Old 03-01-2015, 10:21 PM   #126
flashed
Re: Meet Homer (the motor home)
I didnt know you were a Chevelle guy too ,very nice .
flashed is offline   Reply With Quote
Old 03-01-2015, 10:28 PM   #127
cooperhw
cooperhw's Avatar
Actually I am mostly a Chevelle guy sticking my toe back into the truck water. I have had 8 Chevelle's over the years. That's my go-to car. Problem I have is "I like a bunch of stuff".
Can only afford 1 nice one and then a bunch of junk trying to be better.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 03-01-2015, 10:33 PM   #128
nlped
nlped's Avatar
Cool Chevy II and I love the chevelle too. I totally get the"I like a bunch of stuff" syndrome, I have that too. Mustangs, trucks, broncos and trans Am's...I have at least one of each right now. None of them are great, but in my head they will be...someday.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 03-01-2015, 11:02 PM   #129
cooperhw
cooperhw's Avatar
Yep. I know what you mean.
Little bit of progress today. got the cab mounts in and bolted in and aligned up. Then went to put the motor and transmission in but first had to get and install new motor mounts. Didn't have them and couldn't find them. What the heck.
Anybody got and part numbers for a 68 327 that bolts to the block and has a hole that you bolt to the perch from underneath. Standard stuff I thought.
A couple progress pics.
Later,
Wayne
Old 03-01-2015, 11:02 PM   #130
flashed
I have that same cronic syndrome .
Old 03-02-2015, 02:37 AM   #131
swamp rat
swamp rat's Avatar
Man your progress puts me to shame, nice work!~
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-02-2015, 04:03 PM   #132
cooperhw
cooperhw's Avatar
Thanks for the kind words. A lot of times it kinda boils down to zip codes. Right now here in the desert we gotta "make hay while the sun is shining". About 3 months from now it will feel like we are on the surface of the sun, while all you guys out there where it's now cold will be "whipping and a spurring".
Later,
Wayne
Old 03-02-2015, 10:45 PM   #133
BlueBullet
BlueBullet's Avatar
Prothane Motion Control Part Number: D/I7-509 is what I went with on my K10 with a 327. I got them from 4 Wheel Parts. They are the same as the mounts I took off except for the mounting bolt that goes through perch is smaller and they are polyurethane. They are a little thicker they to originals also. Not sure if the perchs are the same from 4 wheel to 2 wheel drive.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 03-03-2015, 11:52 AM   #134
cooperhw
cooperhw's Avatar
Thanks. I found some and bought them yesterday.
Later,
Wayne
Old 03-04-2015, 07:00 PM   #135
lannyhaas
lannyhaas's Avatar
Hey Wayne do you have a couple of front fenders laying around? I need the inter lip that the wheel wells bolt to? Mine were cut out. I have wheel wells, but nothing to bolt them too, fender wise..Just wondering.
lannyhaas is offline   Reply With Quote
Old 03-09-2015, 10:34 AM   #136
cooperhw
cooperhw's Avatar
Little bit of progress update.
This past weekend I installed the new motor mounts and bolted the motor and transmission back into place. Replaced the broken exhaust manifold. Installed an H.E.I. distributor and new plugs. Then, (drum roll)
Actually fired up the motor. She started right up after about a half a turn. Little bit of smoke out of one bank, but not too bad. Never had heard it run before. Still don't want to put any more money in this bullet than I have to cause I might need to replace it. Got a great running 350 sitting on the sidelines yelling "put me in coach". The other hand is if it'll run ok I would rather leave it alone and "don't fix it if it ain't broke".
Anyhow, it lives.
Later,
Wayne
Old 03-09-2015, 12:10 PM   #137
flashed
Awesome that you got to hear it run ,Im looking forward to hearing my old ton truck run again one day .
Old 03-09-2015, 12:33 PM   #138
cooperhw
cooperhw's Avatar
Well thanks. It sure did my heart good to hear the old dude fire right up. Puts a smile in my mind just thinking about it.
I guess it's just the old scrounger in me that loves this part of a build. Looked at it and thought "what is going to puke if it starts"? so if cut a pair of tranny lines and made a loop. looped the water pump. hooked up the oil pressure guage. poured gas in and BAMM, sukka started right up first try.
