Old 01-14-2016, 03:25 PM   #126
GRX
GRX's Avatar
Originally Posted by Mrturner1 View Post
Here's a question, do people sell used camshafts? As long as they are in good shape? I definitely won't be using the Lunati cam, but it's a shame to see it just sit around
Only if the matching lifters have been kept in order. Even then, not much market for used cams.
When scraping those gaskets be sure to keep dirt & particles out of the cylinders away from the rings.
GRX is offline   Reply With Quote
Old 01-14-2016, 03:39 PM   #127
davepl
davepl's Avatar
Re: Starting my engine build
^^^ Agree
Stuff the cylinders with rags and try very hard to keep junk out of them. Don't use so sharp a scraper that you nick any of the head surface, but also don't go crazy with a pneumatic 3M disc either. Slow and careful. Laquer thinner helps.
When you're all done, of course, you'll break the cam in and do an oil change promptly after that to get stuff like gasket debris and breakin lube out of the oil.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-14-2016, 03:40 PM   #128
Mrturner1
Perfect! I kept everything in order on two cardboard cutouts in case I was going to put it back in. Maybe somebody can put it to use.
Mrturner1 is offline   Reply With Quote
Old 01-15-2016, 11:23 AM   #129
Mrturner1
I'm putting together a list today of all the different kinds of sealant, silicone, and RTV that I'll need to put this motor back together nice and tight. Any suggestions are much appreciated. Please be specific with the brand and color so I get the right stuff. I used to build 4 stroke 450cc engines for drag racing in the sand dunes and I learned all the best tips for sealing up the engine and what types of gasket/RTV to use from the old timers who'd done it for years.
I'm hoping the heads will be done today, not sure how long a magnaflux and cleaning should take but I'm eager to get started. I have some things I can do while I wait, cam installation, timing gears and chain, timing cover and damper. The only thing I'm worried about is the cam break in lube sitting over the weekend if the heads aren't done today, maybe that stuff can sit a couple days?
Old 01-15-2016, 01:23 PM   #130
toolboxchev
You will want RTV black for the intake manifolds. Use this instead of the rubber or composite for the front and back sides where the intake manifold mates to the block. I tried using those dam seals twice and both times they squeezed out. Its a little tricky dropping the manifold back on top with a bead on block but it is very doable. Mine is still sealed after 50 k miles.
I used a Thread Sealant made by permatex for the head bolts. It is white in color. You can pick up both at any local parts store. Napa always has this in stock.
You can leave the break in lube for a couple days. I used a Moly style that is tacky and almost a grease. In addition use the Comp Cams Break In additive.
http://www.compcams.com/Products/CC-'Lubricants'-0.aspx
toolboxchev is offline   Reply With Quote
Old 01-15-2016, 07:35 PM   #131
Money_pit
Money_pit's Avatar
Don't remember if it was mentioned or not but always a good idea to run a thread tap/cleaner down all the holes for the head bolts. I like to do every bolt hole I see when I got them apart holes are usually full of old sealant and rust most times. Get a more accurate reading on the torque wrench also.
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 01-18-2016, 02:23 PM   #132
Mrturner1
Well after a couple days of rain and freezing weather, and waiting on the machine shop for my heads, it looks like I'll be able to get some work done today. The machine shop said the heads are great, no cracks or anything like that. I bought a set of comp cams valve springs to match the cam I bought, but the machine shop guy is saying that the springs that came with the heads look to be really nice so he's pressure testing them. That would be cool because the new springs were 100 bucks and that pays for gaskets and sealants. He said he'd get back to me by noon, so hopefully I'm picking the heads and rocker arms up today. I'm eager to get moving on this.
I am a little intimidated about getting the timing right on the first try because I need to break the new cam in, but I've been reading a lot. I didn't however mark or keep track of anything about the distributor when I pulled it (doh!!!) so that's going to pose a challenge I'm sure. I know that when the #1 piston is TDC, you put the cam gear with the mark straight up, and also the crank gear, straight up. I understand that part but I'm not 100% confident on the rest yet. It's gonna be fun though. Any suggestions or tips are greatly appreciated guys
Matt
Old 01-18-2016, 02:44 PM   #133
Coley
Coley's Avatar
Smile Re: Starting my engine build
Matt
Here you go....there are several very good 'how to' videos on youtube on how to do this and they are all well worth watching and this should bring back the confidence in getting the dizzy in the right spot.
https://www.youtube.com/watch?v=5a2X9mSSlQY
...this is just one of them...they are several, many of which deal with the distributor installation on a 'new' engine or one that that has had the original timing disturbed.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 01-18-2016, 03:20 PM   #134
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Crank gear dot goes "up" at 12 o'clock position.
Cam gear dot goes "down" at 6,0clock position.
There will be 2 little dots on the gears to line up. This will put the engine on the #6 compression stroke. Then rotate the crank to bring the cam gear dot to the "top" 12 o'clock position and you will now be on the #1 compression stroke.
Clear as mud?
Also... for what it's worth... you couldn't pay me to install a used cam and lifters nowadays.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-18-2016, 03:42 PM   #135
davepl
davepl's Avatar
Here's what I do...
