Old 12-04-2017, 08:01 PM   #126
sprint_9
sprint_9's Avatar
Re: sprint_9's 72 C10 Project
Originally Posted by BIGglaSS View Post
Looking good! Following along...
Originally Posted by gringoloco View Post
Where’s the wolf whistle emoji? Looking great!
Originally Posted by Jason7121 View Post
Looking great can't wait to see more!
Originally Posted by knomadd View Post
Looks good!
Thanks everyone.
I started out today fixing the small spots I talked about in my previous post. I couldnt let them go, and after some guidance from Barry with SPI I felt confident in getting them shaped up. After those were sanded and spotted in everything sat for a couple hours then I went to clear. My clear went pretty good for only being my second time spraying clear. I learned alot and by my last coat things were flowing out pretty decent, a good cut and buff and I think it will look real nice, to be fair the pictures look better than in person.
Im beyond thrilled with how the old gas cap filled in, I have alot of time in that one area trying to get that to look good.
sprint_9 is offline   Reply With Quote
Old 12-04-2017, 08:47 PM   #127
builtbyKane
builtbyKane's Avatar
That looks great
builtbyKane is offline   Reply With Quote
Old 12-04-2017, 09:59 PM   #128
Jason7121
Jason7121's Avatar
Really nice looks great!
Jason7121 is offline   Reply With Quote
Old 12-04-2017, 10:12 PM   #129
Bennett68C10
Bennett68C10's Avatar
Very nice
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-05-2017, 12:29 PM   #130
knomadd
knomadd's Avatar
Wow, that looks really good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 12-05-2017, 05:10 PM   #131
sprint_9
sprint_9's Avatar
Originally Posted by builtbyKane View Post
That looks great
Originally Posted by Bennett68C10 View Post
Very nice
Thank you.
Doing a little sanding and buffing today. I sprayed a little far from the panel so I had a little bit too much orange peel.
A little before and after
Old 12-09-2017, 10:51 AM   #132
gringoloco
A guy with a truck
gringoloco's Avatar
Man, I’m loving this color
How’s the fit on the Speed Engineering headers? Specifically, how much hang down below the framerails?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-09-2017, 11:30 AM   #133
Bennett68C10
^^^ I would like to know this too, I’m unsure if I want to keep the hooker manifolds I currently have or run some 1 7/8” full length headers!
Keith
66 Suburban
IG: bennett68c10
Old 12-09-2017, 08:42 PM   #134
sprint_9
sprint_9's Avatar
I couldn't have picked a better color. Its so hard to pick the right one but I ended up with exactly what I wanted.
There is a good thread on the headers here: http://67-72chevytrucks.com/vboard/s...d.php?t=746414
I have some info on page 1, and most of what your looking for is on page 2. Side shots below the frame and block clearance. Let me know if you want any other info or measurements.
Old 12-10-2017, 02:05 AM   #135
gringoloco
A guy with a truck
gringoloco's Avatar
That helps a lot, thanks! 4L60E, right? Looks like a stepped, deep pan. Hard to tell, but it looks like your trans pan hangs below the framerails a little and the collectors a little below that. How much lower?
-Chris
Old 12-10-2017, 11:58 AM   #136
sprint_9
sprint_9's Avatar
I will get you some measurements today.
Old 12-11-2017, 05:14 PM   #137
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks a lot for checking into this. Looks like about 3/4” hang down from what I can tell in pictures
-Chris
Old 12-12-2017, 12:10 AM   #138
sprint_9
sprint_9's Avatar
Im going to try and remember tomorrow. Ive been down to the shop twice now and end up getting side tracked and remember about it when I get home.
Old 12-12-2017, 01:48 PM   #139
sprint_9
sprint_9's Avatar
They hang down about 1.5 inches and are about level with my transmission pan.
Old 12-12-2017, 09:34 PM   #140
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks a lot for the info!
-Chris
Old 12-12-2017, 09:52 PM   #141
sprint_9
sprint_9's Avatar
No problem, let me know if you need anything else.
Old 12-19-2017, 11:37 PM   #142
sprint_9
sprint_9's Avatar
I ended up sanding my clear and spraying 3 more coats. I had too much texture in too many spots I didnt want to buff, especially inside the cab. It was alot of work but it came out great, couple runs to level and some denibbing and it will be real slick. These are right off the gun, it looks as good in person now as it does in the pictures.
Also sprayed a bunch of under hood and dash items in epoxy.
Old 12-20-2017, 01:30 AM   #143
Jason7121
Jason7121's Avatar
Wow looks amazing!
Old 01-24-2018, 12:16 AM   #144
sprint_9
sprint_9's Avatar
Not much happening lately, been spending alot of time cutting and buffing. It took me awhile to find a set of steps that worked for me and I finally got it down today. All the outside of the cab is done except for the rockers, and one weird spot where I had a run. I have some de-nibbing to finish on the inside, Im about half done, and then buff it and it will be ready to mount to the frame.
Ive got quite a few things to knock out before I mount the cab, exhaust, fuel lines, plug wires, transmission cooling lines, as well as some other odds and ends that will be easier to do with it off.
Old 01-24-2018, 12:24 AM   #145
sprint_9
sprint_9's Avatar
Ran across this a couple weeks ago, a fun little before and after. One of the best decisions I have made is to smooth the firewall.
Old 01-24-2018, 11:40 AM   #146
rustytruck50
rustytruck50's Avatar
Nice job!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 01-25-2018, 02:07 AM   #147
gringoloco
A guy with a truck
gringoloco's Avatar
So nice
-Chris
Old 01-25-2018, 11:19 AM   #148
knomadd
knomadd's Avatar
Looks great!
-Duane
Old 01-25-2018, 11:46 AM   #149
Jason7121
Jason7121's Avatar
Looks really good nice work
Old 01-26-2018, 12:19 AM   #150
sprint_9
sprint_9's Avatar
Originally Posted by rustytruck50 View Post
Nice job!!!
So nice
Looks great!
Thank you.
I think Im going to work on exhaust this weekend for a change of scenery. It will be nice to work on something other than this cab for a change. I have almost two weeks of time off from work to use by the end of February, so Im hoping to make some good headway this next month.
