Old 09-10-2011, 10:24 AM   #1476
butternut1972
butternut1972's Avatar
Re: 1967 C10 Custom Big Window
looks and sounds killer slick. I wanna go for a ride...
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 09-10-2011, 10:57 AM   #1477
kev2809
low n' slo
kev2809's Avatar
good idea! lol
hey, what size tires you running front and back?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is online now   Reply With Quote
Old 09-10-2011, 12:35 PM   #1478
Slick67
Sofa King Crazy!!
Slick67's Avatar
Maybe one day if ya make it down south, i'd be happy to take you for a spin!
Originally Posted by kev2809 View Post
good idea! lol
Hahaha, looks cool enough to keep it on!! 245/35-20 front and 245/35-22 in back, I think. It's been awhile since I put them on, pretty sure that they are 245 and I am positive they are 35.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 09-10-2011, 06:12 PM   #1479
kev2809
low n' slo
kev2809's Avatar
dang...i scored a set of cheap 22's and they came with 30 series tires...i figure they are gonna be too small.
-_--_--_ _________
Old 09-11-2011, 12:28 AM   #1480
butternut1972
One of these days I'm going to take a long road trip in my truck and Texas looks like the place to be to see some killer trucks.
1998 SWB 4WD
Old 09-11-2011, 11:30 PM   #1481
Slick67
Sofa King Crazy!!
Slick67's Avatar
Nah. Ride on em till you need some new ones, then get some 35s!!
That sounds like a great plan, and I know some great places to go! Come on down and we'll have some BBQ and some cold ones after the show! First Saturday of every month we have the Coffee and Cars from 8 to 10 then the Niftee 50's show from 5 to 10. Go check out the Coffee and Cars FM249 on Youtube, there is some cool stuff there!
Old 09-12-2011, 02:56 PM   #1482
David67
David67's Avatar
Congrats on getting the engine back in and running!!!! I was home this past weekend and nifty fiftees was great. WOW. I've gotta check out Coffee and Cars.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 09-12-2011, 03:01 PM   #1483
78c10
Originally Posted by Slick67 View Post
Thank you for checkin out the thread! I will absolutely take what you have said into consideration. I do already have a PCV valve in the intake and will reroute my vacuum lines to the carb for more ventilation. If that isn't enough then I will use a "T" and split it to the PCV and the carb. That should be enough to evacuate the crankcase but as a last option I will drill the covers although I really hate to do so.
Attachment 797748
No problem, hope it helps out. I was looking at this pic, trying to see what you currently have configured. If I'm seeing it right, it looks like you've got a vac line going from the manifold vacuum port (just behind the passenger side of the carb) to the oil fill tube cap (which I am making a bit of an assumption on believing that it is also a breather filter). I also see a vac hose coming off the PCV fitting on the front of the carb, but I'm not certain where it's going, unless that's connecting to the PCV valve you mention in your response.
If I am seeing this right, I think it will all straighten out if you disconnect the vac line between the manifold and the breather filter and cap off both ends. If I'm not seeing it right, then I'm all wet.
78c10 is offline   Reply With Quote
Old 09-12-2011, 10:16 PM   #1484
Slick67
Sofa King Crazy!!
Slick67's Avatar
I was outta town this weekend so no shows, but the Coffee and Cars was incredible. 1932 Highboys all the way to Lambo Guillardos, it was really cool to see the full spectrum of new and old hot rods and exotics.
I did run the power booster to the manifold and the breather to the carb which seem to help alot. The hose you see going from the front of the carb is going to the trans, but that is changing tomorrow. I will run that to the small vaccum tube on the front which is really all it needs. It was running fine today with everything just thrown together with tubes not fitting properly and such, but it will done correctly by the weekend. This should be the fix to the problem, then it will be time to throw a new video up with it running properly!!!
Old 09-12-2011, 10:22 PM   #1485
Slick67
Sofa King Crazy!!
Slick67's Avatar
Did anyone see the orange 67 C10 at about 1:22 in the Youtube video above? That truck is really clean, and low! I was driving to the show that morning and I saw it going down the road in the opposite direction. Wish I could have gotten a couple of pics for you guys.
Old 09-13-2011, 07:55 AM   #1486
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice work David...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-13-2011, 09:18 AM   #1487
smbrouss70
smbrouss70's Avatar
He is a member on here, his name is Take2. His buddy greens69 is in the aqua colored Blazer 2 spots over.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-13-2011, 11:16 PM   #1488
Slick67
Sofa King Crazy!!
Slick67's Avatar
I have met the guy with the aqua Blazer before, he is good people. When I see him again maybe the orange short wide will be around him.
Old 09-15-2011, 07:18 PM   #1489
mightymouse
mightymouse's Avatar
hey slick . i just finished reading your build . i think it took me about 2 weeks.it turned out very nice. love the color too ! would like to paint mine orange if i ever get that far along..thanks for some good reading. hope you have lot's of fun with it..
mightymouse is offline   Reply With Quote
Old 09-15-2011, 11:17 PM   #1490
Slick67
Sofa King Crazy!!
Slick67's Avatar
Alot of guys here will tell you that is the biggest compliment and I agree! Thank you for taking the time to read through all of the trials and tribulations of the making of my ride. I hope to see a build thread on your truck soon! I will watch the progress and offer help where I can as will all the forum members. Keep on truckin!
Old 09-15-2011, 11:31 PM   #1491
Slick67
Sofa King Crazy!!
Slick67's Avatar
I don't think I posted this one. Here is a great pic of the front ends of 67 and 72.
Old 09-16-2011, 10:32 AM   #1492
big_al_71
big_al_71's Avatar
I just went thru your whole buil thread and WOW is all I can say....Outstanding job...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-16-2011, 10:52 PM   #1493
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks Bro!!! I really enjoy hearing someone checked out the whole thread, it's a huge compliment! I have checked in on yours from time to time and I really like the finished product, it is SWEET! The rim and tire choice was perfect for your truck. Thanks again big al!
Old 09-16-2011, 11:43 PM   #1494
Slick67
Sofa King Crazy!!
Slick67's Avatar
Well, today I set the timing for the final time and hope that the air/fuel is close. I pulled it out of the shop and back in to make sure all was fine for a short spin.
Old 09-16-2011, 11:51 PM   #1495
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here is the "little spin" around the block, everything seems fine except for the grinding sound in the speedometer. I guess that's not too bad. The video is kinda crappy since the camera was a little shaky.
Old 09-17-2011, 12:49 AM   #1496
VA72C10
VA72C10
VA72C10's Avatar
Very nice!!! Congrats...oh...and get that speedo cable fixed
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-17-2011, 01:41 AM   #1497
chevy88
chevy88's Avatar
Excellent job, I like the color of your truck.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 09-17-2011, 09:49 AM   #1498
67cheby
67cheby
67cheby's Avatar
ya what he said...LOL, is it the cable or the speedometer itself ??
67cheby is offline   Reply With Quote
Old 09-17-2011, 10:31 PM   #1499
68 TT
Still plays with trucks
68 TT's Avatar
Nice to see it back on the road.
It's far to quiet if you can hear that speedo mechanism clicking
It actually has quite a pleasant mellow sound to it at idle. It's nice to be able to hear the stereo without having it at 90% volume once in a while.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-17-2011, 11:01 PM   #1500
67chevy1series
67chevy1series's Avatar
nice! you know my 67 dealer book did say that factory A/C trucks are a quit ride LOL
67chevy1series is offline   Reply With Quote
1967, custom, lwb
