05-22-2016, 05:37 PM | #1476 |
Re: 1976 Square "Simple Green"
One day my will be almost as nice as yours. Probably have 30k or more in it by then!!!
05-22-2016, 05:39 PM | #1477 |
Another.
05-22-2016, 05:40 PM | #1478 |
Thank you. Yes you will.... Lol!!
05-22-2016, 05:42 PM | #1479 |
Another.. She took 300 pics so I have plenty. Going through them.
05-22-2016, 06:02 PM | #1480 |
More.
05-22-2016, 06:03 PM | #1481 |
Another
05-22-2016, 06:10 PM | #1482 |
And again..
05-22-2016, 06:18 PM | #1483 |
05-22-2016, 06:21 PM | #1484 |
05-22-2016, 06:33 PM | #1485 | |
Matt |
05-22-2016, 06:52 PM | #1486 |
Heard that man. I like how it looks the azz needs to come down a little. But I like it and I am low as you can go static in front and a lot cheaper than bags. And thanks about pics.
05-22-2016, 07:03 PM | #1487 |
How much clearance do you have on your control arms to the ground?
Matt |
05-22-2016, 07:11 PM | #1488 |
05-22-2016, 07:36 PM | #1489 |
The lowest point on LCA sits 2.75" from ground. I have not had issues with hitting ground.
05-22-2016, 07:48 PM | #1490 |
05-22-2016, 10:08 PM | #1491 |
Man I wish I could go that low. We have too many dips in the roads around here. I was planning on bags this summer but gonna have to wait awhile.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
05-23-2016, 04:50 AM | #1492 |
Man we got dip pot holes uneven lanes those little spots that are right before bridges or overpasses that jar the hell out of you. But these monotube shocks make a world of difference with all that now. I don't remember what setup I had I have had so many but with a twin tube shock I was smacking my long tubes when I had them I don't have them cause they would be dragging the ground just sitting. These monotube make a world of difference IMO being this low static a monotube is a must have.
05-23-2016, 05:38 AM | #1493 |
More pics. My wife's wasn't BSing me she took about 300 pics lol.
05-23-2016, 08:44 AM | #1494 |
So this morning before work the WSWR was on my mind about rubbing the back side. I could possibly just let it rub off what it needs but that would be half azz lazy. So with the precise measurement with my fingers lol I should be able to move it forward towards the grille and use the original bolt hole and the drill and use a clip. And it will move it out of the way of the wheel touching it in a hard right hand turn. We will see this evening.
05-23-2016, 08:51 AM | #1495 |
Also want to add on my response to UKNOWME. That the PB upper and Lower control arms are the key ingredient getting that low in the front. The 1" narrow and 1" forward is what I am using. If not for the PB control arms it wouldn't be possible.
05-23-2016, 09:29 AM | #1496 |
Plus having 22" wheels with the correct backspacing helps also lol.
05-23-2016, 10:14 AM | #1497 |
I wonder if I could get away with the 4" springs with mono shocks and no control arms for now. I'm currently running a 2 1/2 spindle and 2" spring. As you can tell I'm riding Cali right now and it bugs me.
05-23-2016, 10:22 AM | #1498 | |
I know from what I have done is anything past 5.5" front drop with the correct wheel spacing you will need the PB control arms. With those you can get 6.5" 7.5" 8.5" and in between. |
05-23-2016, 10:30 AM | #1499 |
No BS here. I have had stock, DJM, CPP, and PB control arms on my truck. And I should have bough the PB from the jump.
05-23-2016, 10:41 AM | #1500 |
See I have the opposite problem of what you have going on. My azz is sitting high now so I need a c notch so I can lower the rear another inch. Put me back how I want it.
