#127 |
![]() Join Date: Mar 2013
That thing looks great!!!
#128 |
![]() Join Date: May 2006
John, nice work! Just remembered to check for tinted glass....seems like i have both sides,lmk
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#129 |
Thanks Jim, Let me know if ya need a hand when it's start up time, looks like you're getting close.
#130 |
One could always use an extra set, thanks for the offer....
#131 |
I've been working on the dash and everything behind it, so far so good, I even got the light, wipers and blower fan working. Now I can start on the fuel tank and lines but I still have to order brake lines.
#132 |
Some more.
#133 |
Looking good!
#134 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
you will be done and driving before you know it....Looking real good
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#135 |
X3 John
#136 |
With all the snow we are getting here I'm getting a lot done. I was able to get the windshield installed. What a fun job that was, I used two suction cups from Harbor frieght and some rope. The first two atempts I used the glass wheatherstrip from LMC but the chrome trim kept falling out, I couldn't keep it locked in. when that happens you have to start over. I ordered the weatherstrip from http://precisionrestorationparts.com/ and I had it installed in an hour, there weatherstrip would hold the trim in place while you work the seal over the body lip.
Also got the dash 99% done just need a new turn signal cam, I found out the one I have was cracked. ![]() ![]() ![]() ![]() ![]() ![]()
#137 |
Nice job!
#138 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Strong work - looks great!!! Very nice attention to detail. Just a thought - consider adding a stainless cowl screen (from LMC) to keep out the leaves and other debris. I added one (painted black) to each of my trucks as I plan to drive some forested country roads when the snow melts.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
#139 |
I'm happy, I got the engine back today, I had them bump it up to about 315 hp. I have to flip the drivers side valve covers for the oil tupe and move the crossmember forward because of the 700r4 that I installed last week. I also got all the brake lines, fuel lines and the gas tank complete. I just got done making plates for the underside of the roll bar so I can bolt it down, I'll have to fish the front inner plate through the rocker box and pull it through the floor, I welded the bolts to the plate, It should be fun. Oh and the glove box door clears the roll bar about a 1/2" or so. I hope to have it on the road by late spring or early summer. Here's some pics.
72 CST 4x4 Blazer, 1 ton 70 SS Chevelle, L78, 396 Everytime someone calls your Blazer a Bronco, God kills a kitten. |
#140 |
VA72C10
![]() Join Date: Mar 2008
Looking good!!! Should be fun!
#141 |
Nice attention to detail, well done John. If you are going to use the oem spark plug wire looms, wait till you try to mount up the rear ones by the distri., youll hang by your knees from the ceiling to reach the bolts. I used studs to make it a little more manageable
#142 |
Thanks Jim, That's a good idea. I have a set of headers so I'll guess I'll have to use some aftermarket ones.
#143 |
No problem, how does your shop always stay so clean, mine always looks like a hurricane went through......im trying to do better though
#144 |
![]() Join Date: Mar 2009
WOW! Haven't checked in for a while. Your project progressed fast and came out awesome! Love the color and great job on all the little details. Looking forward to seeing it done. Will it still fit in the garage with 35s though? That would stink. Is it going to be done for the summer? Good luck!
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
#145 |
![]() Join Date: Apr 2007
Just went through the entire thread, great work on the blazer!
#146 | ||
I had the day off today and could'nt wait to drop the engine in. The poly engine and trans mounts are a PITA to line up, I'll try fighting with them over the weekend. But for now it's in.
#147 |
Cool, getting closer, take video of it running when you get that far. Nice to see more getting done.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#148 |
Looks great!
#149 |
Awesome work
Looks great |
#150 |
| Bookmarks |
