08-04-2018, 08:07 PM | #1501 |
Re: What did you do with your truck today, Part 3
I was under the truck making a lost of some of the rust I would like to attend too, and I saw both my cab corners have this nifty flap screwed on both sides. Has to have been on a while, has clutch head screws holding them on.
08-04-2018, 08:30 PM | #1502 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
08-04-2018, 11:20 PM | #1503 |
Finally was able to drive mine out of his bedroom he's been in for the last 15 years with a temp kidney . Made several trips around in the yard and gave him a good rinse off.
Hollis |
08-04-2018, 11:21 PM | #1504 |
Brian, inside cab looks great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
08-04-2018, 11:36 PM | #1505 |
That’s awesome, you all got me wanting an AD for my next project.
08-05-2018, 12:25 AM | #1506 |
once again failed to install a pulley. a simple pulley!! this will be week number two trying to install a simple waterpump pulley. I got the correct pulley from speedway but its going to require a small spacer to get the belts lined up. I had a fan spacer but it was a little to long. using some welding rod as a strait edge I measured with the long spacer on. the pulley was off by 23/64. it was a 1inch spacer so by my math I need a 0.65 spacer to line up. im not sure what sizes fan spacers come in but im going to start my search. after some searching im not finding a .65 spacer. the closest I can find is a .5 spacer with a shim kit that nets me .68 total. it would be a lot easier to cut my 1 inch spacer down but i don't have a way to make a clean flat cut and i don't want my fan wobbling around.
08-05-2018, 12:42 AM | #1507 |
Today I finished up bleeding the brakes then spent time replacing the pickup coil in the distributor. Hard to believe it stopped working after 28 years. Pulled the truck out of the barn for the first time in two years and spent three hours cleaning the exterior. Tomorrow, hopefully, I will begin the work of cleaning up the remains of the mouse tenancy.
08-05-2018, 12:50 AM | #1508 |
Thanks, I feel good for sure!
Brian
08-05-2018, 01:03 AM | #1509 |
Welllllll, I'm not a compressor expert but I think these broken flapper valves may be one of the problems with my compressor! I found them for only $25 including shipping, hope I can get them pretty fast. I sat out there tonight looking at the cab wondering what in the living hell can I do without a compressor! I have one small project, but I will do it, hopefully something else will come to me.
Of course, I can put the thing back together and use it with the one valve I guess, that's what I have been doing the last number of months. Brian
08-05-2018, 10:18 AM | #1510 | ||
08-05-2018, 10:26 AM | #1511 |
Mike, "Modification?" That looks stone original to me!
Brian
08-05-2018, 10:38 AM | #1512 |
I would have to take your word on it, I (being of a younger generation) have never seen the item before. But, you can bet I’ll preserve it and leave it equipped.
08-05-2018, 10:47 AM | #1513 |
It's not whether you have seen one, I never have either. But look how it fits, what are the odds something randomly would fit there, or if someone made it to go there, why?
Then look at how it's condition is exactly the same as the cab in that area, so it has aged and been exposed exactly the same, that means it was on there from the birth of the cab. The clutch heads, NO-ONE reused those clutch heads, they were tossed and phillips or a bolt or something was put there, NO-ONE reused those clutch heads. Those suckers were installed at the factory. Brian
08-05-2018, 10:53 AM | #1514 |
Well I have my cab corners in the mail and thought I'd better do some more prep. Got my wire wheel and removed all the bondo. I pulled out some bondo from the inside passenger corner, big chunks of it.
1950 Build |
08-05-2018, 11:53 AM | #1515 |
Yep, someone did a fine job.
Brian
08-05-2018, 02:41 PM | #1516 |
You look to have your work cut out for you. Nice
08-05-2018, 07:25 PM | #1517 |
Installed motor and Restomod Air serpentine drive kit.
08-05-2018, 09:05 PM | #1518 | |
Those are gravel deflectors. They were available from the factory or as a dealer add-on. I bought a set but never used them. The installation instructions can be found on page 567 of the factory assembly manual. |
08-05-2018, 09:25 PM | #1519 |
[QUOTE=1project2many;8316298]Hey Mikebte,
Those are gravel deflectors. They were available from the factory or as a dealer add-on. I bought a set but never used them. The installation instructions can be found on page 567 of the [QUOTE] Fantastic, Thanks for sharing the knowledge. I’ll be sure to restore and continue the use as gravel deflection.
08-05-2018, 09:29 PM | #1520 |
I drove my truck today! Whoohoo!! Had a helper with me, too.
08-05-2018, 11:55 PM | #1521 |
The Boss took our 2 younguns on a trip for the weekend- so I had some shop time. Finally installed the Pertronix unit I bought a year or so ago. Had to look up the directions to make sure I got the right paper in the box- positive ground still mixes me up..
Also, pulled my “new” 9’ box off the parts chassis I just got. Pulled the fenders off and hit that area with a flap wheel. I’d like to congratulate whoever’s grandpa learned how to gas weld the fenders to the running boards.. Let me tell you- nine feet is a lot of box. She’s a loooong dog.
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
08-06-2018, 12:15 AM | #1522 |
So the next thing I have to do, regardless of the compressor, I need to remove my work bench at the front of the garage and some shelves at the back so the truck will fit in there.
I had an old drill press that I used literally twice in the last ten years I have owned it. Then a grinder bolted to the bench that I have NEVER used. Then a paint shaker that I used once in a while but lived 13 in my shop never having one, so I obviously can live without it. I put a listing on Craigslist for the drill, shaker and grinder and an hour after posting it, it's all gone, wild! Brian
08-06-2018, 12:19 AM | #1523 | |
08-06-2018, 12:25 AM | #1524 |
Made a makeshift storage rack for my spare parts. I had a ton of parts stored in the bed in a lasagna style. So this way I can stack parts up on the upper frame and still access the stuff in my bed. IMG_3797 by Andrew Bushnell, on Flickr
08-06-2018, 12:26 AM | #1525 | |
