Old 12-05-2025, 02:24 PM   #126
Tempest67
Tempest67's Avatar
Re: 56 Chevy (RIP)
Originally Posted by Snake72 View Post
Tempest, I'm sure this is not near the quality of Ididit or Flaming River, but hopefully better than the Amazon specials. Super happy with it so far. Here's the link.
https://www.speedwaymotors.com/Unive...Raw,67289.html
Thanks for the link.
I would like to think that Speeway would not sell junk
Thanks again
Tempest67 is offline   Reply With Quote
Old 12-05-2025, 10:50 PM   #127
Blackie
Blackie's Avatar
Re: 56 Chevy (RIP)
Nice work, certainly gives you a lot more clearance to the headers 👍
It always seems impossible until it's done
Blackie is offline   Reply With Quote
Old 01-02-2026, 11:36 AM   #128
Snake72
Snake72's Avatar
Re: 56 Chevy (RIP)
Motor mounts welded in, motor and trans mated up with the FABbot adapter and trans crossmember fabricated and installed. Now I can see exactly where the shifter will be. I had to cut the shifter rod and will be making a new one. I also had to clearance the stock trans cover and made a small tunnel with cutout for shifter base. Brakes and clutch pedal are next, clutch will be a wilwood unit but undecided on brakes. Will be either a firewall mount booster or firewall mount manual wilwood master cylinders
Snake72 is offline   Reply With Quote
Old 01-03-2026, 12:38 AM   #129
dsraven
Re: 56 Chevy (RIP)
bucket seats and console or bench seat? maybe gonna need a dogleg in that shifter. if no console planned and youre gonna leave th floor area open, try to keep sharp bends in the tunnel cover to a minimum. it just makes it easier to fit floor coverings over.
Old 01-10-2026, 01:49 PM   #130
71'tahoe
71'tahoe's Avatar
Re: 56 Chevy (RIP)
Just read through this whole build. Very cool project!
71'tahoe is offline   Reply With Quote
Old 01-23-2026, 01:21 PM   #131
Snake72
Snake72's Avatar
Re: 56 Chevy (RIP)
Picked up another possible seat to try, this is out of an 80s jeep comanche. The sitting position, leg room, headroom and shifter location are all way better than the suburban seat I was using. Clutch and brake leg room much improved. However it is narrow and I think it looks too small for the cab. I might try to rework the suburban seats to sit lower and further back.
Also picked up Wilwood forward swing clutch and brake pedals. I'm in the middle of fabricating brackets and will post more on that when I finish up.
Old 01-23-2026, 01:48 PM   #132
6DoF
6DoF's Avatar
Re: 56 Chevy (RIP)
i'm currently running the dash swing brake/clutch and the 02 Yukon 2nd row seat in mine ... i have lots of head room, but could really use more leg room. however my head is basically on the back of the cab, so not sure i have far to go. maybe the different generation seat fits different? i also modified the crap out of the gm brackets too.
6DoF is offline   Reply With Quote
Old 01-23-2026, 02:53 PM   #133
Snake72
Snake72's Avatar
Re: 56 Chevy (RIP)
Thanks for the reply, my suburban seats are 2012 and really comfortable but I'm jammed up into the steering wheel. I'm not super tall, 6'2, but need more room for clutch / brake. I have a few ideas to try, would really like to make them work. For now, the comanche seat is winning.
Any way you can post a picture of your pedal set up 6Dof?
Old 01-24-2026, 03:32 PM   #134
dsraven
Re: 56 Chevy (RIP)
88-98 chevy truck seats are common to use it seems. some are split 60-40 and some are split 40-60 if you prefer. lots of guys take the headrest off so seat will go a littler further back. a seat from an extended cab truck will have a seat that allows the backs to tip forward for access to the rear seat area.
Old 01-29-2026, 01:06 PM   #135
6DoF
6DoF's Avatar
Re: 56 Chevy (RIP)
lots in the build thread:
https://67-72chevytrucks.com/vboard/...=814071&page=3
i bought 2 complete brake pedal kits and just used the pedal from the second, then a few mods got it all together as the clutch pedal. post #90 is the best picture of where i started, but lots of other pics in the thread of it coming together and later changes.
edit ... post #135, maybe #594, also #741
Old 02-02-2026, 01:51 PM   #136
Snake72
Snake72's Avatar
Re: 56 Chevy (RIP)
Thanks for the pics, that is the exact set up I was going to use if I went power brakes. I'll get pics of my wilwood pedal box set up posted soon, I think it'll work out great.
Old 02-04-2026, 07:50 PM   #137
Snake72
Snake72's Avatar
Re: 56 Chevy (RIP)
Here is how I set up my pedal box. Found a used wilwood clutch brake set on FB for cheap, they are 7:1 ratio. I called wilwood to get master cylinder size and went with 3/4" front and 5/8" rear MC. This brake pedal set has a balance bar to tune in the front / rear pressures so it uses 2 MC's. The clutch is 7/8 MC per fab bot manufacturing recommendations. I bought 2 brackets for the wilwood brake sets, cut them up and welded togther to make 1 clutch/brake bracket. Then bent up some steel to connect bracket to under dash and steering column mount. Its rigid. Got the pedals positioned exactly where I wanted them and drilled some holes in the firewall.
The stock firewall was those vertical ribs so I had to cut out the ribs and weld in flat sheet metal to have the masters sit flush. The only problem I ran into is mounting the reservoir on the master, I have to trim the ribs up further than I planned on. No biggie.
Old 02-04-2026, 07:52 PM   #138
Snake72
Snake72's Avatar
Re: 56 Chevy (RIP)
The brake pedal is about 1/8" away from column at closest. I tried mounting it to the left of the column but was unnatural to move my foot that far.
Old 02-05-2026, 09:03 AM   #139
6DoF
6DoF's Avatar
Re: 56 Chevy (RIP)
1/8" should be fine, worst case you scratch the finish in a panic situation but still stop well.
i love the idea of manual brakes and steering on a street rod, really liked 'em in the '69 Camaro I've driven. just better feel, more character, etc. i just need and excuse to build a small street rod now.
Old 02-06-2026, 11:22 AM   #140
Jason 56
Re: 56 Chevy (RIP)
Looking good. Following your build makes me want to start another one… maybe soon. Keep the progress going!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
