#1476 |
SSN 706
Re: Daverods project 66
I was thinking about putting these bags from SD ($200) on my 64. It already has the cut springs and I removed the bumper stops and brackets. How much more would the bags drop the front end? When all the air is out of the bags how low would it sit?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-05-2010 at 11:56 AM. |
#1477 |
Member of the longbed union.
that's how I was going to run mine. You wont be able to lay it on the frame in the front because of the crossmember, But that's the way to go, or make your own brackets.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 Last edited by ruffrida2005; 03-05-2010 at 02:21 PM. |
#1478 |
SSN 706
So when I let all the air out the crossmember would sit on the ground? Do you think I would have to change the steering set up?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-05-2010 at 11:01 PM. |
#1479 |
you wont have to mess with the steering. This is mine without drop spindles and a small notch in the rear. Gives you an Idea.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#1480 |
SSN 706
Sweet, I was worried about the steering. My truck has a lot of body roll.I thinking I need to put a sway bar on the front, maybe new shocks? I have a sway bar off a 71 sub. I going to see if it will work. Maybe something to do today.
#1481 |
Daring to be Different
Dave it will go as low in the front as the frame is where it touches to bump stops. Measure from the ground to the lowest part of the frame where the bump stops were. Then with the springs installed subtract the space between where the bump stop was and what would hit it. I hope that didn't sound too confusing. I wish I can draw you a picture.
![]() I wouldn't install a sway bar at all. If you install the front and rear air bag controls independently and not connected to each other, like front and rear controls on 2 switches. If you have each bag adjustable you don't need a sway bar. Example is when the truck leans to the right the air in that bag will gain more pressure. If the air line is connected to the left bag along with the right bag, and controlled with 1 switch, when the pressure gains in the right bag it will transfer the pressure to the left bag. Causing it to lean. When the pressure stays in each bag it will keep it from leaning to that side. Are you really confused now. ![]()
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#1482 | |
#1483 |
SSN 706
Thanks for the info guys. I'm going to put the sway bar on. On my 64 (Work/Driver) I'm thinking about bags with no compressor for now. I want the front lower and I thought that would be a good way/ cheap way to do it. I'm going to cut some more off my spring today just to see what it does. I want more of the stink bug look. Right now it's just about level.
#1484 | |
I got it this low without notching the frame or dropped spindles. ![]() ![]() ![]() ![]()
#1485 |
SSN 706
Cool ride.
#1486 | |
#1487 | |
Sure, you can run w/o them, but they are a benefit for stabilizing the front suspension when using softer, street friendly spring rates. To me, bags fall into that category regardless of whether they're controlled independently or not. I've ran dropped C10's w/o a sway bar & then installed one.... what a difference they make on vehicles w/higher COG's.
#1488 |
SSN 706
Loading up the sled when I got a killer idea for my tilt hood on my 66. I always wondered how people made them tilt. Now I have an idea.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-06-2010 at 02:19 PM. |
#1489 | |
#1490 |
SSN 706
#1491 |
#1492 |
SSN 706
I'm loading up now should be there in about 600/75=make it ten hours.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-06-2010 at 02:47 PM. |
#1493 | |
i do think you need to reinforce the rear of the setup a bit so youre able to lift the whole hood from one of the sides without bending it up
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#1494 |
SSN 706
Cut about 1/2 a coil off dropped about 2". Might be too much going for a drive.
#1495 |
Looks better
#1496 |
SSN 706
Rides sweet. Did'nt bottom out once. The springs where making some noise. Checked it out. They are rubbing on the sides of the mount on top? I did'nt replace the part that holds the bottom of them in. Maybe it's important.
#1497 | |
SSN 706
#1498 |
SSN 706
The morph.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-06-2010 at 05:59 PM. |
#1499 |
SSN 706
Bubba why don't you go buy this for me.
#1500 |
HOW long until spring??
![]() Join Date: Mar 2009
When we finish what we started here, then we will talk buying about a new project. Congratulations on driving your truck. Just starting mine is a rush, Driving it will come soon.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
