#126 |
Second Chance Program
Re: 1977 Silverado Crew Cab.
Here is a little of my filler blocking progress. My goal for today is to block the rest of what I have on there and then go back around with more filler to hit the spots that are still low.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#127 |
So Wednesday I got the rest of my first round of filler blocked. Yesterday I did my second round of filler and started blocking it. I can see I might still have some minor imperfections but I think I will take care of that with glazing putty. Today after work I plan on doing a bunch more blocking. Tomorrow morning I'll likely continue blocking... My arms are already sore! I'll be working on it all day Sunday and hope to have another round of primer on it by the end of Sunday. Then I'll be blocking that next week as quick as possible in preparation for MORE PRIMER followed by MORE BLOCKING. Still shooting for paint and clear the first weekend of October but the likelihood is that it will be the second weekend. It's getting there tho!
#129 |
Yep.
#130 |
the paint is going to be too nice to drive that thing when you are done!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#131 |
Hopefully it turns out that nice! But I assure you, this truck will get many miles and haul loads of everything you can imagine including yard debris, quads, and everything in between. It will be taken camping and probably ran through a little brush from time to time. I just want it to look nice while I'm doing all that stuff!
#132 |
![]() Join Date: Jul 2009
sanding, sanding, sanding - gotta love it! Looking good so far. From what I understand, you should only use the glazing putty for scratches or pin holes but not so much for dings or low spots. I tried to stick to that rule, but used it also for a couple of extremely shallow and small low spots.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#133 |
Yep. That's the plan. I can see that I will have several pin holes and such in the filler that the putty will be perfect for. Thanks!
#134 |
Fantastic work! I wish I had half the motivation you do! I swapped beds on my truck something like a month ago, and I still haven't even bolted it down, lol.
#135 |
I know how it goes! I'm only going so quickly because I have a deadline of the weekend before Halloween! It's going to be close!
I've applied what I believe will be the last of the filler. Going to try like hell to get another round of epoxy on it tomorrow. It will be close. Then I will spray a round of high build and block that and see how its looking. If all looks well after blocking the high build, I'll do a coat of sealer and be ready for paint and clear.
#136 |
Ok so didn't get the re prime done. But I got everything up to that point done so I can do it tomorrow after work.
Here's some current pics. ![]() ![]() ![]()
#137 |
almost there! my fingers hurt looking at all that sanding...
#138 |
Actually it's my shoulders that hate me!
#139 |
Ok second round of epoxy is in the bag! Pretty much a repeat of last time. Mostly awesome with a couple runs. No big. Everything that's not perfect now will be perfected with the feather fill and glazing putty. Body work seems to look pretty good which is nice. The filler really seems to soak up the primer!
#140 |
Looks great!
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#141 |
Looks good, what's with the different gas filler door/cap?!
Matt |
#142 |
Long story. Basically I replaced one of the bed sides and both of them will be going away in a year or so when I switch to a suburban gas tank.
#143 |
Doesn't look to impressive as just a paint splotch but it's going to look pretty nice. It's the original #71 red metallic. Kinda like a mix of red and burgundy. I also picked up a quart of white for the two tone stripe. Getting excited now! Unless something awful happens, I should have paint and clear on it next weekend!
#145 |
In the middle like original.
#146 |
i was able to get full coverage with 2 coats of my wanda base. i sprayed a third because i had waaaayyyyy too much left over.
#147 |
Good to hear! What color were you using?
#148 |
the last color i sprayed was metallic gunmetal on the bottom of my 95. i don't remember the exact color, it was picked from the swatch book, not based on a factory color or anything.
#149 |
looking really good!
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
#150 |
Color is going to look sweet! You have been a busy, keep up the good work!
