Old 10-06-2012, 08:54 PM   #126
CRGRS 66
CRGRS 66's Avatar
Re: Farmers big block
how did I not see this thread before, very, very nice work, like the mods, like the tail lights, like, like, like... nice touch on the memorial to your FIL
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-10-2012, 08:48 PM   #127
66farmer
66farmer's Avatar
Thanks for compliments.
Got the buddy bucket consol ready for the upholsterer. Built a box for the stereo and welded it in the bottom and painted the inside with undercoating.
Another thing finshed.
66farmer is offline   Reply With Quote
Old 10-28-2012, 09:07 PM   #128
66farmer
66farmer's Avatar
It's raining were in the NW and I have all farming duties wrapped up. So I put the 66 back in the shop to "GET HER DOON".
Got the steering column copleted.
Mounted the gas pedal and cable. Installed the brake pedal and arm. modify the brake pedal arm so it isn't so high.
Finished the trans shifter and started installing the Dynomat
Old 11-02-2012, 07:20 PM   #129
66farmer
66farmer's Avatar
Got the Dynamat installed what a puzzel I was only able to lay (2) full sheets the rest I had to make a template cut and lay. After I do the doors I will have used two boxs . Installed the firewall pad I bought from LMC didn't fit but after a little cutting I got it to work.
Old 11-03-2012, 01:58 AM   #130
Iron-Butt
454 club
Iron-Butt's Avatar
nice build
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 11-25-2012, 12:20 PM   #131
66farmer
66farmer's Avatar
Talking Re: Farmers big block
It might not look like it, but I have been putting alot of hours in working on the truck.
1. finished vent window, rebuilt and installed.
2. Kick panel vents gave me some grief. The seals that I installed from LMC are thinner and not as ridged as stock. So the vent in the closed position is flatter. Which means the arms had to be bent to latch right.
3. Installed the electric window mounts and motor's PITA.
4. Installed the door seals (drivers side twice).
5. Finished the brakes.
6. I spent alot of time welding firewall holes. Know I have to redrill them.
7. Built and installed mounting brackets for fuse block and MSD box.
8. Rebuilt heater controller and installed.
The next thing to do is finish the passanger door and install the front end.
Old 11-25-2012, 03:35 PM   #132
McMurphy
McMurphy's Avatar
Modifying those fresh air vents to open and close with a cable is super easy.
I did it with mine. Even with figuring it all out, both took less than a day to adapt.
Here on this page (24) of my build:
http://67-72chevytrucks.com/vboard/s...487100&page=24
and there is a short video of the action at the bottom of the next page.
May be an idea for you.....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 11-26-2012, 10:12 AM   #133
66farmer
66farmer's Avatar
Thanks for that info, right know I,m just trying to get it put together to get it to the upholster he,s waiting on me.
Old 11-26-2012, 09:26 PM   #134
pdxhall
pdxhall's Avatar
Looking great! You'll be on the road in no time.
pdxhall is offline   Reply With Quote
Old 11-26-2012, 10:21 PM   #135
99-LS1-SS
99-LS1-SS's Avatar
Very good looking truck!
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 12-05-2012, 10:38 AM   #136
66farmer
66farmer's Avatar
Well it,s Christmas tree season and are farm is a U-Cut so in between helping the U-Cutters I,m working on the truck. Got a few more things doon.
1. The doors are finished (thank god for that)
2. The core support and inter fenders are on (I hope for the last time)
3. Made the lines for the Hydro boost
Next thing start wiring
Old 12-05-2012, 11:45 PM   #137
burlapen
burlapen's Avatar
Great build!! The pickup is looking good. I have a question regarding your steering setup.
I am using 72 suspension on my 63 C10. When I went to mount the steering cross link, I realized the bracket that holds the idler arm to the frame is completely different between the two and there are no provisions for the 72 mount on the 63 frame. I cant think of a way to properly locate it to make new holes. How did you tackle this if at all? Thanks.
63 Chevy C-10
My build thread
burlapen is offline   Reply With Quote
Old 12-06-2012, 09:57 PM   #138
pdxhall
pdxhall's Avatar
Truck's lookiing great, man! You've been making a lot of progress. I'll bet you're just itchin' to get that thing on the road. Keep it up!
Old 12-07-2012, 11:33 AM   #139
66farmer
66farmer's Avatar
I just leveled the cross link and drilled new holes for the idler arm.
The guy you need to talk to about this is Captainfab he has helped a lot of use with steering problems.
Old 12-07-2012, 11:39 AM   #140
66farmer
66farmer's Avatar
Thanks, I hope I can drive her on the trailer in next two weeks the upholster is waiting.
Old 01-14-2013, 11:42 AM   #141
66farmer
66farmer's Avatar
Well finally the truck is gone.
Last Friday I drove her down the road and put her on the trailer to go to the upholster.
There's things that need more work like the steering at idle there's no power not sure about that.
The upholster said that I should have it back the first of March.
Old 01-14-2013, 01:19 PM   #142
McMurphy
McMurphy's Avatar
I am pretty sure that no steering at idle means the power steering pump is on its last leg if used, defective if new....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 01-14-2013, 01:41 PM   #143
flashed
Nice build ,got a question about your Buddy Console . Can you give more pics and details on how you mounted the radio and how you plan to route the wiring ? What you have done is exactly what I want to do with mine .
Thanks John
flashed is offline   Reply With Quote
Old 01-15-2013, 10:48 AM   #144
66farmer
66farmer's Avatar
This is the second rebuilt steering pump I got from Napa. The first one spit fluid out of the reservoir and now this one. Have had other problems with new parts. Quick Fuel carb does not adjust and alternator gets real hot, had to send them back.
What's the deal, am I getting all the reject parts. Oh, one more thing... don't buy Russell teflon lined braided steering hose... there a ***** to keep from leaking.
Old 01-15-2013, 10:56 AM   #145
66farmer
66farmer's Avatar
Thanks John
John
I cut a channel in the dynomat from under the dash to under the seat, layed the wires in, used tape to hold them in place. I will take some more pictures and post them.
Old 01-15-2013, 12:35 PM   #146
McMurphy
McMurphy's Avatar
Logically speaking the only other element that could be at fault would be your steering gear box.
I confess I have never heard of one of those going bad, nor could I imagineany way to test it.
Perhaps someone else can chime in with greater info for you....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 02-01-2013, 09:25 PM   #147
66farmer
66farmer's Avatar
I picked up the seats today and they look great. The upholsterer is doing a great job and is now working on a door panel. I started working on the bed wood going with maple, purple heart and walnut inlay.
Old 02-01-2013, 10:16 PM   #148
Bomp
Bomp's Avatar
If your bed turns out half as good as seat you definitely have a show winning truck.
Bomp is offline   Reply With Quote
Old 02-02-2013, 04:49 AM   #149
pdxhall
pdxhall's Avatar
The buddy buckets look awsome. I'm looking forward to seeing your bed.
Old 02-02-2013, 06:01 AM   #150
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Beautiful work so far. Can't wait to see the wed wood.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