Later,
Wayne
Old 03-09-2015, 05:12 PM   #139
WIDESIDE72
WIDESIDE72's Avatar
Can't wait to see more progress!
WIDESIDE72 is offline   Reply With Quote
Old 03-09-2015, 05:55 PM   #140
nlped
nlped's Avatar
Sweet
Carter
Old 03-09-2015, 11:04 PM   #141
cooperhw
cooperhw's Avatar
Unhappy Re: Meet Homer (the motor home)
Well baby steps are better than no steps. Yesterday I went to O'Reilly's auto parts and ordered a heater core. Didn't have one in stock so I picked it up tonight after work. Now I know it's not much but I was able to clean it all up, lube the lever, install the new monkey poop seal, and bolted that sucker on. Like I said, not much, but it's one step closer to putting the front clip back on. I need to pull off the drivers side front fender and transfer the bolt holes for the C30 emblem to the new fender and hang it back in place. Got the Spring Nationals Goodguys event in town this coming weekend so no progress planned (unless I skip out on Sunday).
Anybody else going?
Later,
Wayne
Old 03-09-2015, 11:07 PM   #142
blue 72 gmc 4x4
blue 72 gmc 4x4's Avatar
Anybody else going?
I will be there with my 72'!
1955 GMC Hydramatic
1959 Chevy Spartan 100
1969 Chevy C/10
1969 Chevy C/30 Bruiser
1972 GMC (Wrecked)
1972 GMC pickup..old blue
Restored Vent Windows
https://67-72chevytrucks.com/vboard/...d.php?t=766598
1955 GMC hydramatic build
http://67-72chevytrucks.com/vboard/s...d.php?t=429417
blue 72 gmc 4x4 is offline   Reply With Quote
Old 03-09-2015, 11:13 PM   #143
cooperhw
cooperhw's Avatar
Right on. You planning to be in the truck corral? I am planning to be near the car corral/swap meet area on the east/south end where it drops down the hill to the parking lot. I will be in my black 67 Chevelle. Stop by and say hi if you are in the neighborhood. I will look for your truck.
Later,
Wayne
Old 03-09-2015, 11:27 PM   #144
blue 72 gmc 4x4
Not sure yet, this is my first time doing goodguys. I will be on the lookout for it! Sweet Chevelle by the way.
1955 GMC Hydramatic
1969 Chevy C/10
1972 GMC (Wrecked)
Old 03-10-2015, 11:31 PM   #145
cooperhw
cooperhw's Avatar
Thanks,
I bet it will not be the last time you do a Goodguys show. They are awesome.
I will be looking for your beautiful truck too.
Later,
Wayne
Old 03-11-2015, 10:35 PM   #146
cooperhw
cooperhw's Avatar
No pics but I did get a little bit accomplished tonight after work. I pulled the dented drivers front fender (inner and outer) off the removed front clip and drilled the emblem holes on the new (to me) fender I scored from Tom K. Washed out years of leaves and spider nests before it got dark.
Baby steps.
Later,
Wayne
Old 03-15-2015, 10:05 PM   #147
cooperhw
cooperhw's Avatar
Well Friday and Saturday was fun showing the Chevelle at Goodguys but the whole time I was there having fun, visiting, buying stuff, I was wishing I was home working on Homer. But today I dug right in and made up for lost time.
I will show what it looked like this morning and what it looks like tonight. Lighting a fire
Later,
Wayne
Old 03-15-2015, 10:09 PM   #148
cooperhw
cooperhw's Avatar
a few more
Got the core support hung, fenders loosely hung, doors hung and half a** adjusted (gotta pull the fenders back off to adjust them properly), and new center pins and u-bolts installed and locked down.
Back is talkin to me
Later,
Wayne
Old 03-15-2015, 10:37 PM   #149
flashed
Looking better ,keep going .
Old 03-15-2015, 10:42 PM   #150
cooperhw
cooperhw's Avatar
Thanks Flashed. Just keep putting in one bolt after the other. Just think, once it's built and running down the road all sorted out if I keep it I get to pull it back apart and paint it. then the slow put together starts. Oh well, It's what we do.
I tell people I'm like Popeye in that "I Yam What I Yam, & That's All That I Yam".
Later,
Wayne
