12-10-2014, 02:22 PM | #126 |
Re: 1970 One Owner Short Step
That looks awesome! I will have to look into that.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
12-10-2014, 02:35 PM | #127 |
A few more paint pictures.
12-10-2014, 02:47 PM | #128 |
Still working on fitting the cowl. Got the glove box all polished up. I can't wait until the rest of the truck looks this smooth.
12-10-2014, 02:54 PM | #129 |
I got my A/C condenser installed and a couple of the lines run through the core support. I changed my mind on the radiator set-up and used an aluminum radiator from speedway. I had originally wanted to use the 2009 3/4 ton radiator, but it would have taken too much modification to the core support to make it work properly.
12-10-2014, 03:14 PM | #130 |
Couple more shots of the radiator. I tried throwing in a 2007-2013 truck seat. I did not feel like I had enough room due to the size of the seat and I had to have the seat too strait up to feel comfortable. My dad had a 2009 Cadillac CTS parts car that just happens to have tan leather seats in it. So I will be pulling those and modifying them to fit the truck. As I have looked so far it will not take much to get them in the truck. They are heated and cooled as a bonus. I am not sure I will be able to get all the fun toys to work but my wife has told me the heated portion is a must! Since she doesn't complain about the trucks I will make her happy.
12-10-2014, 03:20 PM | #131 |
Still Learning
You are making some killer progress on your truck. Looks great!
12-10-2014, 04:52 PM | #132 |
Nice..That's quite a bit of progress. The paint looks great. What wheels are on the red step side now?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
12-11-2014, 02:02 PM | #133 |
Great progress. Looks fantastic!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-11-2014, 10:18 PM | #134 |
Looking great Boynton! Be sure to post some pictures with the caddy seat. Is your paintshop about done with the bed as well?
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
12-11-2014, 11:22 PM | #135 |
subscribed ....love the color combo cant wait to see the bed on
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
12-15-2014, 01:08 AM | #136 |
Can't believe I just noticed this build. Awesome progress. Couple questions for you
1.) How did you make your fuel line? Specifically where the line meets the fuel rail. You have a part number for that gold piece? 2.) What gauges are you going to run? 3.) Who did your harness? |
12-15-2014, 01:55 AM | #137 | |||||
Thanks how is the yellow truck doing? Quote:
12-24-2014, 12:57 PM | #138 |
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 Last edited by boynton; 12-24-2014 at 01:23 PM. |
12-24-2014, 12:59 PM | #139 |
Video of the motor/walk around
Its alive! (Officially)
12-24-2014, 01:23 PM | #140 |
I think I got the link fixed let me know.
12-24-2014, 01:50 PM | #141 |
Great job. Sounds good. Link worked fine for me.
12-24-2014, 07:37 PM | #142 |
Still Learning
Engine sounds great ! Congrats on getting her fired up.
12-26-2014, 12:12 PM | #143 |
Sounds great!
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust |
12-30-2014, 01:03 AM | #144 |
I got some Hickory wood and used the measurements from GMCPauls website to cut the wood. I then used minwax Helmsman to seal and protect the wood. I put 5 coats on sanding between each coat. I will buff the finish right before the install.
12-30-2014, 01:09 AM | #145 |
A few more.
12-30-2014, 02:49 PM | #146 |
Still Learning
Wow! your bed wood looks great!!!
Excellent work doing it all yourself too. |
12-30-2014, 03:08 PM | #147 |
The hickory looks great, and its different. Should hold up well too. Don't recall you mentioning, but are you going with polished or painted bed strips? Also, congrats on the engine startup!
12-30-2014, 11:06 PM | #148 | |
Going with polished hidden bolts. Should have a pretty clean look. I went with hickory because I liked that it was a strong durable wood but also has some nice character to it. I can't wait to be done so I can cruze down to your house!
01-16-2015, 03:33 PM | #149 |
How's are those CTS seats coming along? I have a set and would love to see how you mounted them!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
01-23-2015, 02:25 AM | #150 |
I haven't mounted them yet but from looking at the drivers side centered on the steering wheel, it doesn't lOok like I will be taking advantage of the factory hole/nuts. Mine seem to be centered when sitting almost on the edge of the floor hump to the left of the outside factory mount. I will probably be drilling new holes and using a large washer or plate on the bottom side of the cab (this is basically what comes from the factory). I ran into an issue with my drivers seat. The drivers seat has a computer/curcuit board that appears to operate the seat, and I believe mine has a malfunction. I can get the passenger seat to work without any issue but the drivers seat is unresponsive. I have an impala seat that has the same track width, so I am going to see if I can swap the cts bottom and back to that track and use a less complicated seat. I am planning on recovering the seats anyway so I will get something worked out. Speaking of recovering I just got my highlander material in! It was a bit expensive ($89 yard) but I really think it will help tie the seats to the truck. No my truck is not a '72 therefore not a highlander, but since it has a ls 6.0 in it, I figure its not original therefore anything is fair game and I really like this material.
