Old 11-09-2014, 09:51 AM   #126
Shady Chevy
Shady Chevy's Avatar
Re: New Project: 1974 2WD Shortbed
ok, so if everyone thought it was crazy to fix the bed, they will be even more unhappy about me fixing these doors. LOL. I almost bought another pair at Carlisle, but it didn't work out. So I am going to fix these.
Shady Chevy is offline   Reply With Quote
Old 11-09-2014, 09:52 AM   #127
Shady Chevy
Old 11-09-2014, 10:03 AM   #128
Shady Chevy
So I want to start planning the custom door panels I want to make. I am going to start with a piece of MDF as the foundation. I will fiberglass over that. I found the material I think I am going to use to cover them with. It is a soft black simulated leather material that I think will match the black part of the Cobalt SS seats I am going to use. I will have to convert to power windows because my speaker pods cover the window crank. I will add a piece of wood trim along the top. Undecided on the wood right now but it will match the wood I use on the console.
Here is the paper template:
Old 11-09-2014, 10:33 AM   #129
Shady Chevy
Old 11-09-2014, 10:36 AM   #130
Shady Chevy
Starting to layout the door panel on a piece of 3/4 inch MDF.
Old 11-15-2014, 12:01 PM   #131
Shady Chevy
Progress on the doors. Ordered the inner bottom of the door from LMC. Cutting and fitting right now.
Old 11-15-2014, 12:05 PM   #132
Shady Chevy
One a different note. I just came across the flush mount rear windows for these trucks. It has a built in 3rd brake light. Very cool. Has everyone else been aware of these???? I didn't even find the price yet. I can't believe I never saw them before!!!
Old 11-15-2014, 12:07 PM   #133
Shady Chevy
here is a link to the flush mount rear window:
http://www.onepieceproducts.com/Prod...0BRAKE%20LIGHT
$295 I might have to have this. They are too cool.
Old 11-15-2014, 01:37 PM   #134
bbbc10
Diggin The SquareLife
Great progress on the truck an I seen/ know few ppl that have used the flush rear window but without the break light
bbbc10 is offline   Reply With Quote
Old 11-15-2014, 04:09 PM   #135
Shady Chevy
Thanks. I can't wait to get some paint on this thing to see what it is going to look like.
Old 11-22-2014, 07:37 PM   #136
Shady Chevy
Old 12-06-2014, 11:51 AM   #137
Shady Chevy
I got the door skin welded on. Now I need some type of slide hammer to pull the panel back to where it should be. I would be interested in any suggestions on what type of slide hammer others are using.
Then I decided I better do a test fit of the door on the truck. I should have done this sooner. My rocker panel I put on a few months ago, is not in the right place. I am going to have to cut it partway off and move it to where it should be.
The I decided I better weld little tabs of metal right up against where the door hinges attach to the door, so every time I take the door back on and off it ends up in the exact same place. This is the first time I have taken on a project this involved.....so a lot of these "little" things are causing me problems. What to other people do to help bolt the door back on the hinges in the exact same spot every time. The gaps on the jams are going to need a lot of work to make them uniform. So the door must go back on in exactly the same spot.
Then the most perplexing one was that the the body line on the side of the truck didn't line up between the door and the cab????? It was about 1/4 inch off. The door would have to raise 1/4 inch to make it line up. If I did that there wouldn't be a gap at the top of the door????? So I am getting creative here and cutting/welding this back to where it matches the door body line.
Old 12-30-2014, 11:46 AM   #138
Shady Chevy
I made this sketch of the interior back in March. I am going to work on the door panels this week. More pics to come this week. Today am am working on welding nuts to the door that will hold the panel in place.
Old 12-30-2014, 01:26 PM   #139
73Super8
73Super8's Avatar
Dude your thread is an inspiration. Like most have said, I wouldn't have tackled such a project. You've got great skills and it shows. I'm looking forward to seeing it completed. Great work!
1973 K10 Super 8 http://67-72chevytrucks.com/vboard/s...d.php?t=645525 Sold
1988 S10 http://www.s10forum.com/forum/f135/p...-papaw-470214/
2010 Nissan Frontier 4wd DD
2008 Ford Escape Limited Awd Momma's Ride
1978 C20 Farm truck Sold
73Super8 is offline   Reply With Quote
Old 12-30-2014, 04:56 PM   #140
Shady Chevy
Thanks, I can't wait to post some more pics.
Old 12-30-2014, 07:34 PM   #141
flashed
We cant wait to see them either ,as said above ,great job .
flashed is offline   Reply With Quote
Old 12-30-2014, 11:16 PM   #142
wideopen1967
wideopen1967's Avatar
Just a suggestion. If you put a fuel cell under that bed cover make sure you ventilate it some kit of way. Or you will be Da Bomb........
wideopen1967 is offline   Reply With Quote
Old 12-31-2014, 01:04 PM   #143
Shady Chevy
Most of the bed floor has been cut out, so there will be lots of ventilation for the fuel cell.
I mounted the door panel on today. I am using (4) 10-32 socket cap head screws to hold it in place. I welded nuts to the door, to thread into. Then countersunk the heads and put washers in there for support. The MDF will be fiberglassed over soon. I am going to make the armrest next. I am going to copy the armrests on my '08 Expedition. The wood will match whatever I pick for the console.
Old 01-01-2015, 02:07 AM   #144
ivorton74
ivorton74's Avatar
Its crazy how this truck is transforming...I cant wait to see it don't. I also like your sketch...I do my own sketches too of my 74...I did one a few days ago of what I want my 5.3 turbo set up to look like.
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 01-15-2015, 12:17 PM   #145
Shady Chevy
Some update pics of the door panel work. Here I have a piece of tiger wood that I am cutting out to use on the top side of the arm rest.
And I started to put the fiberglass over the MDF form. I used the mill to remove the excess material on the back side of the panel. This will get a layer of fiberglass also. I never tried doing this before so we will see how it goes.
Old 01-16-2015, 04:54 PM   #146
Shady Chevy
Here is the armrest I am working on....
And here is a pic of my '08 Expedition that I am loosely copying the armrest from...
Old 01-19-2015, 12:17 PM   #147
Shady Chevy
Ok, here is the armrest mocked up on the door panel for the first time. Speaker pod is off for this pic. Need to lay up more fiberglass.....
Now I am going to start to put the body filler on all my welds on the top of the bed cover. This is all welded, ground and sprayed in Eastwood self etching primer (black). Let the body filler begin. We will see how straight I can get this???
Old 01-20-2015, 02:30 AM   #148
95gmc
Those door panels are nice! That was a great idea
95gmc is offline   Reply With Quote
Old 01-20-2015, 10:14 AM   #149
Shady Chevy
Thanks. I never made a pair of door panels before, so I am learning as I go. I have to decide on a few things yet.
1) which parts will I put the black vinyl material that matches the black part of the seats.
2) Color to paint speaker pods? Right now, I am thinking wild strawberry that matches one of the two colors on the outside of the truck.
3) what to do with the arm rest part. Right now I am thinking a silver interior paint from Eastwood
4) do I stay with the wood I have right now, or pick something different. I am going to put a high gloss finish on this piece and see how it looks.
5) I have to do something with where the door latch is. I haven't put any thought into that yet.
6) And I haven't finished the speaker grill covers yet. They will be 1/4 diameter stainless vertical tubes. I want to do something that has a matching effect on the center console to tie things together.
Old 01-20-2015, 10:17 AM   #150
Shady Chevy
And I started the body filler on the top of the bed. I only have an hour before work each day, so things are going slow. But I want to see how it turns out.