Remove #1 plug
Put finger OVER hole, not into it
Crank engine over with socket driver with other hand
Wait for compression to form and push your finger off
You should be approaching the mark on the balancer.
Continue to 8 degrees BTDC
Install rotor with tab pointing at what will be the #1 wire on the cap
Tighten down clamp enough that you could still adjust the timing.
Install cap.
When you fire it, get it up to 2000rpm and keep it there (at least 1500) to do your cam breakin. If it doesn't fire promptly, stop cranking and figure out why.
You won't be able actually set the timing (except total) because centrifugal will be kicked in, but just set it to something that runs well for the breakin and set the actual final timing later.
Make sure your choke and all of that is working and set before you fire it. You'll be at high enough rpm you can likely run it without a choke, but why fight it?
Old 01-18-2016, 04:30 PM   #136
Mrturner1
Got some bad news from the machine shop. Heads need some machining so the new springs can be installed properly. Need new retainers, clips and shims, and labor. Add the 300 bucks I paid for the heads and 100 for valve springs and my grand total into these heads is 950.....that sounds like a nice set of aluminum heads to me. Maybe next time. I guess it can't all go smooth and perfect the first time.
Old 01-18-2016, 04:30 PM   #137
Mrturner1
Thank you guys for the replies on timing
Old 01-18-2016, 07:10 PM   #138
Redline novdog
Redline novdog's Avatar
Dude do you just have a big wallet or crazy for some wrenchin' .I get the machine shop check on the heads,but springs and a cam? The head change alone will give you seat of the pants pull!!!! Did you pull the cam? what is it, You are worried it is not big enough? I would like to see pics of the end of the cam(part# serial# etc...)
I hope you have the carb/intake/exhaust to go with your build!!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 01-18-2016, 08:50 PM   #139
Mrturner1
Here's the cam I pulled out. It's a Lunati 285 Bracketmaster 2. I have matching lifters for it as well.
Old 01-18-2016, 08:55 PM   #140
Mrturner1
I guess a bit of both. Retired from the Army when I was 22 from injuries in Iraq so the money is good. And since I gotta keep my screws from comin loose I started wrenchin! All the necessary parts are in order to compliment the head and cam change except the tranny and rear end I suppose, those are next on my list of "better upgrade or it'll break" list, that sure got long in a hurry
Old 01-18-2016, 08:59 PM   #141
Mrturner1
This is my barn floor so far
Old 01-18-2016, 09:50 PM   #142
toolboxchev
That is looking awesome. You will be plenty of happy when your back together again.
Make sure your head shop puts in Viton seals. Those things really help keep compression and oil consumption to a minimum!
Old 01-18-2016, 09:52 PM   #143
Mrturner1
Thanks man! And I'm glad you mentioned it, I doubt they have started the seals yet.
Old 01-18-2016, 11:48 PM   #144
Money_pit
Money_pit's Avatar
Just to add before you fire that thing take a small bottle of gas and fill that carb up or use an electric pump. Also a really good idea to get an oil pump primer before you fire it and run it for a minute or two after you get oil pressure just to get it flowing.
Old 01-19-2016, 02:58 AM   #145
GRX
GRX's Avatar
The importance of using a good Moly Paste for proper cam & lifter break in can not be over stated.
Spread it on the cam lobes (not bearing surfaces) before sliding the lump stick in. Or you can apply the paste to the lobes through the lifter holes with a small brush after install while spinning cam to ensure even distribution.
Old 01-19-2016, 07:19 AM   #146
Redline novdog
A good high phosphate break in oil would be important to the cam/lifter break in, for the first start/run.
Sounds like you have it under control,Good luck and sounds like you're already having fun!!
Old 01-19-2016, 08:14 AM   #147
hamjet
hamjet's Avatar
Sounds like they're putting heavy springs in it. (high spring pressure) if they have to machine the heads to make em fit. are the duel springs? Whats the pressure specs on the springs. heavy spring pressure can be bad for cam break-in, alot of guys put in lighter springs or remove the inner spring for less pressure till break-in is complete, then replace the heavier ones. (a lotta extra work).. Not to add fuel to the fire, (something more to worry about), see if you can get the spring specs and post them..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-19-2016, 09:57 AM   #148
Mrturner1
LOTS of fun this has been such a good time and I've already learned so much that even little bumps in the road like the heads getting expensive don't really seem all that bad. I look at it this way, before I busted out the wrenches and went for it, I had started another thread about the engine build, and the labor for JUST the cam and head install with a tune was 2800 bucks. And that didn't include head work, gaskets, springs, nothing. And when it's done I'll be drivin a truck that I built instead of just farming out labor and then driving something I know nothing about.
Old 01-19-2016, 09:59 AM   #149
Mrturner1
Well, I hope it won't hurt anything because I'm gonna have to break it in with the springs that are going on. I can't swap them out or I might try it, and it's too much money to have it done. The springs are pretty heavy, made for a Comp 280H. I'll post the spring pressure when I get home and look
Old 01-19-2016, 12:21 PM   #150
Money_pit
Money_pit's Avatar
The comp cams zdp additive is what you'll need to add to the oil during break in. Depending which oil you use. They also suggest adding that additive every oil change to put back in the oil what modern cars don't need anymore. This chart may also help to determine a converter I just did a little searching for it
