05-19-2018, 03:15 PM | #126 |
Re: Pink's 68/72 - Dropmember Equipped Build
Not much progress since my daughter was born. I was finally able to get back in the garage yesterday so I got a few small things done and a few parts ordered as well.
I picked up a set of the Hooker manifolds. I plan on doing a black Cerakote on these. I also got a new flywheel and also ordered a Circle D torque converter which should arrive in the next couple days. Bag mounts are fully welded on and I spent some time cleaning the axle tubes. You wouldn't believe how much crap was built up in there. This should be going out for blasting and powder coat in the next week or so. Also got my fuel lines ran up to the filter/regulator. I used Notchead line clamps which are pretty sweet. The lines snap in tightly but can easily be removed for maintenance. They make them for all sorts of hard and braided lines. |
06-11-2018, 09:33 AM | #127 |
[/QUOTE] Hey man, where did ya get these line mounts (please). If you don't mind. Thanks!
Curent build:http://67-72chevytrucks.com/vboard/s...d.php?t=764984 |
06-11-2018, 09:44 AM | #128 |
Hey man, where did ya get these line mounts (please). If you don't mind. Thanks![/QUOTE]
I think I bought mine from Jegs but here is the website for the manufacturer so you can see all the different sizes they offer. https://www.notchead.com/ |
06-14-2018, 07:54 AM | #129 | |
https://www.notchead.com/[/QUOTE]
07-28-2018, 03:33 PM | #130 |
I've been collecting parts and slowly making progress.
Holley serpentine belt system Circle D 3200 rpm torque converter Pulled the trigger on Fitech Ultimate LS kit Accuair CVT kit And finally sent the rear end and modified trans mount out for powder. It is currently at a driveline shop getting 373 gears and a Detroit TrueTrac I should have a rolling chassis here shortly and then I'll start on new brake lines and exhaust. |
10-31-2018, 05:10 PM | #131 |
Rear end is bolted in and also got my new diff cover for it.
Unfortunately, I ran in to some issues when I went to install my brake kit. The axles I got had a slight lip on the flange face which interfered with the rotor centering ring. My options were to machine the rings or remove the axles and machine the lip off. I went ahead and machined the rings and now they fit perfect. I also started installing my Fitech fuel injection system. I'm really happy with he way the engine is starting to look. |
11-01-2018, 11:08 AM | #132 |
Nice progress. Engine looks killer!
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
11-03-2018, 11:03 AM | #133 |
Almost Satisfied
TV show build....looking great
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-05-2018, 07:59 PM | #134 |
Thanks guys!
11-08-2018, 12:15 AM | #135 |
I was only at SEMA one day this year so I'm sure I missed a bunch but here's a taste of the C-10's (plus burbs & blazers) from the show this year.
[/url] [/url] [/url] [/url] [/url] [/url] [/url] [/url] [/url] [/url] [/url] [/url] [/url] Right hand drive with a power rear window. Definitely something you don't see every day. [/url] [/url] I didn't get a pic of the interior but trust me, it was even nicer on the inside! |
11-08-2018, 11:24 PM | #136 |
Got the rear brakes installed, wheels mounted and finally have a rolling chassis. It's probably been 6 years since this thing was rolling around. I soaked that in for about 30 seconds and then laid it out on the ground.
11-10-2018, 02:18 AM | #137 |
Just beautiful in every way. Keep the pics coming!
12-10-2018, 11:53 PM | #138 |
Thanks!
I got a few more things done recently. The exhaust is back with fresh black cerakote and installed on the engine. I also installed the differential cover and started making the spark plug wires. I got 4 done before my crimping tool broke so now I'm waiting on a new tool to arrive before I finish them up. |
12-12-2018, 03:44 PM | #139 |
Looks great! What front sway bar are you running with your PB dropmember?
12-13-2018, 10:19 PM | #140 |
I'm not sure of the brand. It's the sway bar that PBFab supplies as an option for the dropmember.
12-14-2018, 09:46 AM | #141 | |
Now, they are building their own sway bars. Last edited by Willie Makeit; 12-14-2018 at 03:20 PM. |
