Old 02-23-2013, 09:38 AM   #126
hydrojunkie
hydrojunkie's Avatar
Re: project "call of duty" 72 c10
Originally Posted by hilljob26 View Post
thats really coming together, i too wont spend a ton of money on parts when i can build them myself,,just my nature,,,i do however play black ops 2 quite a bit on the xbox...look me up sometime,,gamertag is hilljob
Sent you a friend request bud.
Magic happens with a welder and a grinder.
My custom tubular c10 laying rockers.
http://67-72chevytrucks.com/vboard/s...78#post5970778
hydrojunkie is offline   Reply With Quote
Old 02-23-2013, 12:47 PM   #127
smoknbarrels
Registered Mail
smoknbarrels's Avatar
So far i,ve enjoyed following along, even though I don't really post. I like a fast build, I try to push hard when I have time also.
So what happened to the hydro truck? I was really looking forward to seeing that system being built right! Did you go to air because of cost? Is it faster or easier to set up then hydro? Just wondering why you switched..
smoknbarrels is offline   Reply With Quote
Old 02-23-2013, 03:55 PM   #128
hydrojunkie
I wanted to do actually a push pull set up. It consist of 4 hydraulic cyl and 4 air bags.
You use fatty cyl as your supply any skinnies as your lift. Then use air bags to push the filled fatty to raise the wheel. But it takes quite a bit of room to do that.
Hydros also take a bit of room.
I've decided on air because you can hide bits through out the truck. I'm probably gonna regret doing air because the system always leaks. Pop a bag and ur screwed.
Blow a cyl and you still can lift it to limp home.
I may change it so !!!!!!!!
Old 02-23-2013, 03:58 PM   #129
hydrojunkie
Exhaust is complete. Yeaaaaaaa
Old 02-23-2013, 03:59 PM   #130
hydrojunkie
Dropping my heads of to get ported and freshened up for a thumper cam.
Old 02-23-2013, 04:00 PM   #131
hydrojunkie
One more
Old 02-24-2013, 06:07 PM   #132
hydrojunkie
I put the cab on and it was I horrible condition. I really didn't look at it because I've been so rapped up with the frame. So this cab is junk. Nothing is bolted just resting on thr frame. Need to start from scratch. Aaaaaaahhhhhhhh.
Old 02-24-2013, 06:08 PM   #133
hydrojunkie
Here
Old 02-24-2013, 06:09 PM   #134
hydrojunkie
Me driving it. Lol
Old 02-24-2013, 07:29 PM   #135
Zoomin
Man of Mini-Talents
Zoomin's Avatar
New cab? Dang, that'll probably set you back what? 45 minutes?
Your pace is amazing!
Zoomin is offline   Reply With Quote
Old 02-24-2013, 07:59 PM   #136
hydrojunkie
Sexy and centered. Now I need to start my old cab. Redo the chop and so on. Time to order sheet metal.
Old 02-24-2013, 08:01 PM   #137
hydrojunkie
I wish bud. If it looks to good to be true it prob is. My buddy is going to give me the cash back for it so I will put that into my old cab. Time keeps on tickin!!!!!
Old 02-24-2013, 08:17 PM   #138
sduckworth13
sduckworth13's Avatar
wow, man that is looking sweet. Great job
Scott
sduckworth13 is offline   Reply With Quote
Old 02-24-2013, 08:44 PM   #139
hydrojunkie
Thanks bud. I may have some stuff for ya if your interested. How's ur truck comin.
Old 02-25-2013, 11:55 AM   #140
67cheby
67cheby
67cheby's Avatar
well that stinks about the cab but i am sure you can handle it !
67cheby is offline   Reply With Quote
Old 02-25-2013, 07:49 PM   #141
sduckworth13
I'm at a stand still for now on the truck, work is slowwww. I found another truck I like too but its going to have to wait.
Scott
Old 02-25-2013, 09:46 PM   #142
hydrojunkie
Welded the tabs for the radiator support. My tires just make it on the inside of the fenders when it lays. I am going to change the front end into 1967 style I like it better. Because I the engine forward more I have a lot more room in the firewall I think it looks a lot better that way. All in all it's coming along good. Hopefully this week I will get a wheel alignment to finish the front end. Then tear down the entire frame to get painted.
Old 02-25-2013, 09:47 PM   #143
hydrojunkie
Take a look.
Old 02-26-2013, 08:15 AM   #144
RatRod68
RatRod68's Avatar
looks great
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 02-26-2013, 12:40 PM   #145
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Its amazing to me how you got the angles on the frame right so that the radiator support sits where it needs to for the fenders. Pretty cool work!
Old 02-26-2013, 02:17 PM   #146
hydrojunkie
Thanks bud. Basically we mimicked the stock frame and also had a little bit of luck.
Old 02-27-2013, 01:37 AM   #147
vegadesign
vegadesign's Avatar
Looking good bro, everything coming together
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 02-27-2013, 05:35 PM   #148
hydrojunkie
I got the best news possible today.
MY TRUCK WILL DRIVE STRAIGHT.
I had off today because of rain. "Can't work with high voltage in the rain" and took my chassis to my buddy's Firestone. 1 hour later the tv screen was all green. He said it will drive straight as an arrow. Toe,camber,caster all good. Now I can strip the frame to get painted. 1 step closer.
And most of all I built it from scratch. Hell mutha f**kin yea
Old 02-27-2013, 05:37 PM   #149
hydrojunkie
Green screen.
Old 02-27-2013, 05:38 PM   #150
hydrojunkie
1 more
