![]() ![]() Join Date: Nov 2008
Re: What Did You Do With Your Truck Today ?
Ha ha ha, I know what that means: Get OFF YOUR ASS Dan!
So I came down with a case of anal glaucoma today (I couldn't see my ass going to work! ![]() Backside of front bumper: Crusty rust & old chrome bubbling loose in places: ![]() Following directions I diluted Ospho 3:1 and sprayed one side. Full strength by brush on other side. Kept it wet for HOURS - not much happened. After 8 hours my impatient ass was tired of waiting (Yes Virginia, I know you're supposed to wait 24hrs.) I washed it off, dried & used a 3M wheel to remove the remaining rust and loose flaky chrome. Came out decent: ![]() In the center (above) you can KINDA see where the Ospho pooled so it stayed submerged/worked best. I bet it would work great if you get $100 worth (riiight) to submerge a big part in a kiddie pool. After, I sprayed it with the Reformer and up close it came out quite smooth given where it started: ![]() Hit it with the Rust Reformer - Don't flame me, I like that stuff. I don't know if it's just black spray paint and I'm fooling myself, but I'm going willingly! ![]() |
polishing a turd
no pics, but i disassembled the front clip. finally getting back to work on mine after it sat for a few years.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
my new fuel tank came today.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
Oh and P.S. I also used the 3M wheel to strip the front side of the grill under-apron. I wire brushed the backside (sorry, forgot to take a pic) and sprayed it AND the grill with the Rust Reformer. Label says you've gotta wait 24hrs (grrrr...) to top coat. Pics of THAT hopefully tomorrow.
Stripped but Reformer on the mounts where the 3M wheel couldn't reach. I DID spend a while to scrape the loosest rust off with a flat screwdriver. Best I could do. BEFORE: ![]() AFTER: ![]() |
epoxy primed a few pieces and started welding patch panels on the left fender.
Where do you get the cowl panel with out louvors?
They used to be available in steel. I need a web address or link, can't find no limit....??? Last edited by dicer; 03-12-2013 at 05:35 AM. |
Nolimitengineering.net I believe.
Posted via Mobile Device |
After two years, i finally installed the new clutch in my truck.. Now to work on getting it running.
continued working on one of my rear fenders. Welded a new piece in the flange that bolts to the box side. Been putting in overtime so only have a few hrs here and there to tinker.
oldcouple - I'm pretty sure that's a Chinese grille and I've heard differing opinions on whether they fit properly or not. I WILL have a chrome grille someday but for the present I'm just trying to get my truck to a clean, reliable weekend driver. THEN later I will likely blow it all apart and do high end paint and chrome.
Finished the rear driver fender mounting flange and started pounding out the small dents here and there.
Yesterday I took a drive on the back country roads down in Missouri. I had just rolled it out of the shop for the first time since November's snow hit.
The plan was to verify the gas tank's range and enjoy the nice heater on a cloudy cold day. It ran dry 3-miles from the gas station, which is another 3-miles from home. Now I know. Last edited by Highsider; 03-17-2013 at 10:25 PM. |
#13 |
Took all damn day just to do these few things:
"BEFORE" condition: ![]() AFTER : ![]() |
#14 |
BEFORE:
![]() AFTER: ![]() Heavy "pecks" under the eyebrow of the ring visible in this pic: ![]() |
#15 |
How did you do that Dan?
#16 |
Finally got heater and windshield wiper motor installed .Nice to have heat/defrosters.
#17 |
![]() ![]() On the buckets: 1st I washed them with degreaser and a scrub brush, then used a wire wheel on my bench grinder to remove rust & some undercoating a previous owner got on them. Then I used Rustoleum red oxide primer and after it flashed I used their Professional grade semi gloss black. Headlight bezels got polished with Turtle wax chrome polish and OOO Steel wool. Posted via Mobile Device |
#18 | |
I still have a couple of cans of the TW chrome polish from the seventies! Photos show correctly. Thanks, Dan. Last edited by Highsider; 03-18-2013 at 03:01 PM. |
#19 |
I forgot, last week I did about the same things as Dan.
Even put in new stainless screws to hold it all in. Added new NAPA 7" halogen bulbs and a SpeedWay.com headlight relay kit. Also, installed a cooling fan manual dash switch and fan relay kit. So, yes Dan...how did you achieve the "new" look for the chrome rings? |
#20 |
Finally got all paint & clear coat done on sheet metal. Still alot to be done but getting the paint done is major. Black base coat/satin clear.
Time to start assembly. |
#21 | |
56 - autocross
Can you please tell us about the booth you constructed. I see a fan, did you use two? Can u post more pics of the booth? |
#22 |
By the way, on my iPhone (I'm posting from it now) the photos all show as being upside down! But last night on my laptop they were correct. What are you guys seeing?
#23 |
My stuff is small potatoes;
hsdropout, your paint is NOT "small potatoes". It looks really good. Are you an experienced painter? I'd really like to see details on your home built booth too and any info on the paint, you used, HVLP (I assume) tip size, etc? Posted via Mobile Device |
#24 |
i gutted all the old wiring out of the cab, which was a good thing. I found 14 splices and the ignition switch has 10 leads coming off of it, what a mess. I also patched up a couple spots on the floor and took a wire wheel to the rest of the can floor so I can prep it for coating and then sound deadener. My Rebel Wiring harness has shown up so I can start the task of mounting the fuse panel and running wires to their new home.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#25 |
Sounds like a nest of snakes you had there. You got a LOT of work done.
