Old 06-03-2012, 11:38 PM   #126
Low Elco
Re: Boppa's old yeller truck
Ok, got some work done this weekend, although it doesn't seem like it. (Don't you hate that stage?) Anyway, we'll start Friday night. Got the floor flipped over and made up a new xmember over the gas tank out of leftovers. Cleaned out and redrilled spotweld holes in prep for welding. Welded GR. 8 clamp washers over the bed to frame bolt holes, as they were blown out. Sat.- Went junkyarding and desperately resisted a 700r4 in a Sub for my GMC. Cut a big section of frame out of a 68 Sub to fix ours. I think we got a section that's a pretty good match. We'll see. Cut a gas door out of a 91 Ranger and got the fill tube to match. Went and dragged the dr bedside out of the scrap pile. Cut it in half and mocked up the fit of the door. Cut the stuff out of the old xmember in the front that they don't provide in the new ones. (crush sleeves, holes for bed bolts, weld nuts for bed braces.) Today- weld city, baby! Put old stuff in the new xmember, rosette welded all the xmembers in, painted everything to match underneath with tractor enamel, tried to pull a surprise of cutting the stamped Chevrolet out of the old tailgate and welding it into the headgate, but hit a 1/4 inch of mud before I hit sparks. Oy! So much for that idea, now it'll be a wall hanging. Got rid of a bunch of scrap. Boppa is hip to new inner front fenders, thank God. That was gonna be the limit of my capabilities. Anyway, here's some pics.
A little side project-
The start of the crossmember repair-
What I made out of scrap-
The gas door mockup-
Boppa and Neighbor Jay Scrubbin the new stuff for the tractor enamel. The whole underside is now enamel black over the rust bullet. My repair in the foreground.
Low Elco is offline   Reply With Quote
Old 06-03-2012, 11:44 PM   #127
Low Elco
A few more pics-
The Kid clearancing the bed for the gas filler-
Yours Truly setting the rear crossmember-
Old Stuff in new crossmember-
New old frame chunk-
Mud! on tailgate-
Old 06-04-2012, 10:00 AM   #128
67cheby
67cheby
67cheby's Avatar
WOW....that is some great progress.....and some really bad use of filler !
67cheby is offline   Reply With Quote
Old 06-04-2012, 10:46 AM   #129
Low Elco
Thanks! Just got off the phone, bed parts are going to a pro blaster on wed AM, back same day for etch prime. Also may have another alternative for the fuel door, 05 chevy truck brother is making calls today. It might look like progress!
Old 06-04-2012, 10:13 PM   #130
litew8
litew8's Avatar
who put all that bondo on there?
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 06-04-2012, 10:27 PM   #131
Low Elco
Warn't me! Went out and cleaned up welds for a bit, and eyeballed the frame repair. I think it'll come out good.
Old 06-08-2012, 08:06 AM   #132
Low Elco
Ok, it's Friday. Got all the stuff blasted and etch primed. Did a weld test on the scrap frame, came out good. Got springs stripped and rear end dropped last night. Gonna start knocking rivets and welding in bracing In prep to cut the frame tonight. I have pics, try to post up tonight.
Old 06-09-2012, 12:11 AM   #133
Low Elco
Got the rivets out, cut the patch down, ran outta daylight. Gonna git dat azz tomorrow! This tub better start lookin like it's turnin a corner soon! Here's pics-
Ummm, yummy green blasted steel!
Fitup for the weld test-
Welds look sufficient-
The main rot we're after-
The passenger side had a bit too, tore it down as well.
Old 06-09-2012, 12:19 AM   #134
Low Elco
More pics, 'cause I know you love 'em! Heeeere we go!
Comparo of new and old frame- Not bad for shootin' blind, huh?
Rough fit up after trimming the fat-
Random shot of all the crap that fell out during tear out-
A bit more trimming, note bracing.
Final fit up, after notching to follow the curve in the rail better.
Hopefully lookin to get ta whackin tomorrow!
Old 06-10-2012, 12:20 AM   #135
Low Elco
BIG day today, got a lot done. Update with pics tomorrow!
Old 06-10-2012, 12:59 PM   #136
c10327
c10327's Avatar
it's a long process I know !!!! but when it's all done an you an the wife want to go out for a nice cruz it will be well worth the extra effort at least thats wht I have been telling myself these past couple weeks restoring my 70 C10 .. the top pic is how I bought the truck in feb of this year . looks good in the picture butttttt it was a cst truck an the guy before me filled all the molding holes with bondo !! uch since then it come along ways new rear bed an inner fenders new nose . I completely tore it apart .
c10327 is offline   Reply With Quote
Old 06-10-2012, 01:20 PM   #137
c10327
c10327's Avatar
couple more pic's .. my brother in law called it the mud rocket because it had so much bondo under the nice shinney black paint lol ... not no more a few Thousand $$ later most all new metal . the best part of the truck other than the 327 was that the frame is Rock solid .. to give you an Idea of the hack job the last guy did to this poor old Truck . the white stuff on the heater box is silicone , instead of buying a $20 gasket set , he packed it full of tub & tile silicone ... some of it was 1 inch thick . I hate doing thins half ass
Old 06-10-2012, 01:22 PM   #138
c10327
c10327's Avatar
1 more now that I figured out how to post pic's . dont mean to clog up your tread low elco just can appreciate the work you are doing .
