Re: My 56 6bt 4X4 build.
Thanks Mud Man. My truck came from your neck of the woods abt 11 years ago. Much nice stuff out there still ??? Nothing in Ont . Thats for sure .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
So how did you plumb the return into the into the tank. From what I was thinking you need to keep your fuel system submerged in fuel at all times. It looks good finally in there. I dig the Detroit green.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540 1992 Chevy K1500 Silverado ECSB 1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered |
#3 | |
I used a boat thru hull fitting that was set for pipethread . Then added a 90 and a 3/8 barb and off I went . Going out now to thro a log on the outdoor wood burner . Will take a few more pics now that its running .
Hers a few more pics. My return line . Exh clearence. Heater core will take some thought . P/S Like Orries set up. I love it when all the stuff in the shop can finially be bolted to something !
One of the shifter .
I had to put the one of the truck on the hoist in again . Makes me laugh. Not something to do at work . ![]()
In case you do not see it in my thread, here is a shot of the speedo cable extension. It is long enough I looped it over to the frame to keep it out of harms way.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Looking great! How are you gonna do the "gas"
pedal? I took the one out of the donor truck because it has a nice square mounting pad but I wanna see how you did yours.
#8 | |
Stock dodge cable. Its a bit long tho. makes the pedal a bit stiff. May try to shorten . or maby just try a nice new cable .
The cool part of you truck build is when it drives by when your done, people will never expect the sound of a diesel should screw with a few heads, be like ..what..is that a diesel, no way...cool. Keep the work going, cool build for sure, lot to fab and modify that is why I appreciate it so much, a real build.
#10 | |
That's true, most people in general don't really understand, some do but I get the 235 6cyl thing, haha.
#12 | |
#13 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great work on your truck! You're making great progress for sure! The 205 coupler may be hard to find new. Let me check with a dodge dealer and see if they offer it at all. Maybe Quad4x4 or a place like them offer them?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#14 |
If it works for you, on that 89 Burb I did, I was able to retain the stock throttle cable. I just had to drill the hole a little bigger to slide over the dodge pivot ball. I then used a clip and end from another ford throttle cable I had to pop on the ball to retain the cable in place. Works great.
#15 |
Well driveshafts got sent today. Going to finish up steering tonite. Haven trouble getting the mush out of the brake pedal. Master might of been empty for too log during the axle swap. Goint to adjust up the rears and see if I get some pedal. This thing may even move a few feet under it's own power this wknd. !!
Luther I will try to get thise pedal pics tonite. I forgot . My Bad.
#16 |
What did you come up with for the trans mount?
#17 |
Hi Ryan. In the name of simplicity I think im going to re use the dodge crossmember and use the orriginal style mounts.. Cheap And i was able to get them quickly, due to the configuration of the frame being so straight Im going to have to fab up some drop brackets but thats no biggie. I may make a mount for some trac bars off the drop bracket while im at it .
#18 |
Chevy Enthusiast
6BT you need the 29 spline coupler specific to the getrag/205 http://www.ebay.com/itm/Dodge-Cummin...30858207866%26 http://www.enterpriseengine.com/shop...apter-coupler/ http://www.quad4x4.com/cgi-bin/comme...cton&key=10528 http://www.ebay.com/itm/np-205-np205...59218e&vxp=mtr
I would check the web for some feedback before ordering one. I hope this helps!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#19 | |
![]() Is the Gertag the same spline as the NV 4500? I wouldent have thought so ? Most of those links seem to give you that inpression tho. Hummmm.... now what . i guess I gave to hit the web to see whats up . Thanks again for the links .
#20 |
Chevy Enthusiast
Yes all the 4x4 dodge manuals are 29 spline and will all bolt up to your 205 (not sure about the G56) but I was thinking that coupler only came with the 360/205.
#21 | |
That makes more sence. I was going crosseyed just thiking abt it . I will oredr up one of those for sure. Whatever one is closer to canada i guess. Thanks again for the links .
#22 |
Be careful, some NV4500's behind 318's and 360's are 23 spline.
#23 |
Chevy Enthusiast
Yeah your right, I should have said diesels. Do you know what the V10s had?
#24 |
pretty sure all the diesel and v10 trans are the same. they were the "HD" units.
#25 |
Chevy Enthusiast
That's what I thought, they both have the bigger input shafts on the nv4500s also.
| Bookmarks |
| Tags |
| 4x4, cummins, napco |
