Old 03-27-2013, 04:56 AM   #1526
watahyahknow
watahyahknow's Avatar
Re: Finally starting my Longhorn 4x4 conversion
maibe you could put the exaust outside the frame then you only have the drop under or over the frame to get there and a leafspring to go over and you might even not need to go over the frame if you exit through the front inner fender
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-27-2013, 05:16 AM   #1527
coggonobrien
straight up through the hood..................just kidding. don't do stacks, hideous in my opinion. could you just notch the lower parts of your cross members slightly to keep it tucked then dump either ahead of or behind the tire?
coggonobrien is offline   Reply With Quote
Old 03-27-2013, 07:58 AM   #1528
ryanroo
ryanroo's Avatar
Ryan is about to feel this pain.
looking at the rear axle. not much room
from the side, not much room. there are not a lot of options, so i am thrilled to see what Mr. wrencher comes up with
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-27-2013, 09:48 AM   #1529
watahyahknow
sidepipes?
Old 03-27-2013, 08:03 PM   #1530
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
That's cool! I wonder how that would look?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-27-2013, 10:43 PM   #1531
Mattman2010
Mattman2010's Avatar
With a lifted truck I doubt they would look very good. And might burn a leg trying to get into the truck if the person is very short.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 03-27-2013, 10:49 PM   #1532
Mattman2010
Originally Posted by ryanroo View Post
I wonder if you could come under the frame between the transmission cross member and the 4 link bracket and come back to right in front of the rear tire?
Build Thread
Build Thread
Thread
Old 03-27-2013, 11:07 PM   #1533
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
If i could make the side pipes step tubes as well, I'd do it. I won't have it in front of the rear tire.................. Been there done that. I'd rather have a stack. I think I have an idea on how to get it through there. But it might be a while before I get there. I still don't have my dom. I just got my stuff from Ballistic yesterday.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-28-2013, 02:40 AM   #1534
watahyahknow
the truck is so high that it wouldnt be a problem to run the pipe inside the rear wheelwell over the tire , i think you whont hit it even at full travel
Old 03-28-2013, 08:17 AM   #1535
ryanroo
ryanroo's Avatar
how do you like those bushings? i am back to maybe running them on the front of my links so i can mount the shocks off the bottom links. cant use the stock dodge shock mounts after all
Ryan
72 K20 12v build
Old 03-30-2013, 09:49 AM   #1536
rkn463
rkn463's Avatar
I just found this part of the board recently and spent the last few days reading over this thread. A few thoughts:
1) Bad ass!
2) at times I'm lost (I don't know all the lingo)
3) and to quote Jase from Duck Dynasty: "the suspense is killing me!"
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 03-30-2013, 10:41 AM   #1537
ryanroo
ryanroo's Avatar
More suspense. Ryan is trying to let me get done first. he sidelined the longhorn for a little bit to work on some car...
72 K20 12v build
Old 03-30-2013, 11:57 PM   #1538
6BT 56
6BT 56's Avatar
Ryan I need your help.
I got the eng in my 56 all hooked up and good to go. Im having trouble with air in the system. Im using a raycor filter that has 2 inlets and one outlet. running my return line right back into the filter housing mounted on my firewall. Juist have one line from my tank into this filter . this sound ok to you? what does dodge do with there Returnline ? Does it need any kind of a restriction ? or maby 1 way check valve ?
Any help would be appreciated.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-31-2013, 12:29 PM   #1539
skchevota
skchevota's Avatar
The way you have your fuel plumbed will work once all the air is removed. Dodge runs there return back to the tank. The way you have yours will have the air running an endless loop. It would work much better to run your return back to the tank. The added Benifit is a supply of "cool" fuel coming from the tank not preheated in a constant loop untill burned .
Hope that helps
skchevota is offline   Reply With Quote
Old 03-31-2013, 12:56 PM   #1540
6BT 56
6BT 56's Avatar
Yep endles air was my problem. I got it running thismorn. Was cranky but Im going now. I have ditched the return to the filter and just have the return going into a bucket at the moment . Jusy thinking how I want to tap another line into my tank.
Thanks chevotia. You have a thread for your truck ? Sounds nice !
Old 03-31-2013, 01:12 PM   #1541
watahyahknow
doesnt the tank have a ventline in the top of the filleropening ? you might be able to put the returnline in there and use a tiny hole in the gascap for a vent another option would be to brace an extra tube intoo the fuelsender , you can remove that away from the tank and the diesel in it
Old 03-31-2013, 01:16 PM   #1542
ryanroo
ryanroo's Avatar
on my jeep i plumbed the return into the filler neck.
72 K20 12v build
Old 03-31-2013, 02:28 PM   #1543
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Hey...
Your working on some car?.....
I can't wait much longer for you to finish this truck......so i can borrow it and tow one of my slammers with it.....lol. You might have convinced me to revisit my CC big block dually after all.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 04-01-2013, 12:08 AM   #1544
skchevota
skchevota's Avatar
Post Re: Finally starting my Longhorn 4x4 conversion
Your welcome! Glad you got it running. I had an old build thread on mine when I had it on the original frame and running a 12 valve. It's been parked for about 5 years since I started my shop. Haven't had the time or $$ to move forward with it. I will have to get a new thread going on it one of these days . I need a shop build ! Lol
Old 04-01-2013, 11:38 AM   #1545
6BT 56
6BT 56's Avatar
Hey Ryan . What trans mount have you been using on your swaps. Im at that stage now . Not too sur if I want to use the 93 dodge style mount on mine or not .
Old 04-01-2013, 02:08 PM   #1546
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Check out ryanroo's mount, that's what I would do.
Tony
Old 04-01-2013, 03:44 PM   #1547
Dieselwrencher
Yes, I'd do a mount like his if you can. On this truck right now I have 2 poly bushings under the trans and the cross member is bolted to the cross member through the bushings. But I'll be redoing the trans cross member due to boxing the frame there. You could use the stock dodge trans mount and make a new lower plate to weld to your cross member. That way you can walk into a parts store and buy the mount and build it today and move on.
Ryan
Old 04-01-2013, 08:48 PM   #1548
ryanroo
ryanroo's Avatar
That was my original plan. parts store availability. but with a poly bushing, the odds of it going south are pretty low. so its a build it once and never think about it type thing as well. the reason i went poly was to match the material the engine mount was made of. and the stockers have a bad reputation.
also, i think its bad business to mount the crossmember to bushings at the frame. it gives the drivetrain a lot of leverage on the bushing and therefore will move more than it would if the bushing is centered
Ryan
72 K20 12v build
Old 04-01-2013, 11:47 PM   #1549
mosesburb
I had a V-8
mosesburb's Avatar
Ryan
I agree. A couple people I know did this and it did not end well for either of them. Now, that being said, they were not street-only vehicles, but I used their R&D to decide I wasn't going to copy them.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 04-02-2013, 01:17 PM   #1550
Ackattack
Ackattack's Avatar
Keep in mind, for a diesel, you don't want the return line just dumping into the top of the tank, you want to run a hose down into the existing fuel to avoid aeration.
Ackattack is offline   Reply With Quote
