Old 02-09-2021, 09:22 AM   #126
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Re: What kind of gas mileage do you get with your 67-72?
The more I think of it, I didn't go to actual MAX, since I stopped at 2.5k. It is not that the canister is completely trashed/non-operational - it is just does not keep a vacuum when I applied my pump.
As for my cruising speed. 2.5 is about 60-ish, then 70 a bit below 30k if I recall correctly. I really don't see the point trying to cruise to 75~80. 95% of all my driving has been around town - which around here there are lots of 60 MPH roads (non-interstate). To me, it is a lot more fun going the "back way" than get on I35 in my truck.
So it seems time for some more flashy light and perhaps a friend to work the peddle for me
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 02-09-2021, 10:14 AM   #127
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I feed I have eaten way to many replies in this tread and have gone off topic way to much.
I have created my own thread, Timing & Gas Milage.
Hopefully you guys that have helped me so far will pivot there as I update the thread :-)
Richard
Old 02-27-2021, 05:03 PM   #128
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thumbs up Re: What kind of gas mileage do you get with your 67-72?
Originally Posted by Rich72C10 View Post
Stock 350/350 combo (mild RV Cam), 4BBL Qjet, 3.07 rearend with 275 /60 R15 - I haven't seen 10mpg yet, one time I got close.
Though I barely have over 800 miles on the rebuild and I do have a Qjet sent off for rebuilding and tuning. I also have set in the garage / driveway with a lot of idling or very short trips for test runs and not going easy on the gas pedal. Only a few weeks ago did I figure out I needed to adjust the kick down cable for the TH350. Before that, WOT did not much of anything.
Okay, after changing out to New Pertronix Flame-Thrower II, New Flame-Thrower Coil & Wires with 12° initial timing, ~900 RPM idle (Park) and ~640 RPM idle (Drive). Oh and I am using manifold vacuum advance, not ported.
60 Mile test drive, great mixed city and highway (Tx Farm Roads up to 70 MPH).
15 MPG!
SBC 350/TH350 and 3.07 rearend.
Richard
Old 04-12-2021, 03:49 PM   #129
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
update.
So after using over a half tank (well by the gauge) and adjusting the idle up for what will likely be summer "AC Idle" @500 in Drive - I am getting 13 MPG. This is still 80% if not more highway (re: Tx Farm Roads) driving. My 1st outing with the AC was not so happy, I had to keep putting her in neutral, so I upped it. I'd say it's 700~750 in neutral now. This half tank also wasn't me trying to get the best possible MPG. I wasn't dogging it all the time but I was far from being a grandpa too. Nothing like going WOT to beat a few yellow lights or passing some slow poke ;-)
I guess that is good?
PS: Last night on our drive I actually ended up being behind a 68 or so C10 on the Devil's Backbone Scenic Drive. He was very low to the ground and was either a dark blue or perhaps even purple - I couldn't tell as it was dark. Though I could tell he had the same LED backlights as me! I was really hoping he was going to stop at the bar or the rest stop but turned on a secondary road. I thought it would be weird if I had followed him to a house LOL
Richard
Old 04-12-2021, 06:46 PM   #130
1970cstblazer
1970cstblazer's Avatar
The 350 4 speed Blazer would avg. 15MPG. The 402 TH400 4.10 truck gets 12 MPG no matter if empty or loaded.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 04-13-2021, 05:53 PM   #131
DT1
DT1's Avatar
My 71 has a bone stock 350/350/Quad. On flat land at 60 MPH It gets 10 MPG.
On a downhill at 60 MPH it gets 10 MPG.
Against the wind at 60 MPH it gets 10 MPG.
My 72 is also a bone stock 350/350/Quad. Same thiName:  Finished C-10 005.jpg
DT1 is offline   Reply With Quote
Old 04-13-2021, 10:17 PM   #132
Accelo
Accelo's Avatar
When fuel mileage doens't change depending on load or speed it is indicative of under gearing.
Exactly why a modern overdrive transmission works so well in these trucks.
I was able to get a 30% improvement with a .70 overdrive ratio in a 700R4/4L60. The 6L80 have even higher ratios with double overdrive, both 5 and 6 are overdrives, with the final ratio in Sixth is 0.67.
The wide overall ratio spread of 6.04:1 allows a “steep” first gear, as well as a very “tall” overdrive top gear for low-rpm highway cruising.
The trend is for higher differential ratios and lower first gear. This tread is nothing new and has progressed since the power-glide days.
Also a another reason to switch to a 4L60. The lower first gear if good for performance.
When in doubt "switch it out".
Rick
Accelo is offline   Reply With Quote