Old 06-10-2012, 09:05 PM   #139
Low Elco
Looks good!
Old 06-10-2012, 09:39 PM   #140
Low Elco
OK, Saturday we got started early. Cut the frame out and got the new welded in. Cut out scab plates, welded them in. Cut out boxing plates, welded them in. Coated rusted frame sections with Rust Bullet. Coated exhaust with Rust Bullet. Bolted crossmember back in. Sunday, we Moved and extended the rear brake line and put the springs in and got the truck back on the ground. Spent the rest of the hot afternoon with the kids in the pool. Feels good to have some kinda progress. Here's the pics-
Dad and The Kid gettin 'er done!
Kid sez-it's good!
All welded in-
Scabbed and done!
Boppa and the Rust Bullet-
Old 06-10-2012, 09:43 PM   #141
Low Elco
Annnd, here's how it came out. Brake line mods were necessary because of 71 Sub rearend and brake line arrangement Barely made it as it was, and was being kept off the exhaust with zip ties. A move to the center fixed that. Here ya go-
Old 06-13-2012, 08:28 AM   #142
Low Elco
Busy busy- fuel line in, tank adapter found, tank mounts fabbed and painted, tank loosely bolted in, pickup/sender mocked up. Took pics, I'll post later.
Old 06-13-2012, 11:38 PM   #143
Low Elco
Been at it a bit here's some pics.
Jeep Tank final install-loosely
Name:  IMG_2532 (800x600).jpg
Mod on the Blazer Fuel pickup
Name:  IMG_2533 (800x600).jpg
Had a bit of a delay tonight-Someone wants to learn to weld! He did pretty good for his first time!
Name:  IMG_2536 (800x600).jpg
Mocked up-
Name:  IMG_2541 (800x600).jpg
Ready to slice and dice tomorrow!
Name:  IMG_2543 (800x600).jpg
Old 06-13-2012, 11:49 PM   #144
VA72C10
VA72C10
VA72C10's Avatar
Nice progress! And real good idea mocking up/trial fitting the fuel filler in the old bedside piece!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-14-2012, 12:18 AM   #145
Low Elco
Thanks! I was kinda nervous about the big hackeroo, then thought that'd give me a good start point. I highly recommend it.
Old 06-21-2012, 03:49 AM   #146
BruthaMan
US Army Veteran
BruthaMan's Avatar
Stopping by to see how things are coming a long. No rest for the weary, eh?!
Hope life is treating you well.
BruthaMan is offline   Reply With Quote
Old 06-21-2012, 06:54 AM   #147
Low Elco
Hey, thanks, doing good. Been trying hard and have a lot to report. Looking like bed assembly tonight. Fixin ta send front clip to the blaster, learned a lesson with the bed. Hopefully I'll get some of these pics uploaded soon. They say it's gonna get hot this weekend, but we're gonna try to keep it movin' along.
Old 06-22-2012, 11:28 AM   #148
Low Elco
Ok! I know! I need to download and update! Big night last night. A bunch of things came together and it looks good! Gonna be Rollin tonight!
Old 06-24-2012, 10:14 AM   #149
Low Elco
Ok, finally a real update. We had to send the truck to the frame shop on Mon. because if you look at the pics from the rear, somein ain't right. Turned out the driver's rail was perfect, the pass rail was a bit wacky. but they got it all fixed. Then, I got the bed floor out into the driveway and used the 'ol sledge method to straighten it up, which worked better than expected! In the BIG news, Uncle Matt, who production manages the bodyshop where this miasma will be painted, came out with Boppa on Thursday and we got the bed assembled! YAAAY! Then Friday night I got all the under braces fabricated and installed, and started the mudwork. Saturday we got the mudwork finished, sides welded, the shop cleaned, the last 2 holes done for the bed floor and bolted in , bed pulled and back on the cart, seam sealer cut back, tailgate metalworked for fit, Whole mess scrubbed down and primed, blocked with 150, and reprimed. Came out pretty nice! We're all pretty stoked.
Name:  IMG_2545 (800x600).jpg
Name:  IMG_2549 (800x600).jpg
Name:  IMG_2550 (800x600).jpg
Name:  IMG_2557 (800x600).jpg
Name:  IMG_2560 (800x600).jpg
Old 06-24-2012, 01:51 PM   #150
Low Elco
Name:  IMG_2563 (800x600).jpg
Name:  IMG_2566 (800x600).jpg
