Old 06-05-2019, 09:15 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
New Complete Oil Pressure Line
This is a new complete oil pressure line for the Chevy and GMC trucks. I can make them for the Chevy small block V-8, Big Block V-8, & 6 cylinder engines. This would include the copper line, the brass adapter fitting that screws into the block, and the two brass compression sleeve nuts. One of the sleeve nuts screws into the back of the oil pressure gauge and one screws into the block adapter fitting. The line is 38” long for any SB V-8 application and 50" long for the Big Blocks and 6 Cyl applications. I have set the fitting on one end of the tube and you can use that end for the gauge or the block fitting, whichever you prefer. When shipped it will be attached to the block adapter fitting.
Installation instructions and tips are located at the link below..
http://67-72chevytrucks.com/vboard/s...d.php?t=613238
This is a link to information about the Big Block connection location and the extra adapter needed if your block doesn't have it.
http://67-72chevytrucks.com/vboard/s...d.php?t=638710
The complete SB line kit is $16.50 shipped, in a padded envelope. The Big Block and 6 Cylinder lines are $2.00 more because they have to be longer and the postage is more....
PayPal, Money Order, or check works for me.
Per board rules post in thread before any PM’s
(If this is down quite a few pages send me a PM after posting in the thread)
Thanks,
LockDoc
Leon
