Closed Thread
Old 09-23-2015, 10:33 AM   #1626
earl84
Re: What did you do to your truck today part III
Sorry no pics right now, but I got my Vintage Air system all charged up and I now have AC and a heater that kicks butt, with fan speeds that are much better than my stock setup was. Just in time on the heat and fan part for the soon to be here winter. The AC worked very well down the hill in Denver where it was in the low 80's yesterday. If you want a super detailed thread on the install, go here http://www.67-72chevytrucks.com/vboa...d.php?t=468107 My install was done with all the VA parts and went well, and I did it with no help. Challenging, but rewarding.
earl84 is offline
Old 09-23-2015, 03:19 PM   #1627
OldChevy61
OldChevy61's Avatar
Got the rest of the frame cleaned up, primed and painted. Now for the a arms and torsion bars and I can start emptying some of the boxes,lol.
OldChevy61 is offline
Old 09-23-2015, 04:13 PM   #1628
Pappyx3!
Pappyx3!'s Avatar
Looking good!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline
Old 09-23-2015, 09:04 PM   #1629
Blue666(2)
Originally Posted by RKS0069 View Post
Dry fitting the tanks.
Can you tell us more about the tanks? What size (gallons) and inches? Are these under a short bed or a long bed? Looks like a great idea.
Wiil you use a tank switch valve between them?
Thanks.
Blue666(2) is offline
Old 09-23-2015, 11:53 PM   #1630
DLW
Got the ididit tilt steering column and billet specialties steering wheel installed as well as the steering linkage down to the rack and pinion.
While I was at it I installed the New Port Engineering wiper motor.
And I started bolting on the OEM inner fenders and radiator core support I just had freshly powder coated.
DLW is offline
Old 09-24-2015, 11:30 AM   #1631
RKS0069
RKS0069's Avatar
Thanks.
Hi. Theses tanks are one of the options from LMC. They are 21 gallons each. I can not remember the dimensions of the tanks, I'll measure them and post findings later today. This truck is a '62 GMC long bed. The '60,'61 and '62 frames are much wider in the rear than the '63 and newer frames. My original plan was to use just one tank but after mocking up the single tank I realized that two tanks would fit if I turned them sideways, I ordered the second tank that day. I'm going to run two stainless 3/8 lines to the engine bay and install a valve there.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline
Old 09-24-2015, 02:45 PM   #1632
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by DLW View Post
Got the ididit tilt steering column...
Does the steering column come with the holes in the column for the column support bracket to bolt up?
The Rocknrod is offline
Old 09-24-2015, 04:00 PM   #1633
DLW
It did not, I had to drill and tap them myself. Not sure why ididit doesn't just add a slotted bracket of some sort, but it was pretty easy to do it myself.
DLW is offline
Old 09-24-2015, 04:09 PM   #1634
RKS0069
RKS0069's Avatar
Weird. My Ididit does have slots.
1972 C-10 SWB
1962 3/4 ton LWB
RKS0069 is offline
Old 09-24-2015, 09:16 PM   #1635
DLW
Could be they couldn't accommodate those in the column shift, where as yours is a floor shift?
DLW is offline
Old 09-24-2015, 09:39 PM   #1636
RKS0069
RKS0069's Avatar
Ahhh yes!!
I looked in the garage at the Ididit column for the '72 c10 and it has one short slot but it's not for mounting. Haven't had that column in that truck for fourteen years so I don't remember how it mounts but must be a clamp or something.
DLW
I'm really digging the gray and black. Beautiful truck!
1972 C-10 SWB
1962 3/4 ton LWB
RKS0069 is offline
Old 09-24-2015, 10:46 PM   #1637
DaddyOh
DaddyOh's Avatar
How long of a steering column did you go with? Also, how much are you past firewall in the engine compartment? I'd guess 5"....?
Been looking at Flaming River as well... trying to figure out why they are 125.00 more though.... NICE install!
