Old 03-23-2014, 10:45 AM   #126
made2drag
made2drag's Avatar
Re: 56 made2drag
made2drag is offline   Reply With Quote
Old 03-23-2014, 10:49 AM   #127
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 03-23-2014, 10:53 AM   #128
made2drag
made2drag's Avatar
Re: 56 made2drag
it looks worse than it is....
***DON'T TRY THIS AT HOME***
the 2x4 between the firewall and the crossmember isnt doing anything...it isn't there now and i wish it wasnt in the pictures
Old 03-23-2014, 08:06 PM   #129
Kim57
Kim57's Avatar
Re: 56 made2drag
Nice progress.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-24-2014, 09:32 AM   #130
made2drag
made2drag's Avatar
Re: 56 made2drag
thank you sir
Old 03-27-2014, 07:37 AM   #131
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 03-27-2014, 07:39 AM   #132
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 03-27-2014, 07:41 AM   #133
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 03-27-2014, 07:46 AM   #134
made2drag
made2drag's Avatar
Re: 56 made2drag
76 frame is now under it....im going to have to take measurements to see where and how i need to level out the cab. i need to put the bed and front clip on temporarily to see where the mounts need to be...then when cab is mounted i need to shorten the frame....16 or 17 inches....(3 inches more than when people shorten 73-87 longbed to short beds or there would be a 3 inch gap)
my goal for this week is finished. it may be a few weeks til the cab is mounted since im out of time this week. i would like to be driving it this fall.
Old 03-27-2014, 09:05 AM   #135
Kim57
Kim57's Avatar
Re: 56 made2drag
Looks like it should work out pretty good.
Kim
My build thread
Old 04-02-2014, 10:49 AM   #136
made2drag
made2drag's Avatar
Re: 56 made2drag
Question:
should i be able to turn the fan blade easily with the spark plugs in? i can turn the fan blade with little effort and watch the flywheel spin since the manual transmission is off.
im wondering if this is a sign that the compression is low and may be a bad motor? im hoping this is normal for straight 6's...friends tell me it shouldnt spin easy unless the spark plugs are out.
any help would be great. i do plan on doing a compression test on each cyl but it will be a few weeks
Old 04-02-2014, 12:36 PM   #137
akdg87
akdg87's Avatar
Re: 56 made2drag
Even on the straight six its easy to spin with the plugs in, i asked my dad the same question. Low compression motor.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 04-02-2014, 05:16 PM   #138
made2drag
made2drag's Avatar
Re: 56 made2drag
thanks!!! makes me feel better now!
Old 04-20-2014, 04:38 PM   #139
made2drag
made2drag's Avatar
Re: 56 made2drag
I put a little gas in the carb and did the screwdriver trick on the starter...she cranked and ran great....no smoke...I need to clean motor up and buy plug wires, battery cables and motor mounts. The steering column and wiring harness is out of the 76 waiting to go in the 56. The brake pedal bracketry may be the hardest part to adapt. If anyone has any ideas, let me know
Old 04-27-2014, 06:03 PM   #140
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 04-27-2014, 06:07 PM   #141
Kim57
Kim57's Avatar
Re: 56 made2drag
I'll assume those are your cab mounts you're fabbing.
Kim
My build thread
Old 04-27-2014, 06:19 PM   #142
made2drag
made2drag's Avatar
Re: 56 made2drag
so on the 76 frame there is a 4 inch dip and the stock 56 frame is totaly flat. i knew the front cab mounts needed to be 4 inches higher due to the dip in the frame so i looked in my metal scrap and found a 6 inch i beam.
i measured my 56 front wheel center to the front mounting cab holes and came up with 29 or 30 inches and the holes were 8 inches from the frame rail on each side. i did the same measurement with the 76 and the 76 mounts were in about the same place. so i used the 6 inch i beams that i cut and they are about a 1/2 inch too low....so as you can see in the last pic i made kind of like a "ski" on each side....when i lift the cab on the ski's i should be able to slide the cab forwards or backwards a tad and then drill the hole for the cab mount bolt. whatever part of the "ski's" i dont need, i'll just slice off.
i have read on other builds that people move the cab an inch anyway to center the front wheels so maybe im in the ballpark...im hoping the cab will be too low....too low will be a lot easier to adjust than if it is too high...lol
Old 04-27-2014, 06:22 PM   #143
made2drag
made2drag's Avatar
Re: 56 made2drag
Kim
yes sir...i know they're ugly but im thinking they will be hidden....
Old 04-27-2014, 06:25 PM   #144
made2drag
made2drag's Avatar
Re: 56 made2drag
the last pic is really ugly...i primed the mounts the day before and had the idea of the "ski's" and right after i welded them and i put the welder up i rained...you can see the rusty rain drops...LOL
Old 04-27-2014, 06:30 PM   #145
made2drag
made2drag's Avatar
Re: 56 made2drag
can i say ratrod on this forum?? well, unfortunately, this truck will be together with 76 or 56 parts and pieces from my scrap pile....not that it doesnt deserve better, but this will be low budget like they did back when aftermarket parts werent sold...not sure it will have any aftermarket parts on it other than maybe small Autometer gauges to watch oil and water.
Old 04-27-2014, 08:38 PM   #146
Kim57
Kim57's Avatar
Re: 56 made2drag
There's nothing wrong with building on a budget.
Kim
My build thread
Old 05-06-2014, 12:17 PM   #147
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 05-06-2014, 12:19 PM   #148
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 05-06-2014, 12:21 PM   #149
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 05-06-2014, 12:23 PM   #150
made2drag
made2drag's Avatar
Re: 56 made2drag
