#126 |
Re: 72 chevy modern swap
Thanks been pretty happy with how its been goin, but work always gets in the way.
Lance Modern 72 k20 4wd http://67-72chevytrucks.com/vboard/s....php?p=6954551 67 c20 2wd http://67-72chevytrucks.com/vboard/s...d.php?t=669589 |
#127 |
So they sent me a set of headers back! There was even two in the box!! Im happy happy now, and i sent them in to the machine shop to get milled flat. All headers and even the factory manifolds aren't manufactured completely flat. Thats why the bolts end up broken off because of exhaust leak. So they should be back in a day or two.
#128 |
Any progress or plan on your cab?
You obviously have skills tools and a nice place to work even if you have to replace the whole floor might be just as well. Also on the back of the cab sure you know it's beat up and ugly but it's not going to be seen. Besides this is a driver right not a show truck Good luck and keep us posted with your progress |
#129 | |
#130 |
The cab can be fixed yes, but there's more to it. I plan totally restoring it, and going to car shows with it. If i wanted to go mountain climbing or mudding i would've left the old four speed in but needed something a little more highway appropriate. Its just not the can either both of the inner fenders have been torched. Both of the front fender corners are rusted out. I was planning on finding a replacement truck and flip flopping parts to save money. I know regardless theres going to be rust. I just don't always have the time with work. Would take a lot of weight off my shoulders finding a parts truck. You will see what ends up happening, but main goal it to find out where i want everything.
#131 |
After I built my quad cab I cut up the rest of floor from my truck. I could have helped you out if I had not cut it up.
#132 |
6>8 Plugless........
![]() Join Date: Sep 2007
I'd just search for cabs. Nice ones are out there but be prepared to spend $1000-$1200 for a nice one with nice doors. Sometimes you can find just cabs for $600. Go to a local swap meet, I'm sure there will be a vendor there with rust free beds. Usually those guys will find you parts if you ask them.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#133 |
Here's one, it's not cheap and not close but wow!
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
#134 |
Holy biscuits.
#135 | |
#136 |
![]() Join Date: Dec 2012
If I were Richard Rollins I would give him $20k as long as it was filmed for TV!!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#137 |
I know, that's a new reproduction cab price right there.
#138 |
Headers back from the miller! I also remembered I still had the one bolt broke off in the head so took two tries with the welder and pulled right out.
#139 |
Hey lance what is the length of your front driveline? Maybe center to center of ujoints ?
#140 |
Sorry been away Ill get the measurements in the morning!
#141 |
So started on changing the wiring harness also got my oil sending unit together looks like itll do the trick. I have a question I need help with this like quick because I want it all together by the end of the week.
#142 |
There are to fused wires that I need help with. One that hooks up at the power block and one that ties in to all the power wires under the hood. They both go up to the gauge plug, what the heck are they for?
And there on wire that comes right off the plug I cant remember where it goes. Brown with a white stripe. For others that have questions about starter wire you can eliminate the yellow wires, and the one red wire the comes off the plug. for the alternator you can do away with the plug that is mounted to the front clip. Consist of a red. white, blue, and brown wire.
#143 |
Found out what both of the fused wires are for. Went down to our local body shop and they told me they are both for the ammeter. They pulled them outside the cab for better reading and to get away from clutter inside the cab. Maybe he's wrong, but good enough for me.
#144 |
Okay so its been a little awhile and I apologize been so busy with spring being here! So i only have a few photos and the front clips will be on tonight. I got the heater core holes filled in and all the mice nest pulled out of the vent. Its been moving fairly smooth, but im hoping that ill be driving it around this weekend.
#145 |
For all the ls swappers out there with DBW (drive by wire) throttle body keep your factory throttle cable! It worked out perfect on my pickup. For the whole in the firewall I just used a set bit to get the hole to the right size and it clipped right in the hole. For the pedal assembly the wholes already the right size for the clip but you must cut a small line down for the cable to go through. I just used a band saw to cut the line down. Once I had all this down i had one of the guys at the shop hold down the pedal and wouldnt ya no it full throttle response.
#146 |
I made a decision to keep the cab I got and just repair it. I got a buddy that owes me money for a set of wheel spacers. its not a lot but gotta make money somewhere haha. He was telling me that he was going to scrap a pickup he has and let me tell you it is shot!. Its a 1980 chevy 4x4 half ton. Has a 355 with only 600-1000 miles on it and a 350/np205 behind it. The reasons it has such low miles is because when he got it he had a motor built he threw it in his truck alright not thinking about it... It was long after driving it the transmission bellhousing split in half going you hill and he dropped everything out the bottom! He threw another 350 in to replace it but that only lasted a couple month till the flexplate split in half so there it sat. The body is rotting but the plan is to cut the back of his cab to replace mine and pull the sway bar off for my truck as well. It sounds a little different but ill make it work!
#147 |
I'm a little lost on how you're going to use a square body cab to fix your rust issues? Seems like the appropriate patch panels will go a lot farther than hacking a newer cab up and trying to get the stuff to fit............ Or are you just using flat sheet metal that is good from this cab to try and make patches for your cab?
#148 | |
#149 |
Cabs mounted down and the front clips on! Need to finish running some lines for brakes. Its looking really good and will post a video of it running shorty.
#150 |
Got a few pittily things done along the way. I smashed the bolt for the drag linkage with I removed it so just decided to get new ones. Only 20 bucks a piece so cheap buy. Shifters done and looking pretty tits.
