Old 07-22-2015, 08:00 PM   #1
elbine69
elbine69's Avatar
Re: 69 GMC Build, 20s, Full Frame, LS, Bagged, Bodied
A few more pics...
Check out my thread:
69 GMC build, 20s, full frame, LS, bagged, bodied
elbine69 is offline   Reply With Quote
Old 07-22-2015, 08:04 PM   #2
elbine69
elbine69's Avatar
Last but not least, a few before and afters.
At this point most of the heavy fab is almost finished. The frame just needs core support and shock mounts. A bunch of the components for running the air/fuel/brake lines are on order. We're going to get the cab pulled off in the near future to finish the massive amount of welding.
More soon, thanks for looking!
Old 07-23-2015, 08:20 AM   #3
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress! Your truck is really coming together now. I really like all the custom work. Keep the pictures coming
mcbassin is offline   Reply With Quote
Old 07-24-2015, 10:45 AM   #4
elbine69
elbine69's Avatar
Thanks mcbassin
Old 07-24-2015, 03:30 PM   #5
Justin@EntropyRad
Justin@EntropyRad's Avatar
right on!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 11-24-2015, 10:36 PM   #6
elbine69
elbine69's Avatar
Been awhile since an update, but don't worry, we've still been working!
Since the last update got the fabricated front sway bar installed, which I dont think we took any pictures of, and then worked on getting everything we could bolted on the truck to take to a show in the middle of August.
Loaded up morning of the show! We got it loaded up at 10pm the night before, lots of last minute things.
At the show!
The truck got picked for Best Suspension and Best Underconstruction!
Jason with his awards.
Old 11-24-2015, 10:53 PM   #7
elbine69
elbine69's Avatar
After the show, the truck went back in the garage and got completely blown apart, so we could finish up the chassis and build up the engine. Whats left is the shock mounts, fuel lines, air compressor mounts, exhaust mounts, and probably 12 other things we have forgotten about.
You can see the tube that the sway bar mounts in these pictures.
Everything stripped and playing with the exhaust layout.
We didnt really take any pictures of the engine, but we honed the cylinders, put in new rod bearings, gave it a general going over pretty much.
The big changes were a Texas Speed 228r cam! The heads also got rebuilt, stiffer springs, titanium retainers, new guides etc. Cant wait to fire it up!
Old 11-24-2015, 11:08 PM   #8
elbine69
elbine69's Avatar
In the last few weeks, Jason was able to pick up a t56 for 500! We got that mounted, added an x brace in frame, built the transmission mount off it, and have been working on the exhaust. The exhaust is 2.5" stainless from the headers back and will exit through the bedside. Its all getting tig welded, and is turning out pretty nice so far!
The first piece being tacked on.
Drivers side tacked together.
Passenger side tacked in.
View from above. Shows off the x brace pretty well too.
Thanks for looking, will have more soon!
Old 11-25-2015, 12:36 AM   #9
SchreinerM
A T56 for five bills? Care to double your investment?
Great build, I'm definitely following along.
SchreinerM is offline   Reply With Quote
Old 11-25-2015, 09:33 PM   #10
elbine69
elbine69's Avatar
Thanks! I've already tried buying it off him, he's not interested haha.
Old 11-25-2015, 10:12 AM   #11
lowlyfec10
god i love this build. how are you gonna route the exhaust to come out the side?
lowlyfec10 is offline   Reply With Quote
Old 11-25-2015, 09:35 PM   #12
elbine69
elbine69's Avatar
Thanks! It's going to go through the link bar crossmember and under the framerail so it exits in front of the tire. Probably going to make it an oval shape instead of the 2.5 inch round coming out the side.
Old 01-11-2016, 07:04 PM   #13
elbine69
elbine69's Avatar
Red face Re: 69 GMC Build, 20s, Full Frame, LS, Bagged, Bodied
Small update, exhaust is all tacked and mounted minus the rear section. The front bag mount gussets are done as well. We've just been working on finishing up some loose ends of projects to finish up the chassis, we're aiming to be able to start the engine next month. Next on the list is getting the hardlines run for fuel, the engine accessory drive and the wiring.
For the accessory drive the alternator and power steering pump will be high mounted. For the pump we got a CTS-V bracket, GM type ii pump, and an LS1 camaro pulley.
Old 01-12-2016, 11:43 AM   #14
aggie91
I'm just glad to be here!
aggie91's Avatar
Cool updates!
BTW, where did you get that LS1 t-shirt?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-12-2016, 05:10 PM   #15
mcbassin
Still Learning
mcbassin's Avatar
Awesome work as always!
Old 01-14-2016, 11:33 PM   #16
elbine69
elbine69's Avatar
Thanks Mcbassin!
aggie91 that shirt came from one of the ls engine in stagnant pages, don't remember which, sorry!
Old 03-02-2016, 12:11 AM   #17
elbine69
elbine69's Avatar
Update, we've been working on finishing up a bunch of small projects, as well as building a rotisserie for the cab to make it easier to finish welding and finish the roof. The pic below is when it was being built.
Old 03-02-2016, 12:14 AM   #18
elbine69
elbine69's Avatar
Also Country Graphix finished up the rendering, turned out pretty cool!
Old 03-02-2016, 07:30 PM   #19
mooseknuckles
mooseknuckles's Avatar
pretty cool indeed!
mooseknuckles is offline   Reply With Quote
Old 03-02-2016, 09:39 PM   #20
Rochlow
What mufflers are you using??
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 03-03-2016, 11:58 PM   #21
elbine69
elbine69's Avatar
They're just Magnaflow universal stainless 2.5" mufflers.
Old 04-03-2016, 04:14 PM   #22
elbine69
elbine69's Avatar
Getting close to firing this thing up, just waiting on the injectors. Harness came in from PSI and Texas speed did the tune on the pcm. Cab is back on, going to start running the harness to try and start this in the next few weeks!
Old 04-04-2016, 07:00 AM   #23
Sac
Nice build!
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 04-05-2016, 10:27 PM   #24
elbine69
elbine69's Avatar
Is this thing on?
Pics of the cab on, started running fuel lines, injectors arrived today.
Old 04-06-2016, 03:21 AM   #25
Sac
Is that the mid-rise or high-rise and is your motor raised? Seems closer than normal to the wiper cowl.
<SeveredTies>
