05-31-2012, 12:39 AM | #126 | |
Still plays with trucks
Re: Attempt/Mistake #2
Your headers are tiny for that big of an engine and may be the reason it falls on its face at such a low RPM, it just can't breathe. A 2" tube is a little small for that engine so look for a set of 2-1/8" tube headers. It would probably be happy with 2-1/4" tubes like we run on the 565 with the combination you have as well if you find a good deal on a set. 3" duals should be OK as long as the bends are mandrel bends and not crush type. Typical muffler shop crush type hydraulic bends in a 3" pipe will restrict its flow down to that of a 2-1/2" pipe or smaller depending upon the bend radius. Way too small for your engine. The rest of your package sounds like a good parts match for the cubes. I think most of your problem is in the exhaust side. You could also be getting some valve float from too little valve spring pressure if the wrong springs were used. Check your seat and open pressure to make sure they match up with what Comp says the cam needs.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
05-31-2012, 09:01 AM | #127 |
The entire valvetrain is from Comp Cams. I bought the entire matched roller cam, lifters, springs, keepers, timing chain, thrust button that they recommended and they were assembled at Competion Products. I had wondered about the header size too. I will try the new to me Hookers that I just got since I have them and see if I notice any improvement and will keep eyes out for an even bigger set. Would compression make a difference as to necessary header size? Is it an alcohol dragster or gas. If you have really high compression like 14:1 or so then does that make you need bigger headers? I wonder if I could fit big tube headers in to the frame ?
I found this article which is quite interesting!! http://www.hotrod.com/techarticles/e...s/viewall.html
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! Last edited by El Campo; 05-31-2012 at 11:06 AM. |
05-31-2012, 09:27 AM | #128 |
TchncnDen interesting points you bring up. Sam Walton once said that "The customer is the only boss, if he goes away we all do". Now a lot of people may hate on Walmart and the corporation he built BUT he did come from nothing and became the head of the (at one time) wealthiest family on earth if IIRC. Now I agree that there are many ways to skin a cat many times but there are basic fundamentals that are absolutes. Clean, bare, grease and dirt free metal is like clean air and fresh water to us humans. We can all agree that it is superior to anything else. And I may not know a lot about painting (I don't) but consider another parable. A few years ago a medical student from Harvard (I think) who was historically brilliant attempted to hike the Grand Canyon going on information that she "knew". An avid runner she had ran and finished the Boston Marathon and numerous other marathons. BUT she DIED from dehydration because she did not do proper preparation. On the other hand my brothers and I had no prior experience, could never run a marathon, my brother and I both dropped out of high school and we have hiked it 3 times without incident. This was all because we did not go on our own thinking and ideas, we followed advice from others, we did PROPER PREPARATION. My beef with the shop is not so much about the materials as it is about the preparation and execution (which we all know is 90% of a paint job). And just because I am a nurse instead of a painter does not automatically erase all of my credibility. I have a thirst for learning still that I feel is lacking in the shop that did it. And THAT makes a big difference in improving and getting better results. Ever read the book "Who Moved My Cheese"? Obviously there are many many people that would do a better job than I ever will. But we will keep striving to be better and never being satisfied with stasis. Just my opinion and why I do things the way I do.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! Last edited by El Campo; 05-31-2012 at 10:47 AM. |
05-31-2012, 11:41 PM | #129 | |
06-01-2012, 01:59 AM | #130 | |
There is quite a bit of room for bigger tubes in our trucks. You will most likely need square body clam shell style motor mounts to clear the front tubes but this will open up the use of more headers intended for square bodies that may not be designed for 67-72 mounts. This pic is of the clearance on my 69 with 1-3/4" tubes and square body motor mounts. Lots of room for more tube size if they are routed right.
06-01-2012, 07:40 AM | #131 |
Boxed frame is a PITA though and wouldn't do it again! I have those clam style mounts already. There is a bunch of room by the mounts but gets close to frame rail. There is some room though. I really want long tube headers but I do not want to pay to get custom ones made. Hooker has a 2 inch primary for our trucks but nothing bigger. If I understand it the collector length is important too so my next question is would it be better to have a 2 inch primary but full length or going to some Chevelle headers which can get 2 1/4 but are a lot shorter?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
06-01-2012, 10:48 PM | #132 | |
I have a set of the standard Hooker Competition series 2" tube headers that fit a 68-72 Chevelle and 70-81 Camaro that I was going to try to fit to my 69 stepside. I will see if they clear and let you know. It might open up some options for more headers than could fit with little or no mods.
06-02-2012, 12:52 AM | #133 |
Nice work on the frame. I'm happy to see that others have the same OCD issues I have. Going to be a nice truck when your done.
