Old 06-30-2016, 01:07 PM   #126
lowrodderchev
lowrodderchev's Avatar
Re: LS swap for my 75
I tried to post a video but I'm doing something wrong cause it wont attach. but on another note. 13 year old next door and his little buddy decide after a night of breaking bottles in the street they would go around the neighborhood and slash tires
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-30-2016, 01:10 PM   #127
lowrodderchev
I gotta way good with only 2 tire (1 was 4 months old) they hit 7 cars and a RV. one neighbor has a lifted for truck they slashed all 4 of his and his dads and his sisters car. over $1600 of damage with them alone. Family don't have money to pay for the damage. his buddy who helped him left and he doesn't want to tell on him so he's taking the fall alone.
Old 06-30-2016, 01:17 PM   #128
68Timber
I know the pieces fit
68Timber's Avatar
Hate to see that. His parents should let him work restitution with a lawn mower, give him plenty of time to think about where he went wrong.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-30-2016, 01:21 PM   #129
lowrodderchev
that's what the cops said one or two neighbors agreed to that but the others didn't feel the same way. the lady is a single parent and she adopted like 4 kids. I feel bad for the kid but at the same time he did cost me a pretty big chunk of change for 2 big tires plus my wife thinks we should move because of them.
Old 07-12-2016, 01:45 PM   #130
lowrodderchev
and so continues the bugs. I bought a new fancy toy ultragauge. yesterday I found out my temp was up to 230. the thermostat was the stock one so I traded it out this morning. i'll see how it goes.
Old 07-12-2016, 01:46 PM   #131
lowrodderchev
this was this morning after hot rodding it all the way to work. hopefully I fixed the problem. the old one was really soft like I could press the spring down with one finger Name:  WP_20160712_002.jpg
Old 07-12-2016, 04:03 PM   #132
phillipm
If the spring was soft wouldn't that mean it would've acted like a much cooler stat? Just wondering.
Old 07-12-2016, 04:37 PM   #133
lowrodderchev
I was thinking the same thing but I know these LS motors run hot so maybe it's not letting the coolant cool off I don't know I'm hoping that's it
Old 07-12-2016, 05:00 PM   #134
phillipm
I tried to see but couldn't tell. What does your cooling fan setup look like?
Old 07-12-2016, 05:15 PM   #135
lowrodderchev
I have 2 electric fans that kick on at 190. originally one was kicking on at 190 but the other was not working right I assumed it was because I had him set it up to go on when I turned the AC on but I haven't put the AC in it yet. so I ran the wire to the fan 1 wire. my buddy said its not a good idea to run both fans at once it would take away from the air flow
Old 07-12-2016, 05:32 PM   #136
phillipm
Not a good idea to run both e-fans together? Never heard that before. I promise that is what you want to do. Move the most air possible. Also, not all fans are created equal. I don't look at CFM ratings. I look at how many amps the motor is. That will tell you way more. SPAL and Cooling Components are a couple brands that make quality fans.
Old 07-12-2016, 05:53 PM   #137
lowrodderchev
i pretty sure the bigger fan was 1350 cfm not sure on the smaller one
Old 07-13-2016, 09:00 PM   #138
lowrodderchev
took advantage of this hot day and took the blazer out for a 30 minute drive on the freeway and slow traffic. the highest it went was 223 for maybe a minute then drop down to 220. I'm only running one fan right now. I need to find someone to program my secondary fan or see whats up with it. it not keeping a constant signal it will just sorta sputter the signal so maybe it was the thermostat
Old 07-14-2016, 11:49 AM   #139
phillipm
What ECU are you using?
Old 07-14-2016, 12:13 PM   #140
lowrodderchev
yea so funny story. I have 2 fans behind the radiator(in front of the water pump) and um well I wired them backwards. I mean I wired them right if the fans were in front of the radiator but in this case well you know. they were puling air from the motor instead of pushing it. so on my 20 minute drive to work I was getting a 195-197 reading.
Old 07-14-2016, 12:14 PM   #141
lowrodderchev
its a 2001 ECM. the guy who did it is going to check it out Saturday because I'm still having a issue with fan#2. its pulsing a signal so its not staying constant to keep the fan running
Old 07-14-2016, 03:21 PM   #142
phillipm
Glad you got it figured out.
Old 07-14-2016, 04:05 PM   #143
lowrodderchev
yeah so you were right my thermostat was ok
Old 07-28-2016, 02:03 PM   #144
lowrodderchev
so far so good this bad boy has a massive amount of power. currently dealing with a fuel gauge issue. weather the sending unit is plugged in or not it pegs to 3:00 I have a new gauge and sending unit and replace the sending unit wire. so I'm at a lost right now. I also deiced to shoot some satin black on it.
Old 07-30-2016, 08:56 PM   #145
lowrodderchev
well the black fenders with stock blue/white rear wasn't cutting it. so decide to satin black her out till I get around to doing the body work. what do you guys think
Old 07-30-2016, 10:08 PM   #146
68Timber
68Timber's Avatar
Are the fenders supposed to match? j/k, looks good! Are you going back to blue and white when you paint it?
John
74 Honda Z50 build
Old 07-30-2016, 10:13 PM   #147
lowrodderchev
Lol funny guy yeah I'm sticking to the stock look. I just have a lower quarter pan with some rust and a few other small things. Pretty much stock look
Old 08-27-2016, 07:23 PM   #148
lowrodderchev
Man I got no luck. I put a new sending unit, new fuel gauge and it still dont work. I tire it down today so my brand new sending unit isn't working or the 75 gauge dont work with 87 sender
Old 08-28-2016, 03:42 AM   #149
terrylgreenjr
Did you check the ground from the sender to the frame?
terrylgreenjr is offline   Reply With Quote
Old 08-28-2016, 10:39 AM   #150
lowrodderchev
Yes sir. I pulled the sender out of the tank and both my old and new one grounded to the sane spot. My original one work like a charm the new one didn't. It goes straight past full to 3:00 position
