Old 06-06-2017, 09:19 PM   #126
Brad54
Brad54's Avatar
Re: Finally caught a break NP440 / MY 6
Originally Posted by Blue666(2) View Post
Brad, do you know if a hydraulic clutch can be used with a trans originally set up for a mechanical clutch? Any info as to which part numbers would be needed? Thank.
Sorry, no.
Mine was a '62, and I used a CCP kit for the power brakes and new hydraulic clutch master. I just used the stock original bell housing and slave.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 06-07-2017, 12:53 AM   #127
Captainfab
60-66 Nut
You can convert to a hydraulic clutch by either using a '84-'91 truck bellhousing or by installing a hydraulic clutch conversion slave cylinder and brackets from Novak onto your existing bellhousing. I make the booster brackets with the hydraulic clutch conversions for '60-'72 trucks which includes a new clutch master matched to the slave you are using.
Old 06-10-2017, 01:55 PM   #128
trailcarnage
trailcarnage's Avatar
Alright fellows, I need some help with my A883 conversion.
1) Does this conversion require a high hump tunnel to clear the shifter box?
2) Last night I ran into a clutch issue. I am running the stock LT1 flywheel which is 153teeth. I ordered a 1984 C10 5.0L clutch that would have been with this transmission. When I went to install the pressure plate, I found that the bolt pattern of the pressure plate is about an inch larger. It turns out that the 1984 flywheel was a 168teeth. I am looking for recommendations for a clutch for this combo, 10"/10-spline/153teeth.
trailcarnage is offline   Reply With Quote
Old 06-10-2017, 10:17 PM   #129
Greg63
Enjoy your truck
Greg63's Avatar
1) It didn't with mine - I used my stock low hump tunnel.
2) Cant help you there.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 06-12-2017, 07:06 PM   #130
par4tom
Mine had the high hump...168 Ring Gear
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 06-12-2017, 07:13 PM   #131
par4tom
Here's a picture of the bracket I bought from Captain about 5 years back...it really worked out well for my situation and like the transmission, it pretty much just bolts right up. I painted the bracket to match the truck and Captain included everything else.
I did have to source a braided line to the slave cylinder...other than that the tranny and the clutch were turn key to the original.
T
My Build Thread
Old 10-18-2023, 09:24 AM   #132
mdmcs1
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
mdmcs1 is offline   Reply With Quote
Old 01-23-2024, 10:37 AM   #133
mdmcs1
ah yes, ^^^ these posts getting removed/overwritten reminds me of why i quit using these boards in the first place - i wondered why it had been so long since i was here, now i remember!
Old 01-24-2024, 11:08 PM   #134
cwcarpenter98
cwcarpenter98's Avatar
I understand that you are disappointed about your previous post being edited, but you did break the rules of this forum that you agreed to when you first signed up to use it.
If you would like to post a Want To Buy thread, you can certainly upgrade your membership and post the WTB thread in the correct location on this forum.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