1972 GMC (PROJECT LONG OVERDUE) 1998 SWB 4WD |
06-07-2012, 11:20 PM | #134 |
It's been a week since you last posted, did you get it all back together yet
project: "my happy mess" |
06-20-2012, 10:31 PM | #135 |
Finally had a chance to work on truck again. Spent a BUNCH of time spraying just these 27 parts. I see now why people use rattle cans because it sure is easier than a spray gun. (especially when your small gun is a POS from Harbor Freight) Got so infuriated with it I contemplated buying an Iwata. It dripped paint over my perfectly painted sway bar because it sporadically ejaculated paint from various orfices where it was not supposed to. Now the parts all are satisfactory though after wet sanding etc.
06-20-2012, 10:35 PM | #136 |
The trailing arms in the picture above as well as these wheels will be for sale. I finally figured out how to get my wheels polished. PITA!!!! Turned out well though I think. Anyone want some 20x10s????
06-20-2012, 11:32 PM | #137 |
wow those rockers look really good in there and nice job on the black pieces some stuff just can't get covered by powdercoating (shocks) great idea
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
06-20-2012, 11:35 PM | #138 |
jmdero I see you looking at this thread. Without you the wheels would never look like this. Thanks dude!!! The shocks are KYB but of course the crap coating from the factory rusted immediately. Springs are SOOO hard to paint!!! I will definitely powdercoat them in the future.
06-21-2012, 08:06 AM | #139 | |
06-21-2012, 08:17 AM | #140 |
Suspension parts look great all painted up, nice job
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-21-2012, 10:29 AM | #141 |
I may be interested in the wheels.. pm sent
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
06-21-2012, 11:14 AM | #142 |
Looking good man ! I have a paint gun that did that, had to buy a new lid so it wouldnt drip.
Whats the secret on polishing the wheels? My billets are pretty scuzzy and I need to get them polished back up someday soon. Later
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
06-21-2012, 11:25 PM | #143 | |
06-21-2012, 11:47 PM | #144 |
67cheby
Mic work , great polishing job
Posted via Mobile Device |
06-22-2012, 09:34 AM | #145 |
Look at this link for how to do the wheels. http://67-72chevytrucks.com/vboard/s...d.php?t=485766 I had real hell trying to get them polished until jmdero clued me in how to do it. First I hit them with Allbrite wire wheel acid for one minute and then washed off very well (found out that if you have a brush and agitate the suds on the wheel during this one minute it works much better yet even). I had some nasty deep pits on them and had to end up wetsanding the hoops (in some spots all the way down to 400 grit) and then working up to 2000. Then I used some Master Formula (brand) jewelers rouge that I got at the Rot biker rally a few weeks ago and a cotton polishing wheel that cost 3 dollars at HF on my 90 degree die grinder. This is how they turned out. Takes time but the results speak for themselves. Then I sealed them with Master Formula sealer which they say will keep them oxidation free even in Texas for 6 months. I am going to do the billet gauge bezel on Monday and will post step by step pictures of it. It is brushed aluminum but am going to polish it to match the wheels as I am not crazy about the brushed look.
06-22-2012, 09:40 AM | #146 |
TechncDan yea the HF gun actually sprayed pretty well and I will use it again for small parts. I liked it a lot better than the devilBiss Finishline that I also tried on them. Sure would like to have a little better quality touch up gun though but you are correct that a 600 dollar gun is probably unnecessary haha. Unfortunately for me I lack significantly in that 98% department!
06-24-2012, 09:34 AM | #147 |
I had a great uncle who lived in El Camo for years. He was a diesel mechanic for Halliburton before he retired. His name was Raymond Williams. He could set up new gears in a rear end in about an hour and made everything look easy. Unfortunately he passed away last year. My great aunt still lives there, though. BTW, I would like more info on using the Sanden compressor in the stock mounts.
06-24-2012, 10:13 AM | #148 |
WIDESIDE72 I will be happy to provide you with the info when I get to that point. Might even make an extra set of brackets for it that I would sell for a few bucks if you are interested while I am at it.
06-24-2012, 12:53 PM | #149 |
Is this going to be a show only truck? Just curious you are very meticulous and it shows. That is going to be one beautiful, clean truck that will outlast all of us. I am at awe with the amount of work you have put into the frame. Good Luck.
06-24-2012, 01:08 PM | #150 |
Nope. It will never actually be IN a show. Except maybe local car shows. Its going to be a driver. I am planning on driving the wheels off of it. I just did a crappy job the first go around and the bitterness of that is still strong inside me. I learned the hard way that those grade 8 bolts that everyone puts in uncoated for example WILL rust when you are close to the coast. So this is why I am probably too OCD. Thanks for looking.
