01-06-2015, 01:09 AM | #1551 |
Re: What did you do to your truck today? Chapter II
Mocked up some motor mounts for my 70 swb 5.3/4l80-e project
01-06-2015, 01:54 AM | #1552 |
Apparently I had two wires make contact on my starter while driving to work, the back fire was so loud that Patton would have been impressed, melt my battery cable, kill my (Optima) battery and .......
These are the mufflers that included with LMC's "Complete V8 high performance dual exhaust system...." . Great kit, could use a little bit better instructions, and the fit is a little bit tight on a lowered truck. So I ...... And all is good !
1968 C/10 short bed 1969 SS 396 Camaro "there's no replacement for displacement" |
01-06-2015, 02:07 AM | #1553 |
pulled the edge of the rubber flooring on the passenger side and saw some crud . wiped it out with my key. tapped the floor in that spot a couple times and made a pinhole of daylight through my floor I though my floors were solid
01-06-2015, 08:28 AM | #1554 |
those new mufflers should hold up to many backfires!
01-06-2015, 11:58 AM | #1555 |
Did you do them yourself?
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
01-06-2015, 11:59 AM | #1556 |
Are you making your own?
01-06-2015, 01:56 PM | #1557 | |
01-06-2015, 02:28 PM | #1558 | |
RAT1968 '68 Cab/'71 Parts
Here's a parts list: About ten feet of 4 7/8" (or whatever it is) left over flooring material...any floor installation place has a bunch of 18" scraps. A yard of carpet that matches your interior to your liking (mine was under $20 from the dollar store...I got about 2.5 yds) ... ...the stuff I had was left over from the tank cover and kick and lower door panels. Some heavy poster board or cardboard for templates. A hundred different (in different sizes) wood and sheet metal screws. About twenty feet of 1 x 2 scrap wood. Maybe twenty feet of 1 x 1 if you want to rip the the 1 x 1. Four 1/2" "L" brackets (with the legs about 1-1/2" on each side) to hold the cabinet to the floor on the bottom, and screw (or bolt) through to the existing holes under the a/c or heater controls on the under side of the dash. Some spray glue to attach the carpet to the outside of the box. Some Elmer's wood glue to stiffen up the wood support joints inside the box. Some kind of clamps to help you hold everything in place while you glue/screw..... Unless you have six hands. After I did the interior bracket for the radio, I cut the hole in the face plate (made of 2 sections of the floor material glued together), I covered the face with some faux-carbon fiber material. I had to attach blocks inside the at the corners of the box to screw the face on. I wanted/needed access for the electronics installation and for playing with it, if necessary, down the road. For me, it was about thirty bucks and a few days of work. Would be less if I don't count the carpet. In actuality, it really only cost me the gas to get to a friends house to snag some scrap bracing wood. But, I already had all the stuff laying around. This one's not for everyone. But it serves my purposes pretty well.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 01-06-2015 at 03:01 PM. |
01-06-2015, 03:51 PM | #1559 | |
01-06-2015, 09:13 PM | #1560 |
got the Flowmasters installed today. tomorrow put the bed back on and get ready for paint.
01-07-2015, 02:29 AM | #1561 |
01-07-2015, 03:03 PM | #1562 |
Cool! Make sure you post some pictures! Have you been posting in the LS Swappers thread?
01-07-2015, 07:25 PM | #1563 |
No, but I'd like to. I'm not sure how to move my post into certain sections or categories. I'd like to move my build thread into the build thread.
01-07-2015, 10:10 PM | #1564 |
Aligned my '72 today. The alignment shop got two tries first... but apparently this truck "isn't in the computer" (go figure) and after I told them how to measure for toe, then received it back toed 3/16" OUTWARD, I just said screw it and did it myself. I guess the old saw about doing it yourself is true...
Now the truck is toed factory 1/8" in and drives better than ever.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
01-07-2015, 10:52 PM | #1565 |
Just spent the day cleaning bolts and painting them.... Not much else to do right now till the ole lady stops spending my parts money on un-necessary crap like food, and gas, and kids schooling and stuff like that. Work is slow right now.... Story of my life, when i have time I have no money and when I have money I have no time.... Life, go figure....
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
01-08-2015, 12:06 AM | #1566 | |
01-08-2015, 09:58 AM | #1567 |
Ive had over 1000 bucks of body parts and patches sitting in my LMC shopping cart for 3 weeks or so now.... It will be the first sizable purchase. Ive done smaller stuff that has to sit until its time for them. You know, the stuff you see for a great deal but are nowhere near ready for buy you couldnt pass up.
01-08-2015, 05:30 PM | #1568 |
Yesterday I installed a vacuum gauge, today I replaced the heater core I broke while routing the vacuum line for the gauge. I guess I stepped on the hose while I was under the hood. Go figure the coldest day of the year too.
01-08-2015, 07:48 PM | #1569 | |
Who Changed This?
All I did today was drive mine for the first time in a few weeks. Too much going on, and I'm retired!
01-08-2015, 09:09 PM | #1570 |
01-08-2015, 10:05 PM | #1571 |
[QUOTE=gutterworks129;6991609]I cleaned and prepped/painted this engine that was in a barn for 8yrs in VA. I bought a project truck that the guy gave up on 8yrs ago
very nice clean up and paint job, and welcome to the forum from Texas, we like lots of pic's keep them coming... |
01-09-2015, 09:14 AM | #1572 |
got the bed back on. that was a neat trick by myself! as soon as it warms up a bit, I'll get some paint on it.
01-09-2015, 11:02 AM | #1573 |
Brazed a 3/8" hose barb in my factory rad for my LS Steam port.
01-09-2015, 11:47 AM | #1574 |
Put an ol school stagger tall fat/small skinny tire combo on ol Owen and painted the wheels white.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
01-09-2015, 11:48 AM | #1575 |
Gave me the rake I wanted to.
