Old 02-11-2013, 03:55 PM   #126
muddnutz
muddnutz's Avatar
Re: '77 c10 "charlene" bagged on billets
Love it!! Can't wait to see more of it
1986 K-10 "ole blue"
muddnutz is offline   Reply With Quote
Old 02-11-2013, 10:52 PM   #127
mccurrkm
mccurrkm's Avatar
Sweet truck man! What gauges are those you put in and what sizes are they?
My 85 LQ4 Build
mccurrkm is offline   Reply With Quote
Old 02-12-2013, 12:02 AM   #128
DIRTY HAIR
Originally Posted by Devillusion View Post
You do any square bodies in the paint? and how big? I could use a few prints like that for my rec room.
Shoot me an email on all the details if you don't mind.
automationcreations@inetbiz.ca
ya bro for sure, im an artist, i do all sorts of oil paintings and portraits an weird stuff, i figured i should paint some chevy trucks for my fellow truckers
DIRTY HAIR is offline   Reply With Quote
Old 02-12-2013, 12:07 AM   #129
DIRTY HAIR
o'reilys finest...equus gages, 2 1/8 if im not mistaken
Old 02-12-2013, 10:37 AM   #130
mccurrkm
mccurrkm's Avatar
They really look good! Probably a more economical way to go than AutoMeter. I have been looking for a nice alternative to AM since I have to change my speedo with the LS swap. Would you mind posting a picture of the gauges straight on and what they look like at night too? How do you like them?
My 85 LQ4 Build
Old 02-12-2013, 12:44 PM   #131
DIRTY HAIR
Yes they were in my price range and still lok great. Ill post a pic when I get a chance
Old 02-12-2013, 12:53 PM   #132
mccurrkm
mccurrkm's Avatar
Well, I just realized they don't have an electric speedo so I can't use it with my LS...dang I thought I had found my solution!
My 85 LQ4 Build
Old 02-12-2013, 08:11 PM   #133
SCOTI
SCOTI's Avatar
Seen this thing cruising up 66 a week or so ago.... looks good 'hovering' down the road . Been by the shop more than once but too busy to see what other projects your group was nearing completion on.
Hopefully can catch up w/you guys @ Kellers soon.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-13-2013, 12:16 AM   #134
DIRTY HAIR
oh man... well hope you find an alternative solution. those autometers sure are nice but a bit pricey
Old 02-13-2013, 12:19 AM   #135
DIRTY HAIR
haha ya ive been beating the streets lately. ya stop by, couple of the guys got some cool projects going on...ls motors and intro wheels are flying around over there...
Old 02-13-2013, 02:03 AM   #136
SCOTI
SCOTI's Avatar
I check to see what's new in the parking lot every time I'm picking up some plating or leaving my storage building. I spoke w/YellowGT @ the Turkey Drag when they had just swapped the new rear set-up onto the crew-cab.
Nice looking ride.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-28-2013, 10:35 PM   #137
DIRTY HAIR
what fuel pressure are yall running? my truck turned off while driving, reads roughly up to 4 psi right now and it doesnt stay on. im pretty sure i set it to 6-7. could my filter be clogged? or fuel regulator be clogged? it def aint the timing, has power, and correct volt. itll stay on only if i step on the gas pedal and constantly feed it fuel, but it just wont stay on.
help!
Old 03-01-2013, 09:16 AM   #138
SCOTI
SCOTI's Avatar
Different carbs have diff psi requirements. Quadrajets & Carter/AFB style carbs utilize 5psi max while Holleys use slightly higher up to 7psi. Check your supply source for flow issues (in-line filters, fuel pump issues, in-tank sock).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2013, 09:58 PM   #139
DIRTY HAIR
will do, im running a holley 750 dp, and a electric holley fuel pump out a fuel cell. one thing im pretty sure i ran out of gas and i may have run the pump dry for a moment or two...dont know if that may have damaged the pump
Old 03-02-2013, 02:32 AM   #140
74 stepside
74 stepside's Avatar
Your truck looks bad a$$ !
74 stepside is offline   Reply With Quote
Old 03-02-2013, 11:06 AM   #141
mccollum23
Dude the truck is so sick! I have a 79 swb that I need to get started on and your truck is motivation!
mccollum23 is offline   Reply With Quote
Old 03-02-2013, 05:28 PM   #142
DIRTY HAIR
thank you gentlemen..
so now i found out the issue of why the truck wont stay on and idle. the throttle iddler screw backed off from the vibration of the motor. i feel like a stupid bleep.
in other news.........i drained my oil breather resivour and ounces of what seams to be fuel, and about a half ounce of the "milky substance" poured out. panic mode is in effect. im guessing the valve covers arent pouring out fuel but, maybe im running too rich and the vapors are collected in the res tank.
any imput?
Old 03-02-2013, 05:39 PM   #143
DIRTY HAIR
when i take the pcv valve out the valve cover, smoke spews out..
Old 03-02-2013, 05:41 PM   #144
DIRTY HAIR
re routed the trans line to the cooler through the pass side frame,,, mounted the fuel press reg on the frame, installed my porterbuilt firewall cover and oil breather tank. cleaned up and cut out any extra wires i had hanging on the fire wall. ignition box was installed behind the porterbuilt firewall cover and all wires to and from it were hidden as well..
heres what im working with, one pcv valve coming out each valve cover into a res tank..
Last edited by DIRTY HAIR; 03-02-2013 at 05:42 PM. Reason: oh well i thought it would repost the pic
Old 03-04-2013, 09:50 PM   #145
DIRTY HAIR
truck is running super lean, ive parked it and it is now going under theh knife once again.
next objective is to get rid of this camber issue...i know ive put it off but the time has come.
upper a arms are gonna b mounted 1.5 inches higher and steering shaft will be relocated.
its officially lone star roundup crunch time. i have about a month to do this and a couple other small things like add a radio, fix the carb issue, pin stripe the hood, and paint a logo on the door pannels. ill try to keep yall posted.
Old 03-04-2013, 10:09 PM   #146
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
I will be at LSRU too (minus truck) hit me up..... Truck looks good bro I really like how your wheels came out
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 03-05-2013, 06:33 PM   #147
aggie91
I'm just glad to be here!
aggie91's Avatar
Good looking truck. I saw your buddy's white crew at Turkey Drag with the 24's, it looked sick, but it stayed on the trailer...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-06-2013, 07:11 PM   #148
DIRTY HAIR
thanks, and for sure man. im really excited this year bout roundup! i missed last year cause my truck was in pieces.
Old 03-06-2013, 07:14 PM   #149
DIRTY HAIR
ya if im not mistaken he tried to have the truck ready by lone star throwdown but didnt make it. hes getting down on the truck, ls motor that has a sweet sounding cam, wilwood brakes, digital gages, fuel cell. i shoulda made a build thread for him.
Old 03-11-2013, 11:45 PM   #150
DIRTY HAIR
Heres a pretty cool project hanging round the shop, 4 door dually bagged on alcoas. These guys are building stuff left and right over here. Ill post some more stuff later of the "4 brothers" here at bedrock customs
