07-09-2012, 08:22 PM | #126 |
Re: Wires,Wires, and MORE WIRES..
Duane, got wiring harness in, really not in very good shape. Not going to add to all the drama, but I hope you will either replace or refund.............Also dome light was supposed to be complete assembly.................
07-09-2012, 08:59 PM | #127 |
Just a Member
was that wrapped up when sent because that does not look like it
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
07-10-2012, 09:57 AM | #128 |
07-10-2012, 01:51 PM | #129 |
C10 addict
Not trying to hi-jack your post but what are the two wires in the top two pictures for in this thread? I'm trying to sort out which wires I am still missing.
http://67-72chevytrucks.com/vboard/s...0&postcount=13 Do you have any glove box light assemblies?
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
07-10-2012, 06:35 PM | #130 |
Just a Member
I must have grabbed an old one. I was not insinuating that you mixed up. I just bundled all the good ones and i must have sent one that I never unbounded to inspect.. I dunno.. I will post pics of the others shortly.. Sorry. If they look the part I will send them tomorrow.
07-10-2012, 06:38 PM | #131 | |
Just a Member
Pics?
07-10-2012, 08:37 PM | #132 |
pic#13 looks like lighter harness, at least 2 of the pics
07-11-2012, 08:16 AM | #133 | |
07-12-2012, 11:29 AM | #134 | |
07-12-2012, 11:33 AM | #135 |
still looking for a 70 A/C dash harness??
07-12-2012, 12:15 PM | #136 |
Just a Member
PM me on refund amount for tail light harness and I will get the dome assembly sent out tomorrow.
07-12-2012, 12:21 PM | #137 |
Just a Member
check posts 8-10 and 85-86.
07-12-2012, 02:52 PM | #138 | |
You packaged the tail light harness and the dome light together for $72. See in post #7 you quoted someone $41.20. Send me a money order for $40. I will PM you my address, otherwise I want to keep everything else in this thread........ |
07-12-2012, 03:05 PM | #139 | |
Just a Member
Duane
07-12-2012, 10:28 PM | #140 |
if the A/C dash harness is still available can I get a pic or two of the bulkhead connector? that is my problem area I have on mine, major melt down!!!
OH yeh how much? thanks |
07-12-2012, 10:38 PM | #141 |
Just a Member
Here they all are absolutely not burnt and no splices There are more pics on page 1 and 4 in this thread.
07-12-2012, 10:51 PM | #142 |
I like it how much?
07-12-2012, 10:53 PM | #143 |
Just a Member
I had them for $150 originally which is really reasonable for hard to find original dash harnesses. I will let them go for $120 shipped though. $15 of that will be shipping.
07-12-2012, 11:31 PM | #144 |
OK consider that harness mine. I just went out and looked at my truck, I will also need if you have one in excellent condition, the harness that is on the left side of the bulkhead connector it goes to the distributor and the starter etc.
if you have that one also shoot me a combined total please. thanks Richard |
07-12-2012, 11:48 PM | #145 | |
Just a Member
07-12-2012, 11:54 PM | #146 |
Just a Member
picture of engine harness
07-13-2012, 12:10 AM | #147 |
that one looks like the alternator side, I may have described wrong, I'll try again: as you are looking at the engine from the front of the truck and the harness connector is on the drivers side I need the harness that goes across the firewall to the starter, distributer and the blower motor. the pictured plug looks to be the alternator harness that goes to the drivers side and voltage regulator assy.
07-14-2012, 12:48 AM | #148 |
so whats the word on the harnesses?
07-14-2012, 02:20 AM | #149 |
Just a Member
the one in the pic is the engine harness which runs along the top of the firewall.
07-14-2012, 02:22 AM | #150 |
Just a Member
the bottom pic shows the end of the wiring where it connects to the pass. fender for the battery feed. It is the wire you are talking about. I know the difference between the two and alternator wiring and the driver side is way smaller in bundle and length.
