Old 02-10-2012, 08:35 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Camshafts..
OK so dont bother cleaning cam/lifters?
I didnt clean my cam im using now installed right out of box.
John
1999 Toyota Tacoma 4x4
Old 02-10-2012, 09:46 PM   #2
litew8
litew8's Avatar
Re: Camshafts..
Basic instruction -
"Before installing the camshaft and lifters, wash them thoroughly in clean mineral spirits to remove the rust preventative that is placed on the cam before shipping."
I'd imagine it's to clean - so you don't contaminate the oil.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-10-2012, 09:57 PM   #3
oldblue1968chevy
Re: Camshafts..
Huh? litew8?
So wash it in mineral spirits or no lol
John
Old 02-10-2012, 10:00 PM   #4
litew8
litew8's Avatar
Re: Camshafts..
Yes (just wipe clean). Dry good after - air hose (water free!) if you have one.
It's probably not THAT big of a deal (to have to clean), but you should always try to be professional in EVERYTHING you do.
You'll learn that in the military too.
Old 02-10-2012, 10:51 PM   #5
oldblue1968chevy
Re: Camshafts..
Okay so wipe with mineral spirits (I have access to a parts washer) then blow dry. Got it thanks guys
John
Old 02-10-2012, 11:10 PM   #6
litew8
litew8's Avatar
Re: Camshafts..
Not sure what solvent is used in your "parts washer", stick with "mineral spirits".
Old 02-10-2012, 11:18 PM   #7
oldblue1968chevy
Re: Camshafts..
Its old mineral spirits. Kinda dirty Its filtered but I think i'll just use some out a bottle.
John
Old 02-10-2012, 11:32 PM   #8
oldblue1968chevy
Re: Camshafts..
yay or nay on soaking lifters lol
i didnt soak my comp lifters (same thing)
John
Old 02-11-2012, 12:47 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Camshafts..
No need to soak lifters. and I'm bettin' most of the cats here that build lots of engines don't either.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-13-2012, 10:05 PM   #10
oldblue1968chevy
Re: Camshafts..
Should I bump the engine around to TDC before I take it apart or what? hopefully ima start in the AM soon as I clear a spot in the garage!
John
Old 02-13-2012, 10:59 PM   #11
68Stepbed
68Stepbed's Avatar
Re: Camshafts..
Yes, put it at TDC. It makes reassembly much easier.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-13-2012, 11:19 PM   #12
oldblue1968chevy
Re: Camshafts..
TDC compression stroke right
John
Old 02-13-2012, 11:24 PM   #13
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Camshafts..
You mean to tell me this thing is not running yet??????????? LOL
prostreetC-10 is offline   Reply With Quote
Old 02-13-2012, 11:37 PM   #14
oldblue1968chevy
Re: Camshafts..
One more thing
Im leaking oil from my drain bolt
I'll have it in/out alot in the next few days. Can I seal it up by putting something like teflon tape on the threads?
John
Old 02-13-2012, 11:38 PM   #15
oldblue1968chevy
Re: Camshafts..
No its not even torn down yet LOL
I borrowed the puller tonite. Hopefully I'll start tom. soon as I build a fire and clear a spot in the garage out
John
Old 02-14-2012, 12:58 AM   #16
Captainfab
60-66 Nut
Re: Camshafts..
It sounds to me like you need a new gasket on your drain plug.
Old 02-14-2012, 02:02 AM   #17
litew8
litew8's Avatar
Re: Camshafts..
What Captain said. You're suppose to change the drain plug gasket at every oil change (so they say). Thought you were looking for a new pan anyway? If the threads are stripped, don't know what to tell you - other than I think someone makes a repair kit for it.
Old 02-14-2012, 10:33 AM   #18
oldblue1968chevy
Re: Camshafts..
Its a copper crush washer right?
I have a few around I"ll try that and something on the threads
threads are fine not stipped.
John
Old 02-14-2012, 11:25 AM   #19
litew8
litew8's Avatar
Re: Camshafts..
oops, no. I was referring to the nylon kind.
Old 02-14-2012, 04:06 PM   #20
oldblue1968chevy
Re: Camshafts..
Ok 1 more.
My crank sprocket has 3 positions. With the dot @ 12 O clock (crank sprocket) the keyway is @ 2 O clock.
My motor has always ran @ 30* or so with no vac adv and its always puzzled me
Is something wrong here?
Thanks pix soon
John
Old 02-14-2012, 04:11 PM   #21
oldblue1968chevy
Re: Camshafts..
Calling comp now I guess
LMK what i need to do
ps how do i get the lifters out lol there flat with engine lol magnet no worky (sall one)
John
Old 02-14-2012, 04:28 PM   #22
GASoline71
GASoline71's Avatar
Re: Camshafts..
You need to read the instructions that came with the timing set for a 3 keyed crank gear. It will tell you where to set it up for TDC.
Are you talkin' 30 degrees initial??? holy cats!
You can pull the lifters out carefully with a pair of pliers.
Gary
Old 02-14-2012, 05:16 PM   #23
oldblue1968chevy
Re: Camshafts..
Machine shop did the bottom end (assy) im not sure if I have the papers..I called comp and squared it away.
yeah 30 deg initial!
Ok the comp was real hard comming out (never done before either).
I got a little rough with it 2 times (turning via cam sprocket) There was some metal shavings (not sure from where) like metal hairs actually not very many but more than I wanted to see?
I got some pics but they dont show much. Whats excessive and now im worried.
Thanks guys its torn down but I have to go out with the MS.
Now im worried
Gary-I just tunred the cam and picked the lifters up as they came up.
Thanks guys leave me something good
John
Old 02-14-2012, 05:41 PM   #24
GASoline71
GASoline71's Avatar
Re: Camshafts..
You got 'em out. That's all that matters. Do any of the bottoms of the lifters look concave and "eaten up"?
Gary
Old 02-14-2012, 05:48 PM   #25
oldblue1968chevy
Re: Camshafts..
Lobes on the cam look fine.
I glanced at the lifter bottoms as I was taking them out. Nothing JUMPED out at me
Only thing im worried about now is the metal hairs that came out toward the rear of the cam..
John
