Old 06-03-2015, 07:48 PM   #1
ZouchaR
Re: My 63 Project
And a view of both sides.
ZouchaR is offline   Reply With Quote
Old 09-05-2015, 01:33 AM   #2
whitels1
whitels1's Avatar
Re: My 63 Project
Bad ass build so far, nice attention to detail!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 09-08-2015, 02:10 PM   #3
62jimmy
Re: My 63 Project
Great Build! Just read the whole thing! How much clearance do you have on the bottom side of the driveshaft with the flipped crossmember?
62jimmy is offline   Reply With Quote
Old 09-08-2015, 02:23 PM   #4
ZouchaR
Re: My 63 Project
That was a dang good question. And I didn't know. So I went out and took a picture.
Looks to be about an inch and a half.
Old 10-29-2017, 04:50 PM   #5
Bomp
Bomp's Avatar
Re: My 63 Project
Thank you for the heads up.
Have had similar dealings with other retailers and it really Kills ones motivation.
Bomp is offline   Reply With Quote
Old 11-13-2019, 09:33 PM   #6
ZouchaR
Re: My 63 Project
So having a side fill gas tank.. And I have since replaced this tank as it developed rust holes in less than 4 years. Anyway.. this was my answer to where to install the gas filler....
Old 11-13-2019, 10:30 PM   #7
ZouchaR
Rusted Tank
So this is the original Red tank that I purchased, painted and installed. While I was installing my SNIPER EFI system, I was installing the new fuel pump when I noticed the blisters in the paint on the bottom of the tank. When I rubbed one of the blisters... GUSHER!!!! And I had just put 15 gallons of 91 octane in the tank.....
Old 11-14-2019, 01:32 PM   #8
ZouchaR
Re: My 63 Project
Because I SUCK at tuning carburetors and because I couldn’t really find the right combination for this motor.... I purchased the Holley Sniper EFI system.....
This system is AMAZING!!!! a single O2 sensor... high pressure fuel pump... return line too the tank... couple of wires.... VROOM!!!!!
Old 11-14-2019, 01:42 PM   #9
ZouchaR
Re: My 63 Project
This is the video of the first key turn start with the new Sniper EFI... Listen too the motor rev up.. and then immediately slow down too the idle RPM that we set with the handheld unit....
https://youtu.be/IGj-6-vG2eI
Old 11-15-2019, 03:42 PM   #10
Android04
Android04's Avatar
Re: My 63 Project
Sounding good. I've considered Sniper or going LS for a while.
Android04 is offline   Reply With Quote
Old 08-12-2020, 11:34 AM   #11
88Stanger
88Stanger's Avatar
Re: My 63 Project
Good Write up, it is a bit older but still a good write up.
88Stanger is offline   Reply With Quote
Old 08-12-2020, 11:45 AM   #12
J Williams
J Williams's Avatar
Re: My 63 Project
Truck looks great man! Good work
63 C10
J Williams is offline   Reply With Quote
