04-04-2013, 08:14 AM | #126 |
Re: Build: I've never done bodywork...but I can change if I have to! (bagged '67 SWB
Just caught up on your build. I admire the fact that you have decided to take on the paint and bodywork yourself. Everything looks awesome, great job.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
04-04-2013, 10:08 AM | #127 |
Looking good so far. I'm definitely going to be following the rest of your build.
04-04-2013, 10:44 AM | #128 |
motor exploder
What part number was that parking brake cable kit?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 04-04-2013 at 11:24 PM. |
04-04-2013, 11:02 AM | #129 | |
I use this product after i have my bodywork dialed in. http://evercoat.com/imgs/pis/SLICKSANDPIS.pdf I would also recommend using a epoxy primer on all your metalwork or bare metal spots before you apply any fillers. As for fillers i like to use a skim coat of evercoat everglass over all my metalwork areas. Lets say you have a pinhole you missed welding up the everglass will resist moisture where bondo or filler will absorb the moisture. After you layed down a skim coat of everglass and sanded it, you can use your choice of fillers. I perfer rage gold or extreme body filler(nice stuff to sand). In no way am i telling you how to do your build but offering some advise that i have used for many times and had great results. |
04-04-2013, 02:37 PM | #130 | |
04-04-2013, 06:00 PM | #131 |
One major thing i have forgotten to say is if you end up using Slick Sand make sure the shop or paint store you buy it from puts it on the paint shaker for a min. of 10min.
If they tell you they shake it up before it goes on the shelf, INSIST they shake it again. Another thing is to spray it through a gun with a 2.0 tip or larger. |
04-04-2013, 09:11 PM | #132 | ||||
Registered Mail
I assume wilwood, they only have one park brake cable kit, its a universal fit, that only works with their disc/drum combo units. Quote:
'67 chev 496, lwb to swb, bagged - pro street project |
04-12-2013, 12:49 AM | #133 |
Registered Mail
well things are progressing... finally finished destroying my nice new bedsides, used a stud puller to bring it back a bit then filler'd her up! just need to do a few touch ups and fill a few bubble pockets, then scuff it up and start the paint process on them.
got sensors mounted up for the e-level up front, had to mount them a bit lower so it would clear the shocks which i relocated, so i just welded on a plate to the bracket I had already made for the shocks. and here is the cab right in the middle of being wet sanded, what a long process, i really don't care for the orange peel look though, so I hit the clear with 800 then again with 2000. hopefully I can find materials I need to buffer it tomorrow, then I can put the cab on the frame for good!!!
04-12-2013, 08:07 AM | #134 |
67cheby
Looking good !
Posted via Mobile Device |
04-13-2013, 10:13 AM | #135 |
Good steady progress.
04-13-2013, 02:32 PM | #136 |
Registered Mail
Thanks!!
thanks! hows the recovery going? here are some shots after the wetsand of the clear coat. I am new to this so i didn't want to go too aggressive, resulting in a little wave here and there.. but wayy better then before! I was doing some reading on the internet (which was a bad thing this time) read some info and started the wetsand with 800, well that turned out to be much to aggressive for what I wanted, and now I have little micro scratches and I'm a bit too affraid to keep hitting it with 2000 to remove them and end up sanding off the clear is some areas. I buffed it and polished, came out good, minus the micro scratches and the odd spot where the stupid 8" knuckle buster caught the drip rail for a split second and burnt the paint off right to the primer! I dunno how I will buff the interior? I tried by hand, seems completely ineffective...
04-13-2013, 04:33 PM | #137 |
Looks great!! You'll be driving long before I will
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
04-13-2013, 08:13 PM | #138 |
Truck and auto performance nut
that looks great! Did you mention the color and I missed? Just went thru but couldn't find where you mention it?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-13-2013, 09:02 PM | #139 |
Looking good smoknbarrels.
Some advice on wet & polish.... Start with 800 grit to cut your down your orangepeel like you did. Then hit it with 1000 grit Then 1500 grit Then 2000 grit & if you havent gone insane by then Hit it with 2500 grit. You really dont have to go to this extreme using 2500 grit but makes it nicer to polish out. One thing i noticed on your cab you wet sanded is the you sanded right to the edge. That is not recomended, reason being it is so easy to burn through on a edge polishing. This will open a whole new can of worms for you & not in a good way.... I like to stay a min of a 1/2" from all edges on a wet/polish. I also tape around all my edges to be safe. Another little tip is to add a drop of dish soap in you bucket & spray bottle when your wet sanding. Makes sanding a little easier. Also do not wet sand with out a block, never just use your hand. You will end up seeing grooves created by your hand. Hope this helps. How many coats of clear did you lay down? What brand are you using of clear? What size tip & air pressure are you using? Last edited by BLUIDVL; 04-13-2013 at 09:11 PM. |
04-13-2013, 09:13 PM | #140 |
Looks great! Trial by error is the best way to learn. I'll follow along for this build.
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
04-13-2013, 09:21 PM | #141 |
Probably,.......he may never let you drive it at all!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
04-13-2013, 09:23 PM | #142 |
I don't know how many coats of clear you put on, if it's less than 4 or 5 go easy....
04-13-2013, 10:23 PM | #143 |
Nice!
04-14-2013, 10:01 AM | #144 | ||||
Registered Mail
Its funny, i have most of the winter to work on it, but like last year i dont get much done during the winter, but push hard the last few weeks of spring, starting to not look like its gonna be rolling this summer..
I used a 1.5 tip for my base ( think i'm going to 1.3 next time) and used 1.3 for my clear. Clear is a proform product or plus1 or something like that. Running my pressure a little over 20psi at the gun. Wish i would have though of taping off drip rail and a few other spots, as i did do a bit of damage, i guess i will just have to use some nail polish and do a few touch ups. Quote:
04-16-2013, 12:35 AM | #145 |
Registered Mail
Another forum member was nice enough to give us an idea of what the build should end up like.
04-16-2013, 11:06 AM | #146 |
That is a super nice color, your doing great job. It'll all be worth the effort when your done.
Scott |
04-16-2013, 11:57 AM | #147 |
Your buildin a show winner there.
foot recovery is going good thanks for asking. |
04-17-2013, 01:16 AM | #148 | |
Registered Mail
I don't think it gonna be a show winner, but I am trying to the best of my skills.... and patience! thanks! gonna stay up late tonight, or into the early hours and get my paint and clear done on the doors, and perhaps hang them the next day or two! I am just waiting for my primer to dry so I can hit it with some 320.
'67 chev 496, lwb to swb, bagged - pro street project Last edited by smoknbarrels; 04-17-2013 at 04:04 PM. |
04-17-2013, 04:14 PM | #149 |
Registered Mail
well I didn't spray the colour last night, takes a while sanding the primer down.
but here it is!! finally have the doors done today, so I will be looking forward to hanging them in the next day or two, wanna make sure I don't get finger prints in the clear coat when handling them. thought it would be fun to spray my brake reservoir, so I disassembled it and shot the casting.
04-17-2013, 04:18 PM | #150 |
VA72C10
looking good!
Looking for a 67-72 swb or blazer project in or around VA. |
