Old 09-30-2003, 10:43 PM   #126
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Lets get a inside shot of the fender.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 09-30-2003, 10:46 PM   #127
phantom dually
I also got a little done here. It will set the crossmember with 255 45 18 tires and wheels. The factory tire are 28.5 inches and the 18" will be 27" tall. This is a rough idea of what to expect. Measured a bit on the cab and will (should) set the rocker. maybe 1/2 inch tops!! YEAH BABY YEAH!!!!
Old 09-30-2003, 10:47 PM   #128
phantom dually
2
Old 09-30-2003, 10:47 PM   #129
phantom dually
3
Old 09-30-2003, 10:48 PM   #130
wdz28ss
wdz28ss's Avatar
dont make fun of the pic...still need to clean up the rough edges...it was getting late last night.
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had"
wdz28ss is offline   Reply With Quote
Old 09-30-2003, 10:50 PM   #131
wdz28ss
wdz28ss's Avatar
oops..clicked the wrong button.
Old 09-30-2003, 10:56 PM   #132
wdz28ss
wdz28ss's Avatar
Originally posted by loweredd
one word------awesome. That is stunning wdz. Are you going to keep the wood look trim when you repaint?
The only thing i'm changing is wheels and the blue to copper or candy orange...still undecided for sure. But all trim and interior and the white (mabye shade) will remain as it did when new.
Old 09-30-2003, 10:58 PM   #133
phantom dually
A little fender mods there to say the least!!!
Old 09-30-2003, 11:34 PM   #134
Slammed67
Progress = 0%
Slammed67's Avatar
wdz28ss: Looking good! What are you going to do for hood hinges?
Phantom: Also looking good! How high (or low) is the bottom on the cross member compared to the bottom of the frame (at the straight part, like below the cab)?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 09-30-2003, 11:40 PM   #135
wdz28ss
wdz28ss's Avatar
[QUOTE]Originally posted by Slammed67
[B]wdz28ss: Looking good! What are you going to do for hood hinges?
This is a good question for now. I'm thinking of a way to fab something up. Also Turner is coming up with his own reverse flip kit. Now sure at this time but will be doing something with it soon. Anyone else have any ideas for hinges?
Old 10-01-2003, 06:06 PM   #136
phantom dually
The crossmember seems to be about the same height as the frame. I think it may lay the frame?? I will see when I finish up the rear.
Old 10-01-2003, 07:49 PM   #137
fastbagged68
fastbagged68's Avatar
Phantom Dually- you might not lay frame. Not to put salt on your progress. Your frame looks good! When I assembled mine with my 2inch crossmember drop mine laid out. I set he rear frame at where my notch will be. the reason I dont think you will lay frame is because of your front bag mounts. I am cutting my crossmember up more so my bags won't rub. I'm using upper cups in the front and the out edge around the bag needs to be cut to get my frame down.
Look at my pics in the beggining of this post and look at where my lower control arms is in relation to yours.
You are moving along fast. My crossmember is sitting on my work bench waiting to get plasma more. Spending to much time on everyone else car.
fastbagged68 is offline   Reply With Quote
Old 10-01-2003, 08:02 PM   #138
phantom dually
Really if it dont lay frame Im not going to be upset. It will be really low and in reality I do not want to lay frame. I am building this truck for show and there is no reason to scrape the frame all up. Do you see a problem with the way the bag sits in?? Do you think I will possibly pop a bag from rubbing??
Old 10-01-2003, 08:16 PM   #139
phantom dually
Also by cutting the bag mounts and moving the metal out of the way are you actually moving the upper mounting pad?? If I do this what would be the best way?? pics would be great!!
Old 10-01-2003, 08:25 PM   #140
loweredd
www.loweredd.com
loweredd's Avatar
phantom, I used bag mounts like on an S-10, or a new fullsize. It puts the top of the bag into the crossmember about 3/4 of an inch.
loweredd is offline   Reply With Quote
Old 10-01-2003, 08:30 PM   #141
phantom dually
I have 2 sets of upper bag mounts. One set is from turners and the others from a fab shop in cali that closed down?? I will check them to see which ones are smaller.
Old 10-01-2003, 08:33 PM   #142
loweredd
www.loweredd.com
loweredd's Avatar
are you using cups, or a plate?
Old 10-01-2003, 08:38 PM   #143
phantom dually
right now I have cups. I beleive a plate would not let the bag sit into the member enough?
Old 10-01-2003, 08:46 PM   #144
loweredd
www.loweredd.com
loweredd's Avatar
no, that's right.
Old 10-02-2003, 03:04 PM   #145
fastbagged68
Hey quick question- what about sway bar mounts on Bill Turners arms. I was checking mine out last night and was wonder if I should use the sway bar off my 67 El Camino. What are you guys doing?
Old 10-02-2003, 03:11 PM   #146
fastbagged68
Phantom have you aired up your front suspension yet? You should and see if it rubs anywhere. If that is a firestone bag they balloon out then up. Make sure it does not rub. If it touches when air down all the way it should be fine as long as it does not sit on sharp edges.
Old 10-03-2003, 10:29 PM   #147
phantom dually
I am going to smooth the inside of the crossmember around where the bag mounts. It is pretty clean now but could use a few minutes of work. I have not aired it up yet. I am trying to get the rack setup with the stock tie rod ends. You have to do a little cutting on them to get the adjuster sleeves to fit in. I thought about running my airline out through the inside of the crossmember and then out the side of the frame. Is this a good idea??
Old 10-03-2003, 11:58 PM   #148
wdz28ss
wdz28ss's Avatar
A few pics after tonight...Got together and sat on ground. Lays frame!!! actually lays on the rivets along bottom of frame. Looks like I need to do something in rear (about 3 more inches). Guess I'll be looking into "back halfing" it. The front crossmember is about 1/2" off ground laid out. probally be working on the rack tomorrow.
Old 10-03-2003, 11:59 PM   #149
wdz28ss
wdz28ss's Avatar
another pic
Old 10-04-2003, 12:01 AM   #150
wdz28ss
wdz28ss's Avatar
one more
