Old 06-12-2015, 09:12 AM   #126
OutlawDrifter
Re: Project "Steppin Wolf" LS swap
Your wiring diagram looks good. That should be what you need.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 06-12-2015, 12:31 PM   #127
Liltroy
Liltroy's Avatar
Outstanding. Thank you sir!
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 06-14-2015, 01:48 AM   #128
Liltroy
Liltroy's Avatar
bye bye 1990 exhaust
Old 06-14-2015, 01:49 AM   #129
Liltroy
Liltroy's Avatar
Old engine all ready to come out tomorrow
So what do I do with my old alt wires???
Old 06-14-2015, 01:53 AM   #130
Liltroy
Liltroy's Avatar
Ok so do I just splice my old starter wire into the purple starter wire in my LS harness??
Old 06-14-2015, 08:48 AM   #131
aknovaman
Yes that is correct. Actually on you application, the starter circuit is separate electrically from the efi harness. It's just wrapped inside the efi harness.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 06-14-2015, 10:51 AM   #132
Smokey burnouts
Good job with all the pics and info, def gonna refer back here when I do my swap!! Sweet step side btw👍
72 K5 4x4, 350(rebuilt stock w/edelbrock carb and manifold)/th350, 4"lift 35's, GM 10bolt rear(not thrilled)... Thinking I need some heads and a mild cam or maybe a 5.3!!
Smokey burnouts is offline   Reply With Quote
Old 06-14-2015, 05:45 PM   #133
Liltroy
Liltroy's Avatar
thanks!!
Old 06-14-2015, 05:47 PM   #134
Liltroy
Liltroy's Avatar
something seems to be missing!!!
Old engines out!!!
And sold. its on its way to a new home in a 54 chevy 2door.
Old 06-15-2015, 12:46 PM   #135
Liltroy
Liltroy's Avatar
Hopefully I can get my transmission cleaned up and painted this week after work so I can put the new drivetrain in this weekend! I think I'm gonna wait till its in the vehicle to change the fluid and filter. Thinking about an hd2 shift reprogramming kit too. Does anyone have this kit installed? I know it gives full manual control but does it still allow automatic function as well?
Old 06-15-2015, 10:11 PM   #136
Liltroy
Liltroy's Avatar
Guess who got some cool hoodage today?
Old 06-16-2015, 11:02 AM   #137
Rich84
Rich84's Avatar
I know it's back tracking a bit..But can you tell me how you cleaned the aluminum brackets and accessories to get them ready for paint. I finally got my LQ4 on a stand and have started taking it apart to clean and detail. They are loaded with white powdery oxidation and I'm concerned about the paint sticking and lasting.
Rich84 is offline   Reply With Quote
Old 06-16-2015, 10:11 PM   #138
Liltroy
Liltroy's Avatar
I had all the brackets, water pump, ps pump, and a few other items media blasted. Cost me $80. If I had it to do over I would just goto harbor frieght and pay $40 for the 50lb blaster and do it myself.
Old 06-17-2015, 11:10 AM   #139
Rich84
Rich84's Avatar
How about the oil pan??
Old 06-17-2015, 11:42 AM   #140
Liltroy
Liltroy's Avatar
Muretic acid/water mix and a wire brush. I tryed all kinds of stuff to clean the engine....degreaser, simple Greene, oven clean....finally my uncle gave me some muretic acid and water in a spray bottle. Sprayed on watched it bubble for a few minutes, scrubbed a little with plastic brissel brush, hosed with water and she was clean! Wish I would have started with that stuff in the first place!!! I'm gonna see if he can get me some more to clean whine bay with this weekend. I've decided to postpone the engine install and spend some time cleaning and painting engine bay this weekend instead. It'd be a same to drop a pretty new drivetrain into a dirty rusty engine bay!!
Old 06-17-2015, 06:49 PM   #141
Liltroy
Liltroy's Avatar
Ok I know I flip flop a lot so I'm back on my fuse block and harness. This is how my power wires came back from wait4me performance
For the sake of properly labeling my fuses, how do I trace what wires go where without ripping the harness back apart? Is it safe to just send 12volts down each wire and check each connector with a multimeter? I see that most people seperate the left injectors and coil packs from the right in the fuse block, then a third fuse for sensors and I want to do this as well. I just want everything to be straight for future trouble shooting. Thanks for any help guys.
Old 06-17-2015, 06:51 PM   #142
Liltroy
Liltroy's Avatar
Old 06-17-2015, 07:15 PM   #143
slimneverdies
slimneverdies's Avatar
I think we all flip flop around these builds. As long as you finish everything
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 06-17-2015, 07:42 PM   #144
tinydb84
tinydb84's Avatar
I havent done it on an LS harness specifically but I have used a voltmeter or a test light to do that on plenty of wiring.
David
Instagram: myfabguy
Old 06-17-2015, 11:58 PM   #145
Liltroy
Liltroy's Avatar
found some stuff laying around from my old car stereo bumpin days....decided to use the one in the middle to power my fuse box. fat 4 gauge split to two 10 gauge leads.
This is what Im going for...
starting to come together...Im having trouble finding relay terminals for 10 gauge wire. wish radio shack was still in business.
Old 06-18-2015, 12:05 AM   #146
Liltroy
Liltroy's Avatar
This is my uncles 78 that were trying to put back together from being painted.
Old 06-18-2015, 12:17 AM   #147
Liltroy
Liltroy's Avatar
Steppin Wolf mean muggin...
Old 06-18-2015, 11:25 AM   #148
OutlawDrifter
i hear you about radio shack. definitely made it more difficult every time i want to wire/rewire something!
1991 Z/28, 6.0L/T56
Old 06-18-2015, 12:14 PM   #149
aknovaman
Not trying to hijack your thread; just info to help.
For you guys building your own standalone harnesses, shoot me a PM with your email address in it and I can send you my simple relay diagram. I use Ford Taurus relay bank that has a top and bottom cover. It is located behind the drivers headlight on a Taurus. I also use a raised 6 fuse panel from Ebay. Cheap, clean and effective.
Here is a video of the layout without the relay panel to and bottom covers.
https://youtu.be/xhqukQYe3Qc
FMCDH GBU and GBA
Old 06-18-2015, 11:04 PM   #150
Liltroy
Liltroy's Avatar
You're good brother. just wish I wouldve seen that BEFORE I built my set up.
