04-17-2021, 02:28 PM | #1601 |
Re: A '54 named Busty
It's Saturday and on Saturday you need to pick your priorities, and you chose well!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-17-2021, 11:12 PM | #1602 |
Post Whore
04-17-2021, 11:14 PM | #1603 |
Post Whore
then went ahead and mounted the grille, just needed her to look like a truck again
04-17-2021, 11:15 PM | #1604 |
Post Whore
well after 9 hours spent trying to get a broken off rivet end out of the rivet gun
04-17-2021, 11:18 PM | #1605 |
Post Whore
and then this happened, and it made my day... she's 16 and her nick name is baby Hercules she busted off like three bolts already overtightening them... I couldn't be more proud!
04-17-2021, 11:20 PM | #1606 |
Post Whore
the hand slicer needed trimming and folding over
04-17-2021, 11:21 PM | #1607 |
Post Whore
all more better and almost accessible too
04-17-2021, 11:26 PM | #1608 |
Post Whore
here you go
04-17-2021, 11:30 PM | #1609 |
Post Whore
started mocking up the front bumper, not sure I want to run the stock one as it sticks out 3 feet
04-17-2021, 11:32 PM | #1610 |
Post Whore
can somebody tell me what the hewk this horseshoe U joint clamp thinge was supposed to be?
04-17-2021, 11:34 PM | #1611 |
Post Whore
thank goodness the person who stuck this on was a crappy welder, yes it takes one to know one, somehow I own three front bumpers allowing me the luxury of playing with them
04-17-2021, 11:36 PM | #1612 |
Post Whore
apologies for the poor back lit pics, I have a West facing garage and couldn't shut the door on her
04-17-2021, 11:39 PM | #1613 |
Post Whore
I found some threaded holes underneath the frame horns so I chased them in hopes of using them at least to hold the mock up bracketry on for me
these may have been for the Camaro sway bar I'm not sure |
04-17-2021, 11:40 PM | #1614 |
Post Whore
since one side of the stock front fender mounting brackets was already separated I decided to divorce the other side as well for easier installability and tinkerability
here I am grounding down the head of that rivet before pounding it out |
04-18-2021, 12:27 PM | #1615 |
Post Whore
meanwhile the new MOOG all Made in the U.S.A. steering components are trickling in nicely
04-19-2021, 07:56 AM | #1616 |
get after it dude, it looks mean.
is she German? going for the proper torque spec of Goudentite |
04-19-2021, 09:41 AM | #1617 |
it does look mean (the truck)
Thanks for the pics and glad to see you are back at it
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
04-19-2021, 12:25 PM | #1618 |
Post Whore
04-20-2021, 12:15 AM | #1619 |
Post Whore
decided to give her a little colonoscopy today, just had to know the 8.5" 10 bolt rear end digits so that I could set my speedo proper in HP Tuners
we can make out 16 41 followed by 1 77 so looks like it was assembled on 1=January in 77=1977 then we take the bigger number 41 and divide it by the smaller number 16 carry the one, times the circumference of the earth and we go ourselves a 2.56 tall gear rear end, good highway gears but this don't explain why she is so burly with that little 5.3L in her http://www.teufert.net/camaro/1977.htm apologies the pics are blurry Last edited by Gregski; 04-20-2021 at 09:49 AM. |
04-20-2021, 11:03 AM | #1620 |
Post Whore
started wiring up the Auto Meter Z-Series gauges last night, the wires will get cleaned up, zipped tied and loomed, this is just a moch up to make sure everything reaches and works first
even found a place for the Obi-Wan Kenobi glad that I didn't have to drill new holes, same for the MIL aka check engine light, I may just put the high beam light in the other hole, might not even wire it up just use it as a conversation piece |
04-20-2021, 11:17 AM | #1621 |
Don't forget to label that check engine light, lest you forget what it is. I'm not speaking from experience here, as far as you know....
04-20-2021, 11:27 AM | #1622 |
04-20-2021, 11:32 AM | #1623 |
Post Whore
04-20-2021, 03:45 PM | #1624 |
Post Whore
so it appears the previous owner did a Craigslist rebuild on the rear end, aka rattle canned it black right over the grease and rust, that's not right so I took her down to bare metal
04-20-2021, 03:48 PM | #1625 |
Post Whore
a little stare and compare of the before (dirty) bowl and the after (clean) bowl