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356
DaddyOh is offline
Old 09-24-2015, 11:01 PM   #1638
cv65
cv65's Avatar
Im in the middle of a ididit colunm, 700r4 switch from a 3 on the tree,my new ididit colum has 2 slots to move in and out comes with bolts, colunm shift. DLW we arent far from each other should get together and shoot the ---- Ha Ha
cv65 is offline
Old 09-25-2015, 10:50 AM   #1639
Chevy Fleetside
Chevy Fleetside's Avatar
My brake reservoir emptied twice, when I looked down you could see the paint coming off the booster and on the frame. This master is only a few years old and I guess it failed. I changed it out and was hoping I didn't have to bleed the whole system. I pulled the truck out and was able to make the brake pedal go to the floor. I figured their was air in the line. Well when I went to bleed them the right front wheel was wet. I know the last time I put brake pads in the truck the line kinked when I put the caliper back on and I didn't know until I drove the truck. I think that is when the line was compromised and might have had a pin hole in it. Now I just have to change the line and bleed the brakes. woooo hoooo.
I touched up the booster and painted the Master Stainless Steel from Rust Oleum Professional
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 09-25-2015, 11:41 AM   #1640
DLW
Ahhh yes!!
DLW
Thanks for the compliment. I'd like to go shopping in your yard for some parts some time ..
Not sure on total length, seems like I remember somewhere in the 30-31" range, but don't quote me on that. I can grab a tape and measure how much it comes out of firewall, it is at least 5" to the end of the shaft, probably more.
Well, then I don't know what the deal is with the slots then. I know others have also had to drill and tap with theirs. Maybe they made some changes recently. I bought part number 1150650030 which is the retrofit column for the 60-66. I would rather of had the slotted one myself.
Definitely should meet up sometime since your just up the road.
DLW is offline
Old 09-25-2015, 01:23 PM   #1641
DaddyOh
DaddyOh's Avatar
Thanks for the info, looks to be a 32-33" column.
Other than drill/tap the column to accept factory bracket, were there any issues using the 'stock' brackets? Also, any issues or special parts going through the firewall?
DaddyOh is offline
Old 09-25-2015, 01:54 PM   #1642
62stepside longbox
62stepside longbox's Avatar
Cleaned up and painted my carter CAR-buret-TER fuel filter
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline
Old 09-25-2015, 04:19 PM   #1643
DLW
No issues at all installing this, fit very nicely. I do have a different steering shaft setup than stock so I can't comment on that though.
DLW is offline
Old 09-25-2015, 04:41 PM   #1644
Finished getting engine back together. New distributor in and the Mule is mobile again.
Palf70Step is offline
Old 09-25-2015, 05:58 PM   #1645
Grizz1963
Grizz1963's Avatar
So Momma goes to Butlins for a 4 day 70's themed weekend with her school reunion friends........
Where does that leave me??
TRUCK TIME !!!
Passenger sill repair.
Got to say, with a further fine grind, some paint and the door seals, this will be just fine.
Tomorrow I plan on cutting out the drivers kick panel, making up a patch panel and then welding that in, followed by welding up all the holes in the floor and various other places in the cab that should not be there.
Then some rust converter and eventually paint.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 09-25-2015, 06:11 PM   #1646
cv65
cv65's Avatar
Definitely should meet up sometime since your just up the road.[/QUOTE]
I ordered 1140650051 black powder coated colunm shift,you have right part# for brushed aium. wonder why no slots in yours?Yea when i get my mess straightened out and running again we should compare notes Ha Ha Im doing steering colunm, power steering ,700r4,getting rid of 3 speed and crossmembers,so probably in a month or so should be back on the road. Im 66 and dont move like I used to Ha Ha
cv65 is offline
Old 09-26-2015, 10:23 AM   #1647
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I finally got the bed back on the truck, bed wood in and all squared up. Now for inner fenders and bedsides.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 09-27-2015, 05:25 AM   #1648
Grizz1963
Grizz1963's Avatar
patch for the passenger floor.
Patch cut and made to fit. Then welded and ground back.
After this I marked, cut, fabricated and welded in a drivers sill panel.
It is actually better than the photo implies?
With failing light, I had opened up this bit of rust and made a repair panel, but walked away as the light was not bright at all.
Tomorrow, Bootfair then carry on with the cab.
Old 09-27-2015, 05:53 PM   #1649
LT1 Burb
LT1 Burb's Avatar
Nice job Grizz
LT1 Burb is offline
Old 09-27-2015, 07:11 PM   #1650
Closed Thread
