Old 07-01-2025, 08:20 AM   #126
Advanced Design
Advanced Design's Avatar
Re: 2wd 1977 Blazer LS swap, mild drop….escalating
While I ruminate on the master and booster fitment issue, more front end parts were assembled and hoses are being test fit.
Advanced Design is offline   Reply With Quote
Old 07-04-2025, 12:39 PM   #127
Advanced Design
Lines are done and clamped with Notchhead clamps. My first use and I really like them!
Old 07-04-2025, 01:28 PM   #128
OutlawDrifter
Those clamps are cool! I'll have to check that out.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 07-08-2025, 08:28 AM   #129
Advanced Design
I was glad to have stumbled across them.
Right side fender is on.
Old 07-25-2025, 09:06 AM   #130
Advanced Design
The master cylinder to hood clearance issue was resolved with a mounting bracket I had made by a local shop.
Old 07-25-2025, 09:10 AM   #131
Advanced Design
Found a fresh air intake that would work and will swap out the silver clamps for black ones.
Old 07-25-2025, 09:16 AM   #132
Advanced Design
Brake lines are usually pretty simple and straightforward. In this case, I’ve struggled and done every way except the right way to make two lines to go from the master to the metering valve on the frame. Won’t bore everyone with all the details, except to say I’ve learned I can’t double flare stainless. And finally found the correct tube nuts for the 2018 Tahoe master cylinder.
Old 07-25-2025, 09:19 AM   #133
Advanced Design
Wife was working on prepping the underside of the hood for paint and found cracks in the hood fold crease. You know, the system that activates by folding the hood to let you know the hinges are too sticky?
I drilled holes at either end of the crack, cleaned it out and welded it up.
Old 07-28-2025, 10:08 AM   #134
oldman3
oldman3's Avatar
Doug, truck is really taking shape...Jim
oldman3 is offline   Reply With Quote
Old 07-28-2025, 12:14 PM   #135
SCOTI
SCOTI's Avatar
It wouldn't be a bad idea to add some 73-80 hood stiffener brackets while you're @ this stage.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-08-2025, 12:52 PM   #136
Advanced Design
Thank you, Jim!
Old 11-08-2025, 12:54 PM   #137
Advanced Design
Great suggestion. From LSfab…
Old 11-08-2025, 01:00 PM   #138
Advanced Design
Garth is buttoned up and going to a friends shop for the LS and body wiring. He loves doing it, is way better and much more experienced than I, so this will help speed things along.
My grandsons pushed Garth out the big door and made it over by the fuel tanks. I thought he handled well…lol.
Old 01-12-2026, 12:28 PM   #139
Advanced Design
Wired and fired.
Old 01-12-2026, 01:03 PM   #140
SCOTI
SCOTI's Avatar
Ready (well, closer) for some break-in/get acquainted miles for all the changes!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-12-2026, 01:51 PM   #141
Advanced Design
Yep, shake down for any bugs. Tried to load a video and apparently it isn’t the correct format. Exhaust shop we use is backed up until Jan 26, so interior is going in.
Going to take this one on HRPT, if we can get registered. HRPT site is overwhelmed this morning.
Old 01-12-2026, 03:17 PM   #142
rodstored-72
chevy truck fan
rodstored-72's Avatar
VERY COOL!! I remember when I got mine "wired & fired" for the first time, it was a really satisfiying feeling to "jump" over that hurdle.. keep us posted! thank you for the time to post the build process.
rodstored-72 is offline   Reply With Quote
Old 01-14-2026, 01:09 AM   #143
Willowrun
Willowrun's Avatar
This is the fun part. Very nice build and a ‘77 for that special touch.
Old 01-22-2026, 05:21 PM   #144
oldman3
oldman3's Avatar
Looking good Doug, ready to hear the new exhaust...Jim
Old 01-29-2026, 10:43 AM   #145
Advanced Design
Start up is always exciting! Thanks for checking in!
Very fun!
Thanks Jim! Hope you are doing well!
I don’t believe I mentioned the pedal mounting bracket I purchased from Hart Rod worked well. So much easier than making something and saved a lot of fabrication time.
