#1526 |
Re: What did you do to your truck today.The 3rd chapter
Ditched the in cab gas tank and went with something a little more EFI friendly.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
#1527 | |
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod. |
#1528 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Very nice, I'm also curious about the capacity too.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#1529 |
Thanks guys, it’s a 60gal tank so I have the sending unit read empty when there’s about 20 gallons remaining. Even though the tank is baffled the pump was still starving for fuel under hard acceleration and left hand turns. I might install a sump at some point but for now I’m just enjoying being able to drive more than 100 miles between fill ups.
#1530 | |
![]() Join Date: Aug 2015
Steve/NH 1967 K10 327 Short Bed Stepside |
#1531 |
Removed my camshaft and lifters today. No mechanical issues found. It is a Gen I 5.3L 327ci that was rebuilt at some point. Next I will be replacing the valve springs and start cleaning it up for paint.
#1532 |
For someone mechanically challenged like me, adding the legal license plate light was a cinch! (previous owner put new bumpers on, but not this) And it worked first time!
1968 C-10 Long Bed Blue Cloud 1956 GMC 100 GYMEE 1969 Corvette that identifies as a Ferrari Daytona Spyder Fakerri 2016 Honda Civic EX-T Stealth |
#1533 |
Made it work for it keep. Not hard but enough
#1534 |
![]() Join Date: Feb 2019
Made a Custom Cab cover for a neighbor.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
#1535 |
Would like to have a couple of those you should sell them .
#1536 |
![]() ![]() Join Date: Jan 2005
Installed a steel lever kit in my heater controls and replaced the defroster ducts. Got the parts from GMCPauls, and the quality is top notch on both.
Also installed some stock valve covers that I bought from Ironhorse. Still need to find a grommet for the breather. |
#1537 |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#1538 |
Started putting the Inline Tube brake lines on my truck. Got the two rears along the rear end to the tee and flex line installed. Moving to the long line under the cab next.
1967 C10 1997 Ford Ranger 2020 Toyota 4Runner 2024 Toyota Tundra |
#1539 |
![]() Join Date: Dec 2012
New carb in - drove it to a cruise in last weekend and took this pic. This week I am checking timing and finishing up the set up. Went with a 500CFM on the engine. It's running great - very happy with the upgrade.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#1540 |
Found what I consider to be a super nice door to replace my damaged door. I've been looking all over and everything has been excessively rusty so far. Found this one 15 minutes from my house at a private wrecking yard that's not open to the public. The guy there was super nice and helpful. I have been stressing out about being able to find a nice door, so this is a big relief.
#1541 |
Almost Satisfied
![]() Join Date: Mar 2002
I just sat back and looked at it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#1542 | |
#1543 |
Old member
Been wanting to get the letters shadowed now for awhile. Well today it got done and I also did the wheels on the 64 SS Impala while he was here at the house.
Those pictures will be in the general area.
#1544 |
I can only imagine how hard it must be to find clean doors in NY
#1545 |
Hard to find a 8 year old truck with no rust.
#1546 |
Found a place top mount tires on original friction ring wheels. Sanded and painted wheels and cleaned up hub caps as best I could. I will only use these for pictures and shows but I like the original look.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
#1547 |
Old member
Pulled the cluster out to see what happened to the tach.
Stud is broke off inside of it. I will have to call Manes in the morning to see if they will warranty it. It's less than a year old. It just spins around it's not attached to anything. I can pull it up but not out.
#1548 |
![]() Join Date: Jan 2007
Perfect!
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#1549 |
![]() Join Date: Jun 2019
Painting is now complete! I see now why folks hire this done. It’s a ton of work!
#1550 |
Lowered the bench seat 2 inches with Full Custom Fab brackets, and wired up my audio system (Kenwood h/u and Infinity 4" and 6.5" speakers) from scratch.
| Bookmarks |
